Question about Electrolux EI30EF55GS Electric Range
Oven not heating properly
My model number is EI30ef55gsa, and had been working perfectly.The oven takes longer to preheat and never reaches 350 degrees, but the warming oven works and the burners work
  • Electrolux Master
  • 8,220 Answers
Sensor
must read 1100 ohms at room temp. If open or shorted that is yer probo. Could also just be a greasy quick connect not making a good connection.
Posted on Jan 10, 2013
4 Suggested Answers
SOURCE: frigidaire electric range oven and top burners wont come on
It sounds like you only have one side of the 220v current coming into the range. I suggest checking the outlet feeding the range for proper power. The problem could actually be in your circuit breaker, only sending power via one of the conductors.
Posted on Mar 12, 2009
muffteck
  • 202 Answers
SOURCE: oven will not turn on unless over 450 degrees.
thermostate bad
Posted on Mar 27, 2010
SOURCE: Loud pop when I was baking with the oven on Convection bake
Did you resolve the problem with your stove.
Mine just did the same thing.
Posted on May 05, 2010
Whirlpool gold oven
One must preheat the oven to the desired baking temperature. If the oven is turned on and the food immediately put in to bake, it will take longer to bake the first batch than the second and subsequent batches, because the oven need a few minutes to heat up.
In other words, the oven isn't at 350 degrees the instant you turn it on. It takes about 15 minutes for the oven to reach 350 degrees. I hope this helps.
Jan 20, 2014 | Kitchen Ranges
Frigidaire gallery stove
Hello Debbie - Sounds like the unit has loss some of its heat inside of the oven cavity. This means it cannot reach the proper preheat temperature in the programmed 30 minute timeframe. A technician would be required to further diagnose this concern. They would most likely assess the convection heating element, thermal cutout, thermal oven sensor and all wired connections for repairs. Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat. At t his time, I would recommend contacting a professional to assist you further.
May 24, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
JSP26GP code f3 then f2
What is the complete model number of the unit?
Dec 08, 2012 | GE Kitchen Ranges
My oven seems to take a really long time to preheat -- about 20 minutes to reach 350 Fahrenheit. Is that how long it is supposed to take? Thanks
That would seem to be longer then normal...
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 04, 2011 | KitchenAid Ovens
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Oven does not heat but broiler does.
hello mam please visit the manufacturers website there you can find it.
Oct 08, 2009 | Kitchen Ranges
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Maytag advanced cooking system oven does not preheat to correct temperature and fails to reach the correct temperature
Once you put the desired temperature, select a cook time and it should solve the heating issue. Atleast that what worked on mine.
Jul 25, 2008 | Kitchen Ranges
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Electrolux EI30EF55GS Electric Range Logo
112 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
