Question about Maytag Washing Machines
Maytag washer model mvwc200xwo tub drop down
Will not come on and tub droped
  • 142 Answers
SOURCE: My maytag neptune washer model
Your lid switch is bad.
barneyluc
Posted on Oct 01, 2008
  • 36 Answers
SOURCE: maytag washer won't agitate
your transmission is no good and needs to be replaced
Posted on Jan 02, 2009
heatman101
  • 43501 Answers
SOURCE: the tub in my maytag washer will not turn so my
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 28, 2010
vostendorp
  • 347 Answers
SOURCE: My front load washer's tub has dropped down on to
If you are talking about the entire assy. basket and outer tub your support springs have broken,they hold the weight of the tub and basket. For the entire assy. to be laying in the bottom it also had to have the shock absorbers come loose or break..Now if you are saying that the basket is loose inside the outer tub that's much worse than a broken tub support and most likely a rear tub half with bearing assy.You can easily remove the 3 screws on the back of the TOP slide toward the rear and look inside their should be 2 large springs 1 on the left and 1 on the right
Posted on Sep 23, 2010
woodchuck789
  • 4070 Answers
SOURCE: when the washer sits idle, water will drip in the
Your water inlet valve on the back where the water hose connects to the washer is not sealing completely when it's off. It get sediment in it over time and causes this especially if you use well water.You may can stop it by cleaning the valve or replace it. There is one valve for the hot and cold together. There is a screen filter in the water hose where it connects to the water supply.
Posted on Jan 17, 2011
Have necklace stuck between tub and basket of Maytag Centennial low water washer
Visit http://www.maytag.com/manuals/ and type in the model number to find documentation for your washer. Maytag also has a help line at 1-800-253-1301.
Apr 19, 2014 | Maytag Washing Machines
Maytag Centennial topload washer - Model MVWC200XWO. I interrupted a load of wash by pushing the pause button. The lid unlocked, water drained from the drum and the machine makes a humming noise. It...
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board. It's like rebooting your computer. I did this to mine and it cleared up the problem. The capacitors on the board need to discharge to completely depower the board. That why unplugging and replugging right away doesn't always work.
Oct 16, 2013 | Maytag Washing Machines
My maytag neptune tl leaks from the bottom while it washes MODEL #FAV6800AWW it leak about two to three cups of water for each load,about one drop per second.
Possible Tub Seal leak, leak from Outer Tub, Sump Cap, Drain Pump, Drain Line.
You need to pull the front cover off the machine and ID the leak source. If there wash water over the Clutch Pulley I would suspect a Tub Seal issue.
You can't link to the Service Manual form this site.
Google Maytag Neptune load unbalance and see if you can find support for the Service Manual.
Oct 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer leaks on floor while in use .maytag. model # LAT9416AAE
could be pump,tub seal,tub,or a hose. to find leak remove the 2 screws at bottom of front cover and pull out and down after removing the cover you should be able to locate leak. I don't advise trying to replace the tub seal unless you have a lot of time and patience.
Feb 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
Problem with Maytag Washer
Sounds like belt or bearing failure. Possible motor break down. Usually rear panel removal for access. Always unplug unit. Inspect workings for failure. Belt tight, tub turns freely. Usually the motor is the culprit. Tub removal is rarely needed. Search online for specific washer layout.
Jul 10, 2009 | Washing Machines
My maytag top loader washer won't spin but agitates,what is the problem
Maybe a sock stuck between the two tubs. If it has not dropped down too far you maybe able to feel it. Open the lid and pass your fingers gently between the two plastic tub covers. The lower cover moves with the inner tub while the upper stays still.
Jun 21, 2009 | GE WBSE2090A Top Load Washer
Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Mar 10, 2009 | Maytag MAT13MN Top Load Washer
Installing damper pads on a Maytag a710 washer
by damper pads you mean three curved felt pads that come in one package.if yes yes i can tell you but it wont be the funnest thing you ever did .on a service call i would complete this job in about one hour,but you have more time than i. had to move on to the next call and did not want to return[to let glue dry enough and then reassemiable]here goes older maytag two belts under neath! 1 remove front panel and screws from top, so can hinge back. 2 there are three or four big springs that go from tub to floor.next,you need to mark the spot that the nuts are tightened too on those eye bolts that springs are attached too. take black tape and wrap around treads above the nut on the eye bolts so will know where to re tighten too. 3 loosen and undo hose at tub that goes to pump and at top of washer tub where water comes in .4 then under neath the washer remove those nuts that you applied black tape to the eye bolts i thinks 7/16 or 3/8[will have to spin belts off also]now tub should move freely.5 here's the trick,i use a 4'' round pvc coupler on its end and place under neath the washer,center trainee pulley and pull the washer up onto it , this then lifts the whole tub assemblie up so now can get to snubber pads.6 peal off old pads and clean ,glue in new pads and let set for long time[hours],[i did not have that time on service calls so when droped tub back down,some time pads moved]7 when dry add your silicone grease that came with pads.8 put unit back together.now if tub to loose you can tighten those nuts on the eye bolts more,but don't too much because tub dose need to move so the energy when tub out of balance can be transferred to springs and not all the way thru to the bottom deck,which would happen if springs to tight.i hope this helps God bless ,tom.....ps the glue l used for pads was the same glue i use for dryer felt seals.that glue came with the felt seals so i always had it around[free] im not sure which glue to advise you to use,but needs to be good stuff,tom.........also if i have been helpfil please remember to help me with my ratings
Jan 06, 2009 | Maytag Washing Machines
Maytag washer repair
I had the repair guys out 3 months ago maytag paid for labor I paid $150 for seal and bearings, tub froze and belt broke. the tub now is making the loud screams that others complain about I contacted maytag and reapir servce and talked with the tech. this machine is a piece of S$%^ the seal fails on a regular basis and bearings get water in them. I just missed my 3 month waranty and will not pay for that repair again. people at home depot agree that this machine is trouble. the machine must be taken completely down from the top to replace the bearings and or the belt. the tub must be removed. If you call maytag they will pay for the labor but not the parts.
Jan 06, 2008 | Maytag Legacy Series Top Load Washer
Maytag Legacy Series Leaking
I have the same problem as many other Maytag owners of this model machine have. I spoke to a repairman and he told me to "junk" the machine. He said the cost was about $300 to $350 to fix and he WOULD NOT guarantee his work on this machine. He said that Maytag knew of the problem but refused to do any sort of a recall.
My solution:
1. Buy another machine and junk the Matag
2. Tell all your frends and neighbors NOT TO BUY MAYTAG...
3. Drop the old machine off on the MAYTAG door step.
Nov 25, 2007 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
