How to light pilot light on gaffers & sattler S80 FDF
Pilot light
3 Suggested Answers
wcrawf11
  • 52 Answers
SOURCE: Hello I have a Gaffers and Sattler HVAC System the
If you can see the gas valve there is a thin hard wire called a thermocouple that comes from the gas valve and ends uo in front of the pilot light and this is where you would relight the pilot if the pilot wont stay lit then you need to replace the thermocouple you can get one from any hard ware store
Posted on Nov 28, 2009
james3751
  • 614 Answers
SOURCE: Have a Gaffers and Sattler furnace mod # 85 FDF
When it call for heat you need a voltmeter to see if you have voltage at your gas valve. Check that first. You could jumper your stat between w and r to see if you have a bad stat. Rus
Where is the reset on an old Gaffers and Sattler furnace
on my old furnace (gravity) there is a overheat relay which will shut off the furnace if it is very cold and it overheats. it is at the top of the furnace box on the side with a pipe coming out to a relay box.....it needs resetting.....if its like mine with a pilot light...
Dec 20, 2013 | TPMS Scan Tool with TPR Reset Tool Kit...
Gaffers & Sattler stovetop model 1465/944. The burner mechanism malfunctioned when we turned the knob where it connects to the burner and is leaking gas and will not turn off. We would like to find...
Not that many parts for a 33 year old appliance are still avaiable but try one of these places
http://www.antiqueappliances.com/
http://ths.gardenweb.com/forums/load/antiques/msg0717405813237.html
http://www.facebook.com/pages/Vintage-appliance-restoration/124642017603277
http://www.stovelady.com/
I have been a appliance tech for 30 years and love the vintage appliances and strive to search for to repair them whenever possible if the customer wants to hold on to them
Good luck,
Gene
Aug 05, 2011 | Cooktops
I have a gaffers & sattlers hollywood oven
where did you purchase the thermostat from?
Apr 10, 2010 | Kitchen Ranges
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Dec 22, 2009 | Ovens
Have a Gaffers and Sattler furnace mod # 85 FDF ser # PV 09020. Pilot is lit, when I call for heat nothing happens. T-stat is okay, thermo couple okay/new. Fan will run when manually turned on at unit with...
Nov 28, 2009 | Heating & Cooling
Hello I have a Gaffers and Sattler HVAC System the wind has blown out my pilot and I cant seem to locate were to relite
Nov 27, 2009 | Heating & Cooling
Can't find the oven pilot on an old Gaffers and Sattler "Energy Saver Range with Uni Burners"
With the help from your site I was able to hold a match under the bar under the oven shelf toward the back and light the pilot. I am SO grateful. I hadn't been able to see it but just held a match toward the back, and it lit.
Feb 27, 2009 | Garland H283 Gas Kitchen Range
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
The pilot is under the bottom oven deck, usually you can lift the front edge, and slide it out, smelling gas without a pilot would be bad, that means either A : your safety is bad, and allowing gas to flow anyway, which requires replacement, and you may as well replace the thermocouple, and clean the pilot. or B : it is old enough it does not have a protected pilot, and you have to manually light it, usually indicated by an open hole in the front middle of the oven deck plate when you open the door, with a tube going to the burner. or C : your oven burner is bad or misaligned with the burner, and is shooting gas away from the pilot area, it would light via an open pilot eventually, but you don't want that. Please let us know, or have a qualified servicer look at it. Happy New Year, and thank you.
Nov 19, 2008 | Garland H283 Gas Kitchen Range
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Heating & Cooling Logo
258 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
