Ps 2 mouse no driver install
Ps2 mouse not moving is it the driver my problem
  • 104 Answers
Windows has inbuilt driver for all the mouse. YOu dont need to install the driver separately for your PS2 or USB mouse.
The reason why yours is not moving can be
1) Mouse cap/IC gone bad & needed to be changed a new mouse
2) OS faulty (very rare 1 out of 100)
Posted on Jan 21, 2009
How do I connect the mouse?
212
i am assuming you have a usb mouse and a PS2 connection on the computer. If this is the case then you need a female usb to ps2 mouse adapter
So that the mouse cable plugs into the USB female connection and the male ps/2 plug end goes int othe female ps2 port on the computer.
If this is the case you have the wrong converter the chester will convert a ps/2 on the mouse or keyboard to a usb on the back of the computer.. Can you tell us what sort of mouse you are trying to connect does the end of the cable have a usb plug on it a bit like the blue usb plug in your picture.
Google it and see the difference.
Mar 12, 2015 | Chester Creek PS/2-USB Converter PS/2 to...
I have an usb adapter for old ps/2 keyboards, which I tried using for the Dell SK8110 Keyboard. But unfortunately, my laptop needs to install this keyboard's driver for it to function. Any idea where I can...
I think you do not need a driver. Generally ps2 keyboards are detected automatically and work just fine. Still you may go to device manager and un-install the keyboard from there. Then reboot the machine. When it starts again it should detect the modem again.
Note, if you are using a usb mouse please change it to ps2 mouse.
Jan 18, 2011 | Dell SK8110 Keyboard
I have a dell inspiron desktop that has no ps2 port, only USB. From my older computer I would like to use my microsoft ergonomic keyboard that has a ps2 plug. I bought a PS2 to USB adapter but when I...
The adapter you purchased is for use with a PS/2 mouse only. The only keyboard adapters will have keyboard and mouse in a "Y" adapter. The single adapters will not work for keyboards because they do not have the conversion electronics to go from PS/2 to USB, mice can work on either one. Do a google search for "usb to PS2 dual port adapter" you can get them for around $2 plus shipping.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 23, 2010 | Computers & Internet
Driver for PS/2 compatible mouse for tower PC HP compaq dx7300 were not found and not installed in my PC.
PS/2 compatible mouse drivers are generic drivers already install when the Operating System to your PC. You don't need any extra PS/2 drivers!! "
Check your mousePS/2 pins & PS/2 socket -> Pins..Dented..Broken?
Mouse could be faulty. Try replacing another PS/2 mouse to your PC.
If the PS/2 socket is faulty, you can use a USB mouse too.
Hope it helps.
"Courtesy is free but it will carry you forward a long way in a lifetime!"
Nov 07, 2010 | Computers & Internet
Won't move anywhere on the screenhow do we know if we need to replace the mouse
Is it a wireless mouse? If so you may need to replace the batteries and re-sync it with the receiver unit. If it is a chorded USB mouse you may want to try a dif. usb port and see if that works. If it is a PS2 mouse you may need to replace it.
Usb - Flat square shape
PS2 - Small round shape.
Jun 19, 2010 | Compaq PS/2 3 Button Optical Mouse...
How do you turn off a PS/2 compatiable mouse (touch pad) Cant do this in control panel or uninstallng driver in device manger.
If it can't be done in Control Panel you most probably will have to disable it in the BIOS.
Nov 02, 2009 | Computers & Internet
I can't install vista any mouse or keyboard detected
Often times this happens when using a USB keyboard / Mouse.
Or when using a USB keyboard through a PS/2 Converter.
Try using a PS/2 Keyboard if available
(Small Round connector with a small amount of pins, similar to a S-Video connector.)
Also. Access your BIOS settings and assure that you have Legacy USB keyboard support.
Depending on your computer the BIOS / Setup Menu / Options Menu/ Etc. can be accessed by pressing the following key during boot:
F1
F2
ESC
DEL
F12
Let us know your setup(KB and Mouse Port type), and if you have any other issues.
Good luck
Apr 14, 2009 | ASUS P5V800-MX Motherboard
Mouse wont work
You mouse does not work? First few things I would check is make sure your mouse is plugged in all the way if its a ps/2 style mouse check to make sure none of the pins are bent ps/2 style is round. If your mouse is usb try moving it to another usb port also make sure the mouse drivers/software is installed
Aug 12, 2008 | E-Machines etower 500is PC Desktop
USB mouse not recognized
I have similar problem. 2 inland KVM's (both have PS2 inputs, one has USB outputs) do not light or recognize my usb mouse with a PS2 adapter. They do recognize a PS2 ball mouse on the KVM's however. One of the computers (Sony vaio 1.5 GHz) does recognize a usb mouse with adapter on 2 other KVM's (Old Belkin and a Trendnet) (the second computer I have not tried in those configurations). Next I will try an optical mouse with a PS2 fitting. That did work with a fifth KVM at an auto business last week.
Feb 18, 2008 | Dell (582RR) 16-port KVM Switch
Computers & Internet Logo
612 people viewed this question
David Payne
David Payne
