Question about InFocus X6 DLP Projector
How can i remove white (sand-like) spots on the scren of my infocus x6 dlp projector
The white spots increase everytime that i use the projector pls anyone can help me
micromaster
  • 3614 Answers
SOURCE: iNFOCUS LP 425 DLP PROJECTOR PROJECTOR
try to restart the pojector & the pc, &
check the connection of the projector, some projector needs to warm up before it goes to work..
Posted on May 17, 2008
jackboy
  • 2985 Answers
SOURCE: Red Spot in the picture of my Infocus LP-820
This would appear to be a componeent failing and I doubt if it is user fixable.
If it unser warranty send it back whence it came,
Further support try here
http://www.google.co.uk/url?q=http://www.infocus.com/support.aspx&sa=X&oi=smap&resnum=1&ct=result&cd=2&usg=AFQjCNFdFuwQfzBpULQpcHnzxmC_n12fdA
Posted on Aug 20, 2008
projdoc
  • 2237 Answers
SOURCE: infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Posted on Jun 03, 2009
  • 167 Answers
SOURCE: InFocus LP 850 Projector, yellow spot on screen
Unfortunately the discoloration is caused by the extreme heat generated by the Lamp has burned the LCD optical polarization filter/elements.
The only solution for this is to replace the entire LCD optical assembly.
Sorry for the bad news, :(
Posted on Dec 30, 2009
heathgr
  • 442 Answers
SOURCE: My InFocus IN2102EP projector is recently
Sounds like the DMD chip is on it's way out.
Check if the intermittent problem is related to the external air temperature. Try blowing cold air around the unit with a personal fan to see if it does the same thing.
Check if the air vents and filter is clean
Posted on Apr 12, 2011
Model x1. Why does picture have white spots at the top of the screen?
If the projector is a DLP then it will probably be the DMD chip. The white spots are caused by damaged pixels.
Jan 28, 2016 | InFocus Office Equipment & Supplies
Our infocus dlp xga 4000 lumens projector has white spots showing up.
You might inspect the DLP color wheel if you're confident in opening and looking inside your projector.
Jul 15, 2014 | InFocus In5302 Xga 1024 X 768 Dlp...
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
Lamp ballast
www.shopjimmy.com There you can find that out.
Nov 06, 2013 | InFocus X6 DLP Projector
How to change infocus x6 model without remote
try mo po icheck ung lens nyan o kaya po sa cable
Sep 04, 2012 | InFocus X6 DLP Projector
My x6 infocus does not react to the remote control
sometimes there is a switch near the battery or on the bottom of the remotes to disable it. otherwise some projectors have an option in the menu that you need to turn on to be able to use the remote, it should be under IR options
May 11, 2012 | InFocus X6 DLP Projector
THere are an increasing number of white spots (damaged pixels?) on the projection screen. It started with one, and one flickering, now there are 4 clear spots, and another flickers. Can this be solved?
If the spots are well defined rectangular shapes, then DMD pixel failure would most likely be the problem.
You could replace the DMD chip, but it might be more economical to sell the unit as is and buy a new one
Jun 08, 2011 | InFocus IN1102 DLP Projector
There is no sound
HI
Please try replace of audio cord from player to projector.if cord is o.k then some thing wrong with Main boad
Thanks
For
M.R. Mumbai & Dubai
Sep 02, 2010 | InFocus X6 DLP Projector
My InFocus projector is making alot of noise
could be either the colorwheelor one of the fans. checkthe fans for obstructions. otherwise, replace the colorwheel.
Feb 18, 2010 | InFocus X6 DLP Projector
InFocus X6 DLP Projector Logo
61 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
