Question about Konica Minolta 7020 7022 7025 Copier Drum & Blade
Fns convenyance Keeps saying close fns convenyance
  • Konica Minolta Master
  • 1,297 Answers
Clean the side door sensor,verify the electrical circuit to door sensor,you dont have +5V to activate the sensors cable intrerupt.
Posted on Jan 30, 2013
Tip
Changing from a Pentair FNS DE Filter To A Pentair FNS Plus DE Filter
If you are the proud owner of a Penatir FNS DE filter, it may be nearing the time when you will be upgrading to a new filter. Since your first filter has probably been a great performer, you will be considering keeping the same brand of filter.
Ironically, since Pentair is trying to do away with the FNS filter, you may find that the FNS Plus is actually more affordable, and with the minor changes that have been made, is a an even better filter.
So, how do you avoid costly plumbing expenditures in changing out this filter? The FNS actually has the bulkheads (the connections where the backwash valve union nuts) that sit 1/4" lower than the standard FNS filter. In order to avoid having to change the plumbing for the backwash valve (although it is always recommended you change the valve when you install a new filter), you need to bring the filter up that 1/4" to make the bulkhead fittings line up.
Pictured below is a filter and the two kinds of valves that are used with the filter. On the left, the two black "dots" on the front of the filter are the bulkheads. On the right, you will see the two connection ports that the valves use to connect to the filter. Either valve works with this filter (i.e. multiport (left valve) or standard push/pull (right valve).
When changing the filter you should need only a large pair of channel locks and some lube. The other important component is a 18" X 18" Ceramic tile. When you install the new filter, first lay down the ceramic tile. This will make up for that 1/4" difference on the bulkhead location and ensure that your filter lines up with your valve! Thats it...no additional plumbing required.
Always remember, before you attempt to do any installation on your own, with anything you are unfamilar with, do your best to find the people who have been doing this for awhile. These little tips and tricks will make the job much easier, and save some aggravation!
The Ugly Pool Guy www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
Help "Closing" Conveyance Door
Their is a switch letting it know that it is not closed.
find the switch and either adjust it so it closed the contacts ,when the
door is closed,. or temporarily jump it out to confirm that it is the switch. Sometimes switches can be shimmed up with tape etc.
Jun 03, 2014 | Konica Minolta Konica 7020 W/fax Kit...
How to backwash purex triton fns pool
fns sounds like cartridge have to take out and clean if no backwash on a multiport
Jan 11, 2014 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
I got a pool with a fns plus 60 DE filtering system thats depositing diatomaceous earth all over my pool.Took it apart cleaned the grids bought 2 new ones to replace the bad ones,put it back together...
The FNS PLUS was originally built by American Products under a different name and was absorbed into Pentair's line, recently replacing the PAC-FAB FNS (fiberglass nautilus) also absorbed by Pentair. The two filters have no common background.
The FNS PLUS has been cursed at by more pool techs than I can count. All I can say is practice helps but these are always a pain to get right. Make sure that the narrower of the elements is in the correct spot, the rest do not matter. Also check the manifold on all sides for cracks and make sure the air relief screen is set properly. I wish I had an easy solution for you, but this filter is just a pain, even for the guys that work on them every day.
Aug 23, 2013 | Pool & Spa
Fns plus vertical grid de filter plumbing diagram from pump
the front is the inlet from pool the top is out and goes into the filter the filter out goes to the pool returns
Dec 30, 2012 | Pentair Fns Plus 48 sqft De Pool Filter...
Please close FNS conveyance door
Aug 31, 2009 | Office Equipment & Supplies
Konica Minolta 7020 7022 7025 Copier Drum & Blade Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
