I lost the remote my my Philips 40pfl7705dv/f7. Is there anyway to get into the settings menu without the remote?
    Top Expert:
  • Televison & ... Master
  • 43,031 Answers
Unfortunately, setup can only be selected by the remote
Posted on Jan 10, 2013
  • William Moe Jan 10, 2013
    Thanks for the quick response.
3 Suggested Answers
SOURCE: PHILIPS 40PFL7705DV/F7 keeps shutting off
If it is a new TV and under warranty, return it. There is an internal fault and it needs to be serviced.
Posted on Oct 25, 2012
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
How do i zoom out of a philips tv in model 32PFL3504D/F7 without a remote control
Buy a cheap Universal Remote and then you can select the screen format mode
Dec 28, 2014 | Philips Televison & Video
Okay I've purchased a 40 inch tv today and how do I reset everything?
From the User Manual, page 35 (page 36 in the .pdf file):
Return your settings to default values When you return picture and sound settings to their default values the
channel installation settings are not affected.
1 Press MENU on the remote control and then use [the arrow buttons] to select [Setup] > [Installation] > [Reset AV settings] > [Start now].
2 Press OK to reset the picture and sound settings.
3 Press MENU to exit.
You can download a copy of the manual from 40pfl7705dv_f7_dfu_aen.pdf http://download.p4c.philips.com/files/4/40pfl7705dv_f7/40pfl7705dv_f7_dfu_aen.pdf
You may also want to look at "Update your TV software" on the following page of the manual. Updating is not always necessary, unless the update fixes something that bothers you or provides an improvement you want (if it isn't broken, don't fix it). As of this writing, there are two sets of fixes (copied from the "Firmware Upgrade Readme File" at Software & drivers):
Software history:
Version: Problems solved.
PHL-0DA_710_0 - Momentarily looses audio after channel change.
- Time shifts one hour when changing from "Auto Clock" to
"Manual".
- Enables Philips Wireless Media Connect.
PHL-0DA_713_0 - Clock does not keep accurate time.
You do not have to apply both updates; everything is included in the latest one.
Jul 24, 2014 | Philips 40Pfl7705dv/f7 40-inch Smart...
PhillipssoundBar htl2101A
You have to use the TV remote to set the TV sound option to external. Look on TV setup menu for 'external output' or 'external speakers'.
Dec 15, 2013 | Philips HTL2101/F7 Soundbar Speaker Spkr -...
Upside down
Your Horizontal and Vertical Flip is reversed for some reason. This will be a little difficult to do/see, but turn on the TV and Press the Menu Key. Goto "Lock" and press OK. Once you see the Lock Code Box come up, press and hold the Volume down on the TV and the OK Button on the Remote for 5 seconds or more until the TV shuts off. This resets the Memory.
If that doesn't work unplug the power from the TV now for 60 seconds then plug it back in. It should power up at that point.
If that doesn't work it is probably an issue with the Logic Board and a Re-flash of the Logic Board from a Company who has the Equipment to do so will fix it. This shouldn't cost anymore that $150. Goodluck!
May 20, 2013 | Philips Televison & Video
Oct 25, 2012 | Philips 40pfl7705dv/f7 40 Hz 120 Led Tv -...
What do auto fill and auto zoom do on the picture format settings?
You have to enter its service mode options, and make necessary data adjustments there. Just remember, this is a very skilled work. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 580 posts to different brand TVs.
Aug 13, 2012 | Philips 7000 40" 1080p 120Hz LED-LCD HDTV...
I need a manual & a remote for model #22PFL4505D/F7
Philips has the manual on their site: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=mx&ctn=22PFL4505D/F7 . The direct link to the PDF of the manual is http://download.p4c.philips.com/files/2/22pfl4505d_f7/22pfl4505d_f7_dfu_aen.pdf .
A replacement remote that will need to be coded for the TV is available here: http://www.emtcompany.com/philips-22pfl4505df7-remote/rc64.html . An exact replacement remote can be ordered from http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13064588862470&smodel=22PFL4505DF7&brand_pn=PHILIPS_22PFL4505DF7 . However any universal remote should control the basic functions of the TV if they were programmed 6 months or more after the TV was released. Low end remotes may not replace all of the features of the remote. If you have a remote that matches all of the features, you may need to try all of the codes for the Philips TV to get all of the features to work. Those remotes that can be programmed via a USB connection with a computer will be the fastest to set up.
I hope this helps.
May 27, 2011 | Philips Televison & Video
We bought a new phillips moderl #22PFL3504D/F7 tv.
You can download the manual as a PDF here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=22PFL3504D/F7&slg=en&scy=US
There is also a link to Parts and Accessories on the left hand side of the page. Follow the link and enter your model number to get a replacement remote.
You can also buy a replacement remote at remotes.com:
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12743739505150&smodel=22PFL3504DF7&brand_pn=PHILIPS_22PFL3504DF7
I hope this helps.
May 20, 2010 | Philips Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
