Question about Vacuums
My kenwood steam mop makes for very wet mopping is this supposed to be? My floors are a lot wetter than when I use a traditional mop. When I fill the tank and turn it on the water seems to just leak from the bottom so I have only been half filling it and then the water light comes on within 2 mins of when steam starts to appear. What am I doing wrong??
5 Suggested Answers
SOURCE: My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
heatman101
  • 43501 Answers
SOURCE: I just filled and started using my steam mop.
The water you are using is not able to make steam easily...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 26, 2010
SOURCE: Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Posted on Mar 26, 2011
SOURCE: Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Posted on Nov 27, 2011
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam comes out very little and the floors do not get wet at all
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Dec 18, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Makes steam. Leaks where pad goes into pad attachment. Pad doesn't get hot steam...just water but the pad doesn't really get wet but the floor does.
heatman101
Oct 10, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Need video or large diagram instructions for what to put together
heatman101
ui
May 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I just filled and started using my steam mop. There was a lot of steam initially, but the mop quickly lost steam and heat within a few minutes of using it. Any ideas?
heatman101
Apr 10, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop is spilling water out and not steaming.
Empty tank and fill with bottled spring water...
heatman101
Dec 05, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Kenwood Steam mop
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
