Question about Watches
I need to know what movement to order for versailles wall clock quartz with westminister chime
  • 5 Answers
SOURCE: how do i synchronize chimes with clock on
I've know it is very simple but I lost the directions. Removing the minute hand is NOT AN OPTION.
Posted on Jun 05, 2010
gemineye61
  • 831 Answers
SOURCE: i have a quartz
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Posted on Aug 15, 2010
    SOURCE: Elgin Westminster Quartz Chime clock won't work
    IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
    HOPE THIS HELPS.
    Posted on Oct 11, 2010
    • 16 Answers
    SOURCE: Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Posted on Nov 03, 2010
    • 2501 Answers
    SOURCE: I have an Elgin Westminister Quartz Chime clock.
    I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
    Perhaps your is the same?
    Posted on Mar 13, 2011
    MINUTE HAND NOR THE HOUR HAND NOT ADVANCING AS THEY SHOULD. CLOCK STUCK AT 8:45 FOR DAYS, PENDULUM MOVEMENT OK. WHAT IS THE SOLUTION TO GETTING THESE BACK TO WORK? THIS IS ON A STRAUSBOURG MANOR...
    without seeing the clock .....are you sure it isn't something as simple as the hands ( arms) detaching from the centre spindle which continues to turn but without the hands. Alternatively have the hands become stuck on something on the clock face or become intertwined themselves ? Very simplistic but all I have to offer...
    Feb 24, 2015 | Watches
    I have an Elgin Westminster chime quartz wall clock (with pendulum). It uses a C-cell battery. It will not work at all. Please help if you can, since it has sentimental value to me. Don't know if...
    I'm afraid you have to visit clock repair shop, as without close inspection it is not possible to say what's wrong with your clock.
    May 18, 2011 | Watches
    I have an Elgin Westminister Quartz Chime clock. Everything works fine, except the pendulum does not swing, anymore. Can I fix this or can I buy parts to fix this problem?
    Mar 13, 2011 | Watches
    I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
    I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
    Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
    I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
    Hope this helps!
    Feb 07, 2011 | Watches
    How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
    If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
    Jan 16, 2011 | Watches
    I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
  • Aug 15, 2010 | Watches
    John
    Apr 21, 2010 | Watches
    Antique Forestville Mantle Clock
    Middle Key hole for the time.
    Left side is for Chime
    Right side is for the strike.
    r/
    David
    Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
    Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
    Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
    Jul 13, 2009 | Watches
    Elgin grandfather clock chimes not working
    I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
    If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
    Mar 29, 2009 | Elgin 0518709FA
    Watches Logo
    23 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
