Question about Whirlpool WFW9050XW Washer Front Load White
WFW9050xw Whirlpool Front Load Washer fills, turns, then stops.
I have a whirlpool WFW9050XW , but without an LED display. On diagnosis, It blinks 8 times then one. In any wash cycle, it fills about halfway up with water, all the while turning, and then it stops and beeps. I press power and it drains and stops, then I do a rinse and spin, and that does that. However, I still don't like that it stops. I checked the hoses were right, drain height and air, the washer is level, the LED indicates the door is locked at the beginning of the cycle. I pressed my leg against the door just before it stopped to make sure it wasn't a door problem. I think it has something to do with it not being able to tell when to stop filling and start washing.
jsrock516
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
  • 85 Answers
SOURCE: Nothing wierd...just no rinse/no spin/no drain with the whirlpool
sounds like you have a bad lis switch asm.
Posted on Dec 16, 2008
  • 99 Answers
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Posted on Feb 06, 2009
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Can't find a manual to figure out were the coupler is
http://www.manualowl.com/p/Whirlpool/WFW9050XW/Manual/92004
Mar 02, 2014 | Whirlpool WFW9050XW Washer Front Load...
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Apr 28, 2013 | Whirlpool Washing Machines
Whirlpool wfw9050xw washer will not finish spin cycle and drain
Pump is cloged. remove 3 1/4inch screws from bottom panel and unscrew the pump cap (it should be a white pump) remove clog and restart cycle. also be prepared for a lot of water so get a bunch of towels. You can try to pinch the black gasket from the pump to bottom of tub to hold water from pouring out. good luck
Feb 16, 2013 | Washing Machines
Washer will not start
Havenison you tried pushing the door in case it isn't connecting .
Dec 26, 2012 | Whirlpool Duet WFW9050XW Washer
Service manual for whirlpool washer wfw9050xw
you can go to appliancerepairplanet.vstore.ca for a manual
Dec 13, 2010 | Washing Machines
Whirlpool WFW9050XW Washer Front Load White Logo
112 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
