My panasonic Dvd players continues to stop (it says pre stop). I then press play n it runs again, but then stops again. This goes on n on. Sometimes it jumps to the start again.
    Problem Solver:
  • 11 Answers
Panasonic Dvd players optical pickup lence S.L motor HIi ohms pleace rereplace S>L motor also S.P motor replace now
Posted on Jan 10, 2013
SOURCE: Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Posted on Dec 26, 2005
  • 81 Answers
SOURCE: DVD S1000 video player
A new Laser pick up will fix your problem expencsive repair
Posted on Dec 15, 2006
praky16
  • 744 Answers
SOURCE: DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
Posted on Jan 21, 2009
TEKUSER
  • 86 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
  • 25 Answers
SOURCE: DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Posted on Feb 18, 2010
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
Pre Stop Issues
what kind of DVD u r trying to play it it exactly?
Jun 17, 2008 | Durabrand PDV-705 Portable DVD Player
Player shutdown and then go to self check
unit goes in to self checking over and over dvd can not be ejected and will not function at all?
Aug 05, 2009 | Panasonic DMR-E55 DVD Recorder
The machine stops and goes to self check
This problem was solved by Randychev. Do a little searching for his solution. It worked for me but on a diferent set of capacitors. I went to Radio Shack and replaced the bad parts and the problem wos fixed. He even gives you pictures to explain what to do precisely. Good luck!
May 16, 2009 | Panasonic DMR-E85H DVD Recorder
Jan 21, 2009 | Televison & Video
Re: Panasonic Remote Control for DMR-ES35V
All you have to do is unplug the power cord from the unit, wait 10 seconds, and plug it back in. The reboot will make your remote work again. Actually, it is the UNIT that is faulty, not your remote.
Jun 25, 2008 | Panasonic DMR-ES35VS
Movies stop
I had that same problem, Just purchase a cd lens cleaner and it worked like a charm. Seriously. then you can use it on any cd application!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jan 16, 2008 | Memorex MVD2042 DVD Player
Won't format and or won't read disc
I have a similar problem in that it will not record at all or not record very well.  It has a drive inside like a PC DVD drive called the DVD RAM drive. The horrible clunking (grinding) sound is the disc slipping in the spindle. Unfortunately here in Australia the fix is to replace the whole drive (AU$350)!!
I have opened it up and tried to adjust the force of the spindle and it works for a while.
Hope somebody has a better solution.
Dec 03, 2007 | Panasonic DMR-ES10 DVD Recorder
Not reading pre-recorded dvd's and ocassionally not re-wrtten dvds
Over recent months my recorder has stopped reading pre-recorded disc's and more requently re-writer disc's. I had thought that the region had some how been altered, but not too sure now. Is there a way of checking? Or is there a problem with the laser block. I have stripped the machine down and thoroughly cleaned (but no dust found) and no loose parts. I have reset to manufacture default but this hasn't helped.
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Guest, posted on Dec 19, 2007 DVDR70-051 recorder functions generally becoming more and more erratic. DVD-RW discs I have recorded sometimes say 'disc error' sometimes 'no disc' sometimes start ok but cycles round and round for 5 - 10 mins before stopping, sometimes goes straight into play at last position, won't stop back in menu just goes straight to stndby. Factory reset dosn't help. Wont play pre-recorded discs without going into menu and messing around. It seems to damage or not record RW discs properly a lot of the time. Not even sure if it's resetting to factory settings properly.
Oct 28, 2007 | Philips DVDR70 DVD Recorder
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
