Question about HP Pavilion Computers & Internet
Where can i purchase a ws12101 motherboard - Pavilion HP Computers & Internet
  • HP Master
  • 27,725 Answers
2 Suggested Answers
maxcarson
  • 7627 Answers
SOURCE: Can a fried motherboard be fix.Number on mobo is WS12101
I suppose, most likely cheaper to replace the Mobo.
Posted on Jan 10, 2013
Computer power on but no beep,no amber light only power light and the fan works,what's wrong.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Jan 10, 2013 | HP Pavilion Computers & Internet
I have no motherdisk
Hi, the Motherboard Driver Disc is provided with the purchase of Motherboard for the AMD Sempron 2500 Processor and not for the purchase of AMD Processor. Please purchase any Asus Motherboard supporting AMD Sempron 2500 Processor to get the Driver Disc. var geo_Partner = '843689b9-ba30-459d-9c4b-876924715b22'; var geo_isCG = true;
Jun 11, 2011 | AMD Sempron 2500+ (1.75G) Retail Box CPU...
Can i fit a bigger processor to my ASUS K8V-MX Motherboard and mybe more ram and if so where can i purchase it from
This motherboard supports a AMD Athlon 64 / Sempron processor (Socket 754). Since this is an older unit you will have to search on Ebay for a processor.
As for the RAM you will need DDR 400, this can easily be purchased at www.newegg.com There is a maximum of 2 gb on your motherboard.
Mar 17, 2011 | ASUS K8V-MX Motherboard
Compac SR2011WM motherboard
replacing the mobo is much cheaper that to purchase a new computer but purchasing a new computer is much better than replacing your mobo. because in the near future, you need to upgrade your system for better use.
Mar 29, 2010 | Computers & Internet
Where to purchase a ( pwa-7521+_m)) motherboard
You are probably out of luck. Those boards are made in batches of 1M or so, and when they are used up, the next generation is made.
Feb 13, 2010 | NEC Laptop Motherboard (1580262530)
Intel motherboard
Intel gives 3 years warranty with every new motherboard purchased. If you have purchased this motherboard during this 3 year period then you are eligible for a free repair or replacement.
To claim, just take your board back to where you purchased it. They can take care of the rest.
Thank you.
Oct 13, 2009 | Intel Desktop Board D845EPIL Motherboard
Where can i purchase a new 915p-m3 motherboard from a phillips freeline
HI...
You can purchase 915-m3 motherboard through online. Visit the ebay website and search the model and brand name.
Regards
PCmania
Sep 04, 2009 | Abit 915P (AG8) Motherboard
My motherboard (M/b intel 945 Gccrl Oem) is not working due to the problem of no display. I had purchased it from computer empire at nehru place on 10TH may 2007. so,please take some action towards my...
Your motherboard's warranty expired.
You need to repair it by own and if you don't want just purchase VGA card for the same. it cost you around 1000-2000 INR.
May 15, 2009 | Intel D945GCCR Motherboard
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
