Question about Frigidaire PLMV169DC Microwave Oven
Plmvz169gcc lost power
Lost power outlet is goo breaker is good unplugged and ran ext cord to it still no power
  • Frigidaire Master
  • 9,098 Answers
The service manual is here.
It may be a defective 20A fuse, a blown magnetron temperature fuse, or a problem on the control circuit board, which can be economically repaired.
There is a YouTube video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the controller is off, you should be able to access the magnetron's temperature fuse for testing and possible replacement.
You can order parts from the Pros here.
Posted on Jan 10, 2013
Reset button
Unplug,then plug back in,wait 10 minutes,or try another outlet,circuit breaker could of turned off at control panel in house,reset it.
Mar 04, 2017 | Microwave Ovens
I have a Sharp Carousel model R-1874-T. It suddenly stopped working. No lights are on. I checked the outlet and there is power coming there. Is there a way to reset the microwave?
Steve,
You probably have a blown fuse.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 27, 2015 | Sharp Microwave Ovens
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
My microwave/convection oven will not heat up, but the lights and clock work
Hello
Look to see if the microwave power cord is securely plugged into a live power outlet. The power cord cannot be loose for proper function. Move other appliances to a separate outlet if possible.
Replace or reset the circuit breaker or fuse if blown or tripped.
Unplug the microwave and wait several seconds before plugging it back in to reset.
Make sure there are no current functions in use. Press "Clear/Off" to cancel any other settings or programs already in progress.
Select a new cooking program and then select "Cook Time." Make a time selection and press the "Start/Pause" pad to begin cooking.
I accidently ran it for a few minutes wih nothing in it. I turned it off and everyting seemed fine. Later I walked in kitchen and there is no light, power or anything.
I assume you checked the power cord and house power circuit breaker panel... possibly tripped unrelated to your running the microwave empty.
(the following is from http://www.kellerstudio.de/repairfaq/sam/micfaq.htm#mictotdo)
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
If those are not the problems, then the main fuse is the most likely suspect for a totally dead microwave.
Remember, while you can do some repairs on you microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, let me know and I will point you in the direction of some good resources.
Oct 21, 2010 | GE Microwave Ovens
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
GE Sensor Microwave JES1855 died
Mine went dead after about 6 months. I had problems with my breakers and I found out that it was the microwave that blew all of them. I also found out that this perticular microwave is a fire hazard and should be recalled. It has caused me alot of headache. The breakers in my house are brand new and they are put out by GE also. It caused me to loose the food in my freezer, I did not know my freezer had lost power. It would cause my entire lights to go off and then they would come back on. I have checked around and I found out that the power cord on the back of the unit is very loose. I had a person to come in and look at it, he thinks its the power cord.
Feb 20, 2009 | GE JES1855 Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Counter top microwave GE lost all power
As an owner of a GE WES model might want to look at this blog post.
GE Customer Service is here.
Good luck.
Dec 16, 2008 | GE Microwave Ovens
MAYTAGE MICROWAVE MMV5100AAB-SWITCHING BREAKER WHEN STARTING
is there a way to over ride the main board start button so i will know if the board is bad. or away to test this?.
Oct 29, 2008 | Maytag MMV5207A Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
46 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
