Question about Reliance & 40 Gal Electric Mobile Home Water Heater
I have a 640dors reliance capacity40 water won't stay hot long(electric)
How can i set the hot water temp on a reliance 640dors it don't stay hot long enough to take a shower
  • 51 Answers
Remove the two covers one high and one low and set the temp higher. This time of year with colder water comming in the house the water heater has to work harder to raise the temp of the incomming water. In the summer the incommong water is much warmer. 40 gal is a small water heater and you will only get about 15 gal of hot water with the ice cold water entering the water heater as you use the hot water. You can get a bigger water heater. even better is to go tankless and a have never ending hot water and save money at the same time.
Posted on Jan 12, 2013
snap101
  • 117 Answers
SOURCE: My electric reliance water heater is making a constant noise
it might be hard water in the heater. the hard water flakes and when your water heater turns on it creates some movement in those hard water flakes and makes a popping and hissing noise then when it comes to temperature it should stop. the temperature and pressure relief valve shouldn't make this noise. but if you stick your finger in the pipe and it is wet then you might have problems some where else. let me know if it is
Posted on Jul 29, 2009
  • 832 Answers
SOURCE: Our 606 reliance electric hot water heater has the
We will just assume that "a" is the lowest temperature
to correspond to 120 degrees, while "c" for 160 degrees.
So try setting it at "a" and feel the hot water that flow.
Or it could be the other way. Just feel the hot water that
flow. It will be done in a few minutes. I hope this will help
you.
Posted on Nov 27, 2009
  • 127 Answers
SOURCE: I have a reliance 501 electric hot water heater
it is located on the thermostat. Take the cover off the side and you will see a little red button in the side of the themostat.
Posted on Jan 11, 2010
garypetterss
  • 15 Answers
SOURCE: I have reliance 501 electric hot water heater, and
There is an address near the end of this link to request manuals of reliance water heaters not listed. http://www.reliancewaterheaters.com/lit/om.html
it is quite possible that your heater works on the same principle as one of the other models and just differs in capacity or power rating.
Posted on Apr 11, 2010
SOURCE: I have a Reliance 501 water heater, when I take a
Electric water heater is fully repairable by homeowner.
Following information will tell you how.
1) Background on your heater:
Reliance is AO Smith company.
http://www.aosmith.com/OperatingUnits/Detail.aspx?id=138&ekmensel=c580fa7b_12_0_138_3
Age of water heater is shown in serial number. First character is letter. Second 2 characters are numbers, which are year of manufacture. For example 05 is year 2005.
The 501 manual is not shown on Reliance website:
http://www.reliancewaterheaters.com/prod/elec.html
2) Two things known for sure:
- electricity is OK
- upper element is working because there is some hot water.
3) Three things can cause problem you describe:
- Loose wire located from upper thermostat to lower element and thermostat.
- Upper or lower thermostat is bad
- Lower element is burned out
4) How to troubleshoot and repair
- Turn off power, open covers and look for loose and burned wiring, especially on lower element.
- When finished, put back insulation and covers so thermostat not exposed to cooler temperatures.
- Burned wire on lower element is evidence that lower element is burned out.
- If you do not want to follow testing steps below, next step is to replace both upper and lower thermostat for about 25$ and see if problem persists.
- If problem persists, replace lower element.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Test lower element, before replacing anything
http://waterheatertimer.org/How-to-test-water-heater-element.html
6) Troubleshoot electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
7) How to replace lower element and clean sediment out of tank:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Posted on Nov 18, 2010
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
I replaced both thermostats and both elements in my 5 yr old water heater and I still don't have hot water. What else can I look for to fix?
Check that you are receiving 240Volt across top 2 screws on upper thermostat.
Copy following link for troubleshoot resources:
Jul 11, 2012 | RELIANCE ELECTRIC WATER HEATER
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 30, 2011 | RELIANCE ELECTRIC WATER HEATER
Water heater appears to override thermostats. Water gets scalding hot. This has happened twice. First time I replaced both thermostats. Set both at 120degrees. Model 640DORS Sereal# CO5A035030Thank you
1) There is a water heater condition called 'stacking'
http://waterheatertimer.org/Stacking.html
2) Dual element tanks are 240Volt.
Thermostats turn off 1 leg of 240Volt circuit.
If element is shorted to ground through center of element, it might not trip the breaker.
In this case, the bad element would continue heating with 120V through ground wire.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Reliance & 40 Gal Electric Mobile Home...
My dad lost the manual to his 606 Model # 640DORS. We can't figure out where you change the temp.; the person who installed it several years ago, turned the temp. way down, and in the winter, it doesn't...
Remove access door usually on upper side of unit. Will need to unscrew retaining screws. Under cover is a thermostat that you can adjust to your liking. Reattach cover when done.
Sep 06, 2010 | Reliance & 40 Gal Electric Mobile Home...
No hot water
more than likely tripped the high temp switch. This is made as part of the upper thermostat, replace the thermostat and it should start making hot water.
Mar 07, 2010 | RELIANCE ELECTRIC WATER HEATER
Our 606 reliance electric hot water heater has the letters a b c for the temp control not 120-160 degrees. On what letter a-b or c should the temp be set on to get 120 degrees
you.
Nov 26, 2009 | RELIANCE ELECTRIC WATER HEATER
Reliance & 40 Gal Electric Mobile Home Water Heater  Logo
390 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
