Question about Bernina Bernette 75
Feed teeth have dropped down
I have a Bernette 720, the feed teeth have dropped down below the plate so they are not grabbing onto the fabric and feeding it through. I was wondering if I have missed something simple, like there is a darning control that I have mistakingly turned on. Can anyone enlighten me on this? Thanks
Actually Richard Engel, on the Bernette 720, the mechanism which raises the feed dogs above the plate is located below the plate to the right of the bobbin case holder assembly. It is a simple push-pull pivoted can with a roller on top.
Sometimes it is little bit stiff to move.
Posted on Dec 31, 2011
  • 202 Answers
Hi. Benieth the free arm there is a lever that you can switch from left to right. This raises and lowers the feeddogs for normal sewing and darning. Possibly you need to flip that switch lever. If that doesn't solve it then the freearm cover on the bottom needs to be removed and the feeddog mechanism cleaned and oiled. Could be stuck.
Good luck. Hope its the easy fix.
Rick
Posted on Jan 21, 2009
  • Doris
    Doris Apr 24, 2016
    I have the same question for my Singer 4530-merriott.
Thank you for the rapid response. It's a Husqv 1070 model. I have cleaned out the lint under the pressure foot and plate. The feed teeth are still not feeding the fabric. Any thoughts?
Are the feed dogs actually functioning? Are they dropped below the needle plate, move forward, then up, and move toward the back while above the needle plate? If so, then they are working properly. If they are not rising above the needle plate, then they could be stuck in the lowered position (check that it is not set for darning). If they are not moving at all, then something may be disconnected or they are gummed up from old oil that has dried. If they are moving, but not grabbing the fabric, then the teeth could be worn down.
Jan 30, 2017 | Sewing Machines
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
The little Teeth/feeder under the foot doesn't push the fabric out. The fabric doesn't move
check where the direction button/lever is
it controls the feed mechanism and if it is in the middle the teeth will just go up and down
set it one way and it moves forward and set the other way will go in reverse
it is graduated to provide a stitch length ( number of stitches per 1")
Oct 23, 2015 | Sewing Machines
Fabric does not feed through machine
When you sew the machine must be set at the correct settings. If your machine won't straight stitch, turn it off at the power point and then turn it back on. Most machines reset to the default straight stitch setting. Secondly when you sew the presser foot must be down. This engages the "feed dogs" or the triangular looking "teeth" below the presser foot. As you sew, the feed dogs grab the two layers of fabric pulling them through, the thread above (spool) and the thread below (bobbin) meet to form the stitch. Finally, maybe fiddling around with dials and settings you may have dropped, or disengaged the feed dogs. Check with your manual on how to re-engage the feed dogs. Hope this helps and happy sewing. Remember, when all else fails..... read the manual.
Mar 11, 2015 | Brother XL-5700 Mechanical Sewing Machine
Problem with brother vx-1120 will not feed fabric
This is usually caused by the feed-dog ( the metal teeth in the area below the needle) being down instead of up - run your finger under there (over the teeth) if they do not stick up above the base line of the machine, they cannot feed the fabric. If this is the case, look in your manual (or and online manual for your machine) and find out how to put the feed dog up. Other than this, some machines have a plastic plate which fits over the feed dog, so that you can do free machine embroidery, if this is the case, you should be able to remove this and the fabric will feed through
Nov 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
How do I get the teeth to grab and advance the material on my very old Bernina 830?
Well there's a number of reasons why it may not be advancing the material. First, ensure that the teeth are completely cleaned-out - get an old toothbrush, or similar with firm filaments and, with the stitch-plate removed and the bobbin door open, give the teeth a really firm clean across the teeth to remove anything in between ... this is especially important if you've been sewing with metallised fabric or thread. If the teeth are nice and clean, check if they are still pyramidal with a reasonably 'sharp' point facing backwards - if the machine is very old and very well used, the teeth might be rather rounded and it may be time that you have a new feed dog fitted ... some of the old machines are difficult to obtain spares, but they're mostly still out there. Most commonly, check how far the teeth of the feed dogs protrude above the stitch plate ... this is a bit difficult to do and should really be done with a proper gauge, but generally they should protrude 1mm above the stitch plate - less than that and you wont get the material to move properly, especially if its fine material. Lastly, it could be the foot pressure that's the problem ... if there's inadequate foot pressure, the material will not be pushed adequately onto the dogs. Again, unfortunately, you really need a proper gauge to set the foot pressure, but if the dogs are clean, in reasonable condition and have 1mm of clearance above the stitch plate, you can try increasing the foot pressure a bit. This is done by opening the top cover and you will see a large-ish flat-blade screw in a threaded tube just behind where the needle bar goes up and down and to the left of the takeup arm. If the screw is rather near the top of the threaded tube, you can try screwing it down (clockwise) maybe 2-3 turns to see if it makes a difference ... of not, dont be tempted to just keep screwing up the pressure ... there's something else wrong. Oh .... and by the way .... before you've done any of the above, I assume you've checked that the feed-dogs are not dropped ! You can drop the feed-dogs to do embroidery etc on the 830 - there's a small round knob below the stitch length control - make sure its turned to the position that shows a tooth pattern and not the cross-hathced pattern and make sure the feed dogs do actually come above the stitch plate when turning the handwheel - if they dont, or moving the feed-dog drop control doesn't make any difference, then the link mechanism is almost certainly jammed (really, really common on old machines that haven't been regularly maintained!). To free that off, you need to remove the free-arm cover and look to the front right side of the mechanics - you'll see a linkage that should turn when you rotate the feed-dog drop control - if this doesn't separate or is permanently separated, whatever you do with the control, you need to give it a drop or two of Bernina sewing oil and gently help it move - once free, that should solve the problem. I cant think of any other reasons !!
Hope that helps !
Nov 16, 2011 | Bernina Sewing Machines
Feeddogs on a bernette 720 sewing machine do not advance the fabric
Open up the door for the bobbin case and look inside to the right you will find a silver lever make sure that is pressed in this will allow for you feed dog to rise about the plate(it will give you sewinfg mode)
Apr 19, 2010 | Bernina Bernette 75
Sewing Machines Logo
334 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
