Question about Mitsubishi WS-55513 55" Rear Projection HDTV
DM Power on problem - Can I use 35V Caps instead/ (Techman??)
I am following Techman's solution for the power light flash. I really don't want to wait for shipping on the caps. Can I use the 1000uf 35V caps that are available at Radio Shack? (Instead of the 1000uf 16V) Thanks Techman for your solution and instructions. My TV failed today after a few days of flakey on/off issues.
  • 1 more comment
  • Bob Fronk Jul 02, 2007
    Thanks for the RAPID reply!!
    The family wants TV back soon. I will try the Raggedy Shack caps and order the others. Maybe it will get me through for a few days and I can swap them out again later.
    I just ordered a 58" Plasma to replace this TV but it won't be here for a week or so. My 10yr old was really looking forward to getting the Mitsubishi in the basement for his games. (I know he will probably ruin it, but at this point it does not work anyway!!!)
    Techman, where are you located? Contact me offline - [email protected]
  • Anonymous Dec 28, 2007
    Same
    Genius:
  • 1,694 Answers
1000mf 25v or 35v 105 degree high temp only......if too tall,
lay them over 90 degrees on to board...plenty of room...T.
Posted on Dec 29, 2007
    President:
  • 3,130 Answers
If they fit, sure but If I'm not mistaking, they are too tall. And they really should be the high temp caps, as if you do not use hi temp caps you will be in the same boat down the road. Good Luck
Posted on Jul 02, 2007
  • Larry  Dillon
    Larry Dillon Jul 02, 2007
    Fix it right the first time and you should have many years of a good TV set. too bad the TV set will be used as a game monitor :>(. Lucky kid to have such a good projection TV to ruin with image burn in. if I were you, if you already have a good TV set to replace this one, sell or give it to charity, as as a game TV, a totally waist of a perfactly good TV set! I am sorry, i do not mean to sound harsh, but come on, you can get a 32 inch for less then 200 bucks that will not burn in the screen with the games.
    I wish I had the set. Mine just blew up, and parts are no longer available. Oh well wish the best on the repair.
SOURCE:
Green light flashing on timer. tv wont power up..just bought this house. wtv was left behind. i was told it works but i cant turn it on
Thats a common problem if the sets left unplugged or without power the DM caps drain and then wont charge when the power is restored. Its a easy fix usually just replace the DM caps. You can get the Mitsunbishi repair kit called the WS55859 DM repair kit from www.tvrepairworld.com which has the upgraded replacement caps and the CD with repair instructions.
Jun 14, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-65511 has flashing timer light but will not turn on.
I used to have a WS55909 and had this problem. The light is supposed to blink for one minute while the DM (digital module) boots up after a power loss. If the light continues to blink indefinitely, there is a problem with that board. The DM power supplies are known to have faulty capacitors on these models and will need to be replaced. If I remember correctly, there are (7) 1000uf 25v capacitors and they should be desoldered from the board and replaced with 35v ones. Note that my TV model already had 35v caps but changing them solved the problem: electrolytic capacitors have a much shorter life than other components.
The DM is on the left side and is where ANT-DTV and the IR repeaters plug in. The power supply is the board above the main DM board inside the DM case.
If this sounds too technical for you, get a new TV because a repair guy will charge you more than the TV is worth. In other words you could get a (30-46") LCD TV for the same price.
Oct 21, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Want to replace caps which board is the DM board?
Once you take the shield assembly off, you will see a board, I believe it is the DM Board board. There are four Capacitors grouped together probably rated at 35v 1000 mfd, 105 degree. They should be replaced with 35v 680mfd,105 degree Capacitors. Now once that is done, there is another board under that one. This is the Format Board. It also has 4 Capacitors that should also be replaced. They are the same value as the first Board and should be replaced with the same 35v 680mfd, 105 degree Capacitors.
Please note the Flex connectors at the bottom of the DM and Format Boards. They may not be available from Mitsubishi any more so be gentle with them and make sure the are installed properly when reinstalling the Boards back into the chassis. There is one other Board you should look at. The Power Supply Board is the board on the back of the chassis and also has a number of Capacitors that fail. Most all of the Capacitors that fail through out this chassis will have bulging tops. So any you see bulging, you should replace whether they are on the DM, Format , or Power Supply.
I hope this helps,
Skyassoc
Jan 07, 2010 | Mitsubishi WD-52725 52". Rear Projection...
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Model ws65613 green power lite keeps blinking tv does not turn on
oh yea don't try to look for a lamp in your tv set that has three crt's!
if you can solder and unsolder , then replace the four(4) 1000uf capacitors on the dm board , and make sure the new caps are 25v or 35v , also check fuses for the two STK 394-250 convergence IC's (ic8c01 , ic8c02 )( on the big heat sink ) , if they are blown then replace the convergence IC's also
here is the service manual that will help in dissasembly and locations of dm board and convergence IC's
http://www.techlore.com/download/24849/Mitsubishi-WS-xxx13-Service-Manual/
Mar 02, 2009 | Mitsubishi VS-55601 55" Rear Projection...
CAN SOMEONE PLEASE HELP ME
the 3300uf 16vdc caps are on the left side of the power supply board. the 1000uf caps were on the right side.
Dec 14, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Mitsu wd-52628 green flashing timer/power light
steady blinking is the DM failing to complete the boot sequence. Your more than likely needing the DM repair kit.
Jun 18, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mits 52525 blinking green light
Good Day;
If you only changed 4 caps,1000 ucfd 35v, it should be 5, if you did not remove the little plug in board, e prom, you may have damaged that. B-4/after changing caps what is the indicator light, green, doing?
Does light stop? Please rtn with more info.
Jun 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65513 light blinking
If the light continuously blinks, there are four(4) caps, 10000upf @ 35v that are bad on the DM board. The board is on the right side of the chassis, looking from back, the caps will be swollen on the top. The repair is more cost effective then replacing the board.
Mar 12, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi fix.....
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Jan 13, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
