Question about Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer
Replacing the Door Bellow on Kenmore Elite Front Loaders
I need to replace the door bellow on a kenmore elite he4t washer
  • 314 Answers
Hi. Open up the back of the dryer after unplugging it. Take a deep breath. This is not that hard. A dryer is a very simple thing but you need to relax and figure out what the parts are. A dryer has a very basic parts list. The obvious I will not go into with but here goes with the electrical in the guts of the machine. A motor to turn the drum. A heating element. A sensor to sense high temps for safety shutoff of the element. A blower for air. Keep in mind as you look at this that usually power wires are black or red. You will see some wires that are attached to a sensor and then on to the heating elements. Take a test light or volt ohm meter and see if the high temp limit sensor is bad. This can be a simple ten dollar one from Radio Shack. That is, it will it get continuity through it. You may have to detach the wires on this sensor to do this test. The sensor is usually a flattened round disc with two leads coming out of it. Test the element same as the sensor. Take the part where there is no continuity through them to the appliance parts store with the model and serial number of the dryer for appropriate parts. Maybe ten bucks. I know it sounds scary but you may learn something and if all else fails just pickup the phone and call the repairman. Hope this helps.
good luck
please rate thes
Posted on Jan 10, 2013
  • 2 more comments
  • Dean Hutto Jan 10, 2013
    Thanks for responding, but I needed help replacing the bellow on a front load washer, not the dryer. I really appreciate your attempt to help me.
  • adelani muazudeen Jan 10, 2013
    okay what is the main problem
    I wam looking for clarification on the process. I've searched and found two different methods. One that is saying you need to disassemble the top, remove the door and so on and the other it appears as though it can be done from the front. I have the new bellow already. One of the instructions talks about making sure that the new bellow is exactly lined up. Sounds a little intimidating. Ay ideas?
    okay these process is not much easy like that just give me your email address and reply the question.dont forget to rate these
Bellow for Kenmore Elite front-loader washer
The Bellow should be available at a appliance part store. be sure to call with the model number and serial number, that way if they don't have it they will have time to order it.
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
Boot rips
The door bellow on front loaders do wear out and require replacement. However, overloading the washer can contribute to premature wear or rips and tears due to items getting caught in the seal. If the bellow is ripped, it will require replacing or the washer will leak. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The door seal in my kenmore elite HE3 is ripping...is it replaceable?
Yes, it is. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Nov 17, 2009 | Kenmore Elite 45986 Front Load Washer
Replacing the rubber seal on the door
The following link explains how to replace the door bellow on a Kenmore Elite front loader:
NOTE: Review some of the testimonials as well. One user (DGBG) offers a quicker way of replacing the bellow if you're willing to give it a try.
Oct 06, 2009 | Kenmore Elite 45986 Front Load Washer
Door seal tangled in wash load.
It sounds like one of your retaining clamps may have come loose or something sharp may have snagged the door bellow and pulled it loose. You will need to inspect the bellow for any potential rips or tears and ensure the front and rear clamps that hold it in place are still intact and useable. You may be able to simply reattach the bellow and won't require parts. The following link explains how to replace a door bellow and lists the steps required for accessing and installing the clamps:
This isn't difficult, but it can be tedious. If you require replacement parts, you can order from any of the following web sites:
repairclinic.com
The part numbers for Kenmore Elite are as follows:
Door Bellow: 8181850
Front Bellow Clamp: 8182211
Rear Bellow Clamp: 8182210
All these sites offer great service if you determine you need parts. Shop around for the best prices.
Sep 03, 2009 | Kenmore Elite 45986 Front Load Washer
Tub seal relacement method
The following link explains the step-by-step procedures for replacing the door bellow on a Kenmore Elite HE3:
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Jul 16, 2009 | Kenmore 44072 Front Load Washer
Kenmore elite duet 410 metal wire for gasket came off
is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 door bellow
he 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
