Question about Ovens
Readout all of a sudden says E6 and F2 where we usually see the clock/timer/etc. What the heck is going on and how do I clear this so we can see the time display again?
The timer or clock readout display is now stuck on some weird codes or numbers and we can't clear it or have it go back to just showing the time/clock. What can I do to troubleshoot or is this some weird code telling us to clean the oven or what?
  • 4 Answers
Yup Yup, been there. We had to replace the control board on ours. We are lucky enough to have a repair service tech in town that came by and diagnosed this (cheaply since he didn't really do anything), gave us the part number and where locally to order the new control board. Easiest way is to contact the manufacturer to order a new one. If its the exact same problem, the oven wont hold temperature, will start to heat up then gives the code. The board is very easy to replace, takes less than 30 minutes.
Posted on Jan 10, 2013
  • chudwg78
    chudwg78 Jan 10, 2013
    Thanks Jim. So control board and control pad are the same thing right?
  • Jim Couk Jan 11, 2013
    Been a few years since I replaced mine, but I believe so. When you order the part, you get the circuit board and 2 face plates, one white, one black. If you research the error, you'll probably come up with heating element errors. Dont be fooled by the error name, we wound up replacing all 3 elements in our oven, didn't fix the error and cost about the same as just the control pad.
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: RBD305 Whirlpool wall Oven Beeped
You have a shorted control pad you need to replace it.
Posted on Jan 11, 2009
  • 84 Answers
SOURCE: error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Posted on Dec 13, 2009
SOURCE: oven gives code E6 F2 on panel
The problem in our oven has cleared by itself. I did see the E6 F2 error message but for now, it's working fine. Considering the customer service was only able to help to the extent of reading the error code sheet the same as I was (the sheet is behind the touch pad) and seeing how limited the solutions were, we don't think we'll be buying another Whirlpool. I was pretty insulted when the girl a customer quality called to offer me part #8300453 at half cost of $164 providing I have a service guy look at the stove and call in the part. On top of that, the warrenty is 90 days and the part is on back order. Why would the part be on back order? A) they either did not make an ample supply for inventory, B) there are many ovens needing this part. For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me someone was sleeping with a cigar in their mouth in Quality Control. Or, learning what that meant.
Enjoy the day!
Robert
Posted on Jan 26, 2008
fixyourboard
  • 310 Answers
SOURCE: e6 F2 error on Whirlpool double self cleaning oven.
I wrote a blog on this topic recently, perhaps this will help you:
appliancejunk.com/blog/2009/11/11/whirlpool-oven-e6-f2-error-code-failure-andor-blank-display-board-not-available/
Best Regards,
Bruce
Posted on Mar 05, 2010
I get an F5 code. I have replaced the ERC, what next?
it seems like you have a bad control board. we can help you with that if you want to send it to us.
Dec 20, 2015 | Jenn-Air Ovens
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
Our oven read a problem # E6 F2 what that's mean?
The E6-F2 error code means that the control board thinks there is a problem with the cancel button on the touch pad. Sometimes its due to a loose connection from the ribbon cable on the touch pad. You can push cancel and clear it and if within 5 or under the error code returns the touchpad needs to be replaced. But first check/have the connection checked to make sure its tight. The way modern things work though is grand and Whirlpool say if after replacing touchpad the error code returns once again the clock/control board is what needs to be replaced.
Gene
Aug 11, 2011 | Whirlpool RBD305PD Electric Double Oven
Error code e6 f2
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 19, 2010 | Whirlpool RBD305PD Electric Double Oven
WHIRLPOOL GOLD DOUBLE OVEN BEEPING WILL GO BLANK THEN WILL SHOW E6 F2 TROUBLE CODE
Hi dear.Please do the following if you know what you are doing.According to your explanation,F2E6 code on whirlpool oven related with following: F2 - E6
I hope that solves your issue.Thanks.
Aug 28, 2010 | Whirlpool GBD307PDS Electric Double Oven
My oven model # wfg361lfb series : ry1912535 i put it on - it seemed to start up. suddenly the degrees started going down ... and now no buttons work (the clock still does) and it says F2 EO
Hello-  The code indicated-  F2 E0,  is an indicated fault in the touchpad, usually in one of the switches, but sometimes in the connection between them. Onsite diagnostics are required to see which component is affected. If fault does not clear after hitting cancel, then service is required. Solution is to replace touchpad.  Please acknowledge this post if helpful.  Have more info if needed- Thanks- Ed
Mar 24, 2010 | Whirlpool Ovens
ACCU BAKE codes come up e6 f2
You have the following error.
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore Ovens
My oven is giving me an error of E6 F2, what does that mean
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | Whirlpool Ovens
Whirlpool code E6 F2
Hello ssuebe51
Welcome
Turn the power off to the oven.
Check the connection from the key pad to the clock.
If the connection is good then put back together.
Turn power back on and press the cancel button.
If the error code returns after 60 seconds then the keypad will have to be replaced.
Thank you huuum
Please remember to leave a rating
Sep 19, 2008 | Whirlpool RBD305PD Electric Double Oven
Double oven will not work sometime
Mobley, F2-E6 code is cancel key drive line open. The tech sheet I have on this recommends reseating the keypad connector. It then states to press cancel. If the error comes back within 60 seconds replace the keypad....Catriver..post back.
Sep 16, 2006 | Whirlpool GBD307PD Electric Double Oven
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
