Question about HP ProLiant DL380 G6 Server
RAID 1+0 configured on HP DL 380 G6 with two SCSI disks, if one disk gets faulty and new disk inserted how much time will it take to sync/rebuild with the booted diks?
Also, if one of the disks is removed and reinserted after sometime, how much time will it take to sync/mirror with the booted one?
  • HP Master
  • 32,281 Answers
It depends upon the amount of data that is stored on the good hard disk. The greater amount of data the longer the time it will take..
The computer will still operate but it will be slower than usual until then data has finished synchronizing to the new hard disk.
Posted on Jan 10, 2013
micromaster
  • 3614 Answers
SOURCE: ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Try to look at this Guide & Manual on "HOW TO"
Just let me know..
Hope my initial idea/info helps you..
Thanks,
micro
Posted on Jul 25, 2008
WhiteRussian
  • 167 Answers
SOURCE: getting drive array problem
Even the 1st generation will have a ROM based Hard Drive Array utility which you will need to make yourself familiar with. Find out the hard ware you are dealing with, make sure it is functioning properly, and work your way to the software configuration.
Posted on Dec 08, 2008
jbwilliams
  • 4 Answers
SOURCE: i have a HP DL
Are you able to get into the array configuration and make sure the logical drive is still intact? If the logical drive is gone, then your partition may be lost. If you are able to recover the logical drive in your array (which you should be able to if the RAID5 striping was stable) then you should be able to recover your data. You can get into the array configuration during the boot up sequence.
Posted on Feb 06, 2009
  • 17 Answers
SOURCE: configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Posted on Mar 12, 2010
  • 64 Answers
SOURCE: I have HP PROLIANT DL
need to provide moreinfo.
is the server (prolaint DL380) constantly rebooting within BIOS mode or has it got to the stage of running windows.
The other item not mentioned here, is, IF the raid controller has failed, you will not see any disks initializing and would cause the system to continually reboot.
If it is an internal raid controller, it is part of the motherboard, you will need to contact HP to have it replaced.
If an pci related array controller .. i.e. separate to the motherboard, this will need to be replaced to see the HDD's.
Either way sounds like a hardware issue. Best to liaise directly with vendor to have the faulty components replaced.
Posted on Sep 28, 2010
Drive replacement and rebuilding Raid 1 on a Dimension XPS Gen 2
Did you format the new drive? Formatted size must be the same or bigger than remaining drive.
Mar 07, 2014 | Dell Dimension Computers & Internet
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
Blinking red light and beep sound coming from the front blade Slot 1.
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
Dec 05, 2013 | HP ProLiant Computers & Internet
Dell poweredge t110 Raid 5 setup on PERC 100 raid config in bios stating Virtual drive degraded and drive 2 is in ready state...how do we remove from drive array and install a new on without data loss
In a RAID 5 config, you need at least 3 drives (you can have more however). A small part of every drive is then reserved for recovery data for the other drives. So two drives together hold all the data needed to restore a 3rd drive.
The Raid Controllers in the Dell Poweredge Servers are hot swappable. So you can just pull the faulty disk and then insert a new replacement drive in the same slot (Needs to be the same type and size or bigger. However, if the disk is bigger than the other 2, then only the size of the two other disks will be used on the new drive). The Raid controller will then see that there is a new disk and automatically start the recovery process. You will be able to see this when you open the Controller software. Once the recovery is done, the RAID 5 will be fully functional again.
While one of the disks is faulty or missing the two remaining disks will continue to work, but at the severely degraded performance. After the rebuild the performance will be back to the way it was before.
The rebuild can take more than an hour, depending on the disk sizes used.
There is also an option on some Controllers to select one drive as a "spare". Then you insert one more disk and set it as spare. It will not start working unless one of the other disks in the Raid fails. That's when it is used automatically as a replacement.
May 02, 2011 | Dell PowerEdge T110 Server (GB/2GB)...
I have a Dell Poweredge 1800 with 4 Cheetah 10K.7 Ultra U320 SCSI Drives which are supposed to be mirroring each other in case of failure of one hard drive the exact same thing is on the others. Drives 1...
hi!
This is a quite serious matter to be solved. The information you have provided is not enough at all.
What you have to include in here:
  1. First, Be precise. Don't assume.
  2. How did you recognized the failure. Which indicators or POST/BIOS/RAID BIOS reported you the errors? Was it from the OpenManageSA?
  3. Please specify the Hardware Controller model and manufacturer with the version (RAID controller).
  4. Which Operating System do you run (or ran)?
  5. Are these disks Hot Swappable?
  6. Have you used hardware RAID controller or software RAID? Provided by OS.
  7. Do you have Dell OpenManage Server Administrator?
  8. How do you describe the RAID configuration? Are you sure that Disk 1 and 4 are mirrored to 2 and 3? You must be precise. Because raids can be used in many ways. You can combine any two disks and mirror them to any two disks. Even though it prevents hard drive failures, if your OS had an issue Mirrors may not be an option to recover it.
  9. That message is a Warning Message. However Drive Roaming has completed. You don't need to worry about that.
  10. If your BIOS has associated firmware controllers you could rebuild the array. But you may have to add new disks to replace others. You may need to update the firmware if necessary.
  11. Then if you plan to use disk 2 and 3, you have to position them to 1 and 4. Then try to rebuild the array. But you may have to have Controller Drive installed on the disk. That varies from type to type. So I cannot say exactly. However if the mirroring of the OS is done to one disk, that disk would be enough. But you have to be certain. Reconfiguring should be done using both the disks replaced if you do not know anything about the configuration.
  12. Check BOOT ORDER. Change it if necessary. If disks fail again check one by one and repair them using a separate machine.
  13. Use Dell Software (OpenManage Server Administrator, if its the one available). Rebuild and or Resync the array.
  14. If boot record errors occur, you have to boot from CD/DVD and repair the Boot Record and/or MBR.
  15. If you need any other issue like BSOD, please write them down. Make sure the OS is not corrupted. If you backed up the System Status, restore it in such a case. Do an In-place Upgrade otherwise (will replace the OS files only, not data).
  16. Use the manuals for Dell Server and RAID Controller if you do not know how to use properly.
  17. If all the options are not working, you have to contact an engineer at Dell.
Feel free to contact again.
Thanks for using Fixya!
-Lasitha
Aug 27, 2010 | Dell PowerEdge 1800 Server
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
I have hp proliant with raid 1+0 .I have 2 hard and usr in option
Sometimes shortened to RAID 10, RAID 1+0 is a particular combination of two different RAID levels: mirroring (RAID 1) and striping (RAID 0). The appeal of RAID 1+0 is simple: mirroring gives you the highest level of availability RAID offers, with the fastest rebuild times when a disk fails; while striping - using the proper chunk size - is the basis for high-performance I/O.
Jun 09, 2009 | HP ProLiant DL380 G4 Server
SCSI BIOS not installed / ML150G2, exchanged mainboard, RAID
hi..
my guess is no but since i haven't dealt with this type of server i'm going to suggest you go to hp.
if you just goto hp.com and search on live chat and a link will come up.. they should be able to help unless it's too old since i'm not sure what generation we are on now..
good luck, hope this helps a little..d
Feb 23, 2008 | Adaptec (2120S) SCSI Controller
HP ProLiant DL380 G6  Server Logo
170 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
