Question about Garden
Exhaust is suddenly loud, could it be just a muffler gone bad and is there replacable baffles?
  • 32,281 Answers
Yes the muffler needs replacing, you cannot replace the baffles in the muffler as the muffles is welded together.
Posted on Jan 10, 2013
Why am I having such loud exhaust all of the sudden and very bad chugging?
muffler 's silencing plates or damaged or clogged . let it check by muffler mechanic .
Apr 06, 2016 | 2002 Chevy Impala - 3.4L V6 - Electric...
Why does 2006 nissa sentre SE-R SP 1.8 L make a loud exhaust noise? is it just a muffler?
It could possibly be a baffle in the muffler that is causing it to vibrate with acceleration from the engine, or even a exhaust leak from a connection that broke or the gasket has failed. The catalytic convertor might also be the culprit. I would take the vehicle into a shop that specializes in exhaust work and let them put it up on lift to see whats actually going on.
Jun 04, 2014 | 2006 Nissan Sentra
Loud rattleing from exaust
Rattling from exhaust indicates a failure or parts. Check that the cat converter is in one piece and not collapsed . Check mufflers for holes where the baffles inside are spot welded indicating loose baffles. Check for loose /rusted mounting brackets. Check for broken pipes and manifold fittings.
Sep 22, 2013 | Lincoln Town Car Cars & Trucks
There is a loud metallic rattle/clacking noise coming from my exhaust after the bikes engine is hot, basically after riding for 15-30 mins when I crack the throttle at a complete stop in gear or in...
Sounds like the baffle is loose inside the muffler and when it heats up and expands you get movement. I would remove muffler when its cool and try to shake it and inspect it closer. May need a new muffler.
Sep 08, 2013 | Motorcycles
I want more sound from my pipes (australian specs).. how do i knock the restrictions out of the mufflers?
If you remove the baffles from your exhaust pipes the ignition timing and tuning will need attention or it will run rough.
I find it best to buy Screaming Eagle pipes or Slash Cut pipes, they have the correct resistance for backpressure but are very loud!!!!
If you wish to remove the baffles, the procedure will depend on the design of the pipes. There is usually a "pop" rivet somewhere underneath them that if you drill it out the baffles will pull out.
In the UK they fail their roadworthyness test if they have no baffles.
Loud pipes save lives, ride safe!
Nov 28, 2010 | 2000 Harley Davidson FLSTC Heritage...
We have a 2002 nissan altima that has started making a loud rattling noise. There appears to be two rings loosely hanging on a flexible portion of the exhaust.
Just take it into the exhaust people and they will rehang it with new surports plus the muffler might have baffles broken .
Oct 02, 2009 | 2003 Nissan Altima
Exhaust Noises
well, check mounting bolts at cylinder heads(black soot is a sign of loos bolts or bad gasket, the connecter clamp at muffler if it has one, and if all looks well, the baffels inside the muffler may be loose or rotten
Jul 09, 2009 | Yamaha YZF-R125 Motorcycles
Noise from mufflers
It could be the exhaust baffles inside the pipe have given away from its spot weilding whn new, this is due to rust and off course usage.
Try to kick the exhaust pipes (gently and see if theres the same kind of nosies you get when you ride and cruise.
May 24, 2009 | 2000 Yamaha XVS 1100 Dragstar Classic
Still loud
Have you checked the flex pipe section under the engine, and the gasket between the manifold and cat/flex pipe section? Those are two places they usually start to leak from either a blown gasket, or the flex section rusts out under the protective covering.
Mar 24, 2009 | 1998 Saturn SL
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
