Question about Brother MFC-J430w Inkjet All-in-One
MFC-J430W I want to register my brother printer on line.
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
GodBlessU
  • 3513 Answers
SOURCE: I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Posted on Jan 15, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Posted on Feb 25, 2010
My Brother Printer MFC-J430W always says "install Magenta Ink" even though it is already installed
reset the engine to the factory. and clean the cupper pins that are on back of cartridge and on the carriage.
Oct 09, 2016 | Brother MFC-J430W Inkjet All-in-One...
Why does brother j430w print while lines in black areas?
This is cause by minor discrepancies in the printhead. Normally this is caused by blocked jets on the inkjet printhead. Depending on the extent of the lines it may only be one jet blocked or more if there are lots of noticable lines.
Try doing a printhead clean to clear the jets and check the print quality printout.
Due to the way these machines print it could also be just as simple as the normal printing discrepancy. These machines are cheap and made that way. If you are looking for solid black in the black areas then you may need to change the settings on the printer to photo quality or replace the cheap brother with a more expensive machine.
Sep 06, 2014 | Brother MFC-J430W Inkjet All-in-One...
How to cancel brother mfc-j430w displaying "cannot detect"?
Try turning off the printer (hold down the on/off button) then restart your computer.
Aug 16, 2014 | Brother MFC-J430W Inkjet All-in-One...
Brother MFC-J430W INK PROBLEM CANNOT DETECT
Exchange it with a different colour and see if the problem moves to the new position. Its the INK Cartridge. If not then its the ink reservoir system faulty
Apr 11, 2013 | Brother MFC-J430W Inkjet All-in-One...
Brother MFC j430W. How do I correct machine error 48?
The print head circuit or cable is malfunctioning or faulty. Replace the printer. I would suggest the Brother MFC-j450dw/j470dw printer as it is an upgraded and newer version of the j430w. Good luck!
Mar 16, 2013 | Brother DCP 165C Compact Color Inkjet...
Error 76 on brother mfc-j430w after clearing paper jam
Please check this out also. It solved the problem for me.
http://support.brother-usa.com/ModelDocuments/Technical/Service%20Updates/SU_F1379.PDF
Feb 18, 2013 | Brother MFC-J430W Inkjet All-in-One...
BROTHER MFC-J430W
how to reset ink absorber full with brother mfc j430w
Jul 17, 2012 | Brother Office Equipment & Supplies
UNABLE TO INIT. 49 (BROTHER PRINTER MFC-J430W)
dear sir, My printer Brother MFC J430 shows unable to clean 49 in display I have found any solve or suggestion in youtube / Google please suggest me.
email. laskarnet2014@gmail.com
BAHAR LASKAR
SILCHAR, ASSAM
Jun 19, 2012 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-J430w Inkjet All-in-One Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
