Question about Whirlpool LSR7333 Top Load Washer
Whirlpool Model # LSR7233BQ2 Washer top load...How many cubic feet is it?
It's a 17 year old machine and I need to buy a new one. I want to buy one that is bigger, so I need to know the cubic feet of the inside tub (capacity)
SOURCE: Whirlpool Inglis IP44002 Top Loading Washer
What I tried was pushing the lid down and I could hear the machine trying to kick into a spin so then while pressing the lid down i rotated to cycle knob slightly ahead and the spinning started. So I geuss I need to fix the connection between the lid and the machine?!
Posted on Dec 21, 2007
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
App King
  • 55 Answers
SOURCE: Whirlpool Ultimate Care II LSQ9564J Top Load
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
Posted on Jul 22, 2009
SOURCE: whirlpool ultimate care II top load skips agitation turns
I have the same problem, and i think it is a problem with the agitator i pulled mine off, (remove softener insert below that is a seal easily removed and then a 7/16'' bolt) seems a 'clutch' mechanism between base and upper agitators is shot.
Posted on Oct 16, 2009
What is capacity in cubic foot?
  • How to Calculate the Capacity of a Washer Tub - About.com Home laundry.about.com > ... > Selecting a Clothes Washer 2016-04-14 · Video embedded · How to calculate the capacity of a washer tub ... your washing machine ... listed in cubic feet. A regular capacity machine is between 3.1 ...
  • Washer buying guide - CNET www.cnet.com > Appliances > Washing Machines 2013-09-12 · Washer buying guide. ... They have a smaller wash capacity, averaging at 1.5 cubic feet, ... What washing machine capacity do I need?
  • Washing machine capacity in cubic feet ... - Yahoo Answers https://answers.yahoo.com/question/index?qid=20121014130558AA2ph3V
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2012-10-14 · Washing machine capacity in cubic feet what does this mean? ... What does DOE stand for in regards to a washing machine's cubic feet?
  • Washing Maching Buying Guide - Warners Stellian ... www.warnersstellian.com/washer-buying-guide washer buying guide: ... Most conventional top load washers range between 3.2 and 3.5 cubic feet. ... The majority of washing machines are 27? wide, ...
  • What Should I Know About Washing Machine Capacity? www.wisegeek.org/what-should-i-know-about-washing-machine-capacity.htm What Should I Know About Washing Machine Capacity? ... A load of synthetic fleece sweaters will take up many cubic feet while not weighing as much.
  • What is the cubic foot capacity of my Kenmore washing ... www.shopyourway.com > Manage My Life > Questions 2009-09-21 · What is the cubic foot capacity of my Kenmore washing machine, model number 110.82984110? Report This by Manage My Life. September 21st, 2009.
  • Geeks On Home: What Is the Standard Cubic Feet for a ... www.geeksonhome.com/info_12199449_standard-cubic-feet-washer-dryer... What Is the Standard Cubic Feet for a Washer & Dryer?. ... What Is the Water Capacity for a Washing Machine? How to Measure Cubic Feet. How to Find the Capacity ...
  • Geeks On Home: Washing Machine Capacity Guide www.geeksonhome.com/info_12116692_washing-machine-capacity-guide.html Washing Machine Capacity Guide. Washing machines turned the chore of washing clothes by hand into an ... They typically have between 3 to 3.8 cubic feet of washing ...
  • May 04, 2016 | Washing Machines
    How large is the drum in this washer? I'm buying a new one and want to get one as large as my old one.
    Get online, Type in the name brand and model number and hit enter. the should be relevant details about the product think there in cubic feet.most are around four i think. Hope that helped
    Sep 21, 2013 | Kenmore 26882 Top Load Washer
    I am looking to buy a used 4 year whirlpool duet washer and dryer. Do you need transport bolts to move either? Also what capacity is the washer and dryer
    The transport bolts are required to be installed before transporting the machines. This is to support the suspension system to prevent damage to the machines during transportation.
    The washer has a capacity of 9.0 kg or 19.8 lbs with a volume of 3.7 cubic feet. The dryer's capacity is 7.0 cubic feet.
    Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    How many cubic feet are in the Kenmore Washer Model 110 80 series
    The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
    Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    What cu. ft. size is my Whirlpool top loading washer model # LSQ9549LWO?
    hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
    Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Trying to figure out Cu. ft. capacity
    hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
    its not that important for a top loader, but when going to a front loader thats how they rate them.
    what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
    what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
    if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
    the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
    now be ready as the new washers will cost about 1,000 bucks.
    another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
    good luck and happy shopping.
    p.s. remember sears will match prices and give you 10% off the best price!!
    Jan 30, 2009 | Kenmore 22422 Top Load Washer
    How many cubic feet (what size) is my fridge?
    Need the cubic feet on our 16 year old Amana BX22A2W.
    Jun 23, 2008 | Magic Chef CTF2125 Top Freezer...
    Whirlpool LSR7333 Top Load Washer Logo
    250 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
