Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
How to unlock my external hard drive
I was working with (easy hard lock) and than i lock my external hard drive
now i cant get access to my external hard drive
(the program said dont lock external hard drive but i did i didnt know that )
can someone help me please
thanks
  • Anonymous Feb 06, 2009
    i have the same problem
5 Suggested Answers
SOURCE: Locked out of external hard drive!!!
http://support.microsoft.com/kb/308421
Posted on Jan 30, 2008
MLFnet
  • 328 Answers
SOURCE: i have programs within folders
If you are running Windows
  • Right-clicking the folder > "Properties"
  • You can then see what permissions you have.
  • You may need to take ownership of the files/folders.
  • You can find more information on how to do this at http://support.microsoft.com/kb/308421
If you are running OS X
  • CTRL+CLICK the folder > "Get Info"
  • Unlock by clicking on the padlock
  • "Sharing & Permissions"
  • If you are not in the list, press the [+] at the bottom left to add your account
  • Set your Privilege to "Read & Write"
  • Press the Action Icon (the gear next to the [-]) > Apply to enclosed items
Posted on Jan 09, 2011
otacon
  • 1944 Answers
Ask the person who set up your hard drive if the contents of the driver are encrypted. Are the folder names in green?
Posted on Jan 26, 2008
  • 40 Answers
SOURCE: External Hard Drive Not Regonized
I can help you with this. Follow these instructions--> Start-->Control Panel-->Administrative Tools-->Computer Management, under the Storage section select "Disk management". Locate the external harddrive, and then change the drive letter.
Select the external drive. Right click, and select "Change drive letters and paths"-->Highlight the driveletter to change-->Click the "Change" button-->From the drop-down list choose an unused drive letter, and hit Ok.
The external drive should be recognized and accessible at this point. Let me know if you have any other questions.
Thank You, Raph30
Posted on Jan 28, 2009
SOURCE: Western digital 500gb external hard drive ticking noise- Help !!!
There is a number of data recovery solutions online. Just google it. I would recommend one that sends out a static sensitive bag for transportation. But the customer service rep you spoke with, is probably right. The actuator arm has probably locked up and is failing to move back and forth reading and writing to the platters. Good luck and i feel for you with it being your new born on the hard drive.
Posted on Mar 10, 2009
Lock with no password
if locked
you cant access hard drive
you need to unlock hard drive
is there any important data ?
Apr 13, 2014 | Western Digital WD5000BMVV 500GB 5400 RPM...
Hi if you are locked out and cant acess any files then the chances are you have had a virus at some point as this can cause havoc with hd you could try a data recovery programme but if this dont help then the only thing you can do is format and start again
Jan 26, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
How to unlock my local drive if it was locked by "easy drive lock software"??
To unlock the hard drive unlock x:
The x represents the letter of the hard drive that you want to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
To lock the hard drive lock x:
The x represents the letter of the hard drive that you want to lock. For example, if you needed to lock the C: drive, type c in the place of x.
Jan 25, 2014 | Computers & Internet
Iomega prestige portable hard drive
What are you trying to do ?
You can use any drive as long as you have usb or other required ports available on your computer.
If an external hard drive on your computer has been locked, it has likely been done by the computer's system administrator.
This means that anytime you try to access the drive, you will be prompted to enter either your password or the administrator account's password (depending on the methods that person used to lock the drive).
If it asks for the administrator's password, you can't unlock it until you get that information from the administrator.
Click the Windows-logo button on the lower-left-hand corner of the screen.
Click "Computer."
Double-click the icon for the locked external hard drive.
As Windows Explorer attempts to access the drive, it will recognize that the drive has in fact been locked and you will be prompted to enter a password.
Enter the drive's password into the box and click "OK" to view the contents of the locked external hard drive.
Aug 14, 2013 | Computers & Internet
Can't access data on external drive
Right click on the drive in my computer and click properties see what it tells you like info.
Jul 12, 2009 | Western Digital My Book Essential Edition...
Crc errors on simpledrive external 500gb USB
there is a program called HDDregenerator this software will repair HDD errors without destroying data (not sure on W7 support) http://www.dposoft.net/ ( check website for support and info)
I have used this software to bring back to life completely dead harddrives,
its easy to use.
Its not free but in my opinion its worth every penny
Mar 24, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
External drive not showing up at all
i was working with (easy hard lock) and than i lock my external hard drive
thanks
Jan 21, 2009 | Western Digital My Book Essential Edition...
Can't access files on external hard drive
Hi All had the same prob with my external drive and used a program called Easy recovery professional it worked for me .hope this works
Dec 27, 2008 | Western Digital Passport WDXML800UE...
Locked Folders
One week ago my LaCie external disk has been locked during a system reinstallation process in which the hard drive was plugged in.  The message was that I had no permission to access it. I thought I would loose for ever all the files I have been backed up for years. But finally I have got the solution for that. There is a sofware called MacPilot (I used version 3.2.6, $20, 15-day trial) that fixes it. Once instaled, click TOOLS, then "Files&Folders" at left, then "Unlock File or Folder", press "Choose", it opens FINDER and then you click LacCie Disk. When the padlock symbol at the botton of LACie disapears, you can finally change the permissions to "read&Record". That's all, and I hope it helps.
I recommend that you always unplug external hard drivers during system reinstallation to prevent that.
Feb 22, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
7,913 people viewed this question
Top Western Digital Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
