Quiero programar mi remoto rca para mi tv seiki y no se el numero me los puede conseguir
5 Suggested Answers
  • 325 Answers
SOURCE: necesito los codigos para programar el control
Sharp 011,020,025,027,037,052,053,059
cheers
Little Dish Fitter
Posted on Oct 11, 2009
  • 31 Answers
SOURCE: PERDI LOS CODIGOS DE MI CONTROL REMOTO. AHORA
4001, 4023, 4048, 4158, 4228
Posted on Mar 18, 2010
  • 8 Answers
SOURCE: tengo un control de sony RM-YD014 quiero el manual o el codigo para programarlo otra ves a mi televizor
REMOTE CODES & PROGRAMMING INSTRUCTIONS RM-YD014 The RM-YD014 remote control is not programmable and remote codes are not required. This remote is designed to control the product that it originally came with. If the remote has buttons for other product types (TV, DVD, etc.), it can control only Sony branded versions of these products. Please note that this remote may not be able to control all models of these other Sony product types.
Posted on Jun 12, 2012
gopakumarg43
  • 74459 Answers
SOURCE: C?digo para el tv Panasonic plasma mi control es general el?ctrico RC 94925
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Jan 13, 2017
Como programar tv vizio a control dish
Estimado Chuy, primeramente le quiero pedir una disculpa por responderle tan tarde, estoy consiente que en este momento posiblemente su control ya este programado a su televisor. De cualquier manera quiero tomar el tiempo para proveerle los pasos y codigos a programar el control, puede ser que en un futuro los necesite. Para programar su control ala t.v hay ciertos codigos que permiten que el control se programe a las funciones de la t.v. Los codigos para una t.v Vizio son 627, 505 y 506 Oprima el boton transparente de T.V localizado en la parte de arriba del control por 5 segundos hasta que los demas botones se iluminen en rojo, una vez se iluminen ingrese un codigo seguido por el signo de numero por ejemplo: 627#, luego el boton de 'Record' 3 veces (es el boton ***** con un punto rojo) una vez haga esto vera que el boton de t.v se iluminara 3 veces. Esto debera programar el control a su t.v. Si necesita ayuda puede contactarme directamente a kimberly.escobar@dish.com. Gracias por su tiempo.
Jan 06, 2012 | DISH Network IR Remote Control
Como puedo programar el control de dish para mi televisor panasonic si no tengo los codigos
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle proveendole la informacion que necesita. Unos codigos para la television marca Panasonic que se pueden integrar al control serian los siguientes: 685, 512, 738, and 876. El procedimiento es el siguiente: oprima el boton de T.V localizado en la parte de arriba del control hasta que los demas botones se enciendan en rojo una vez esto suceda ingrese uno de sus codigos seguido por el signo de numero por ejemplo 685#, el boton de T.V debe de iluminarce 3 veces despues de esto puede tratar de usar su control con la T.V y deberia funcionar. Si necesita ayuda programandolo este link le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup tambien me puede contactar directamente a mi correo electronico a kimberly.escobar@dishnetwork.com Gracias espero que esto le sirva de ayuda.
Nov 19, 2011 | DISH Network IR Remote Control
Como puedo programar una tv samsung con el control de dish
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
Kimberly Escobar
DISH Network
Aug 07, 2011 | DISH Network IR Remote Control
Los pasos a seguir para progamar el ontrol dish al televisor? y los codogos para el tele RCA
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle y proveerle la informacion que necesita. Para programar el contol de DISH Network a su T.V el procedimiento es el siguiente: Oprima el boton de T.V localizado en la parte de arriba de su control hasta que los demas botones se enciendan en rojo, una vez encendidos ingrese el numero de codigo que tenga para la marca de su televisor seguido por el signo de numero (#) el boton de T.V debe de iluminarce 3 veces, despues usted puede intentar usar su control y deberia funccionar. Los codigos que puede programar a una television marca RCA serian los siguientes: 503, 020, 633, 805, 725 y el 627. Si tiene algun problema me puede contactar directamente a kimberly.escobar@dishnetwork.com este link tambien le puede servir de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui puede encontrar mas codigos y ayuda en como programar el control. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Mi caja convertidora es zenith y quiero programar el control de la caja convertidora con mi television zenith
como puedo conseguir el control remoto de mi caja covertodora se me descompuso y no puedo programar mi senal
Jan 30, 2011 | Abt Television 1745 Remote Control
No se como progamar mi control remoto de Dish Network por que mi televicion es marca Emerson pero tiene VHS incluido?
Hola mi nombre es Kimberly Escobar y soy representante de DISH Network servicio al cliente. Tengo entendido que necesita ayuda programando su control de DISH Network con su televicion Emerson, seria mi placer asistirle proveendo la informacion necesaria. Para programar el control con su televicion hay un cierto codigo que se integra al control, permitiendole controlar ciertas funciones en la T.V. No podemos prometerle que pueda funcionar completamente el VHS. Uno de los codigos que posiblemente se integren al control para trabajar con su T.V seria el numero 632, El paso a seguir es el siguiente: oprima el buton transparente en la parte de arriva del control que diga T.V, cuando vea que los otros botones se prendan em rojo ingrese el numero 632 seguido por el signo de numero (#), el boton de T.V debe de iluminarce 3 veces. Una vez acabe con este procedimiento puede intentar usar el control con su T.V. Si tiene preguntas adicionales o necesita ayuda puede encontrar nuestra pagina web muy importante http://www.dishnetwork.com/SupportSection/power-scan-instructions tambien puede contactarnos directamente al 1800-333-DISH muchas gracias y espero esto le sea de ayuda.
Jan 29, 2011 | DISH Network IR Remote Control
Televison & Video Logo
496 people viewed this question
Top Televison & Video Experts
Electro Med Services...
