Question about Samsung Heating & Cooling
I have a Samsung Biotech plus air conditioner - Model SC12ZAB. When the system is turned on, all the lights on the control panel light up and it is not possible to select any of the 5 sway options to operate the air conditioner. Also, the unit does not repond to the remote control. Any suggestions?
  • Samsung Master
  • 2,963 Answers
Warranty? go that route. Id unplug at least a minute see if it's brain will reset. With these new fangled computerized machines, one needs to be a specialist's specialist. Hopefully you have your owner's manual, it has a troubleshooting section, no help? Call the Customer service they are usually helpful, Or email them too.
Posted on Mar 13, 2015
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
skrbin
  • 121 Answers
SOURCE: samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Posted on Feb 16, 2009
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
co7196
  • 3433 Answers
SOURCE: Samsung Air Conditioner will not turn back on after power Outage
Turn off the circuit breaker and wait 10 mins, then back on.
Turn off all units, wait a about 1/2 hr. See what that does. Also, Turn only one unit on at a time and let it run 5 min before turning on the secon and the same withe third. An what remote island might that be? Good Luck, Ned
Posted on Nov 11, 2009
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
The Samsung biotech is not getting cold anymore what can we do?
You may need to have the system recharged with freon.
Jan 17, 2015 | Samsung Heating & Cooling
The timer light and the turbo light flashes, plus when I turn the air con on it will turn of 5-10 mins later and the lights will flash
your air con has defect and the sequence of flashing lights are tell us whats the problem. If you have electrical s knowledge we can try to resolve it online, if not is better to call a specialist.
Feb 27, 2011 | Samsung Heating & Cooling
I have a samsung biotech plus which is leaking water from the vents in the front. The unit was already in the home when we purchased. Cools beaut but the water is a pain. Can anyone suggest an answer...
Check your air filter & evaporator coil for dust blocked. Clean it.Even if less rpm of blower motor is also one of the problem. Replace the capacitor.
Dec 30, 2010 | Samsung Heating & Cooling
Both of the green lights of my samsung as09xln
Try turning the power off for a few minutes and then turn it back on...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Samsung Heating & Cooling
Indoor unit light blinking ( first n second light from top)
I have the same problem too. Aircon cannot switch on, two lights from the top is blinking. Everytime I turn on, the flip is open then close again with sound. The technician said the thermostat cable need to be replace. It cost about $15. The cable is 14" long. Hope this help.
Feb 16, 2010 | Samsung Heating & Cooling
GREEN LIGHT ON CORD COMES ON BUT THE AC UNIT WONT TURN ON. IT IS A SAMSUNG AW109CB PLEASE HELP.
you need to verify that power is getting to the control panel, the green light does'nt mean that there is power to the unit, also verify power to the controll swithes/board and verify that the thermostat is closing and trying to turn the unit on
Jul 12, 2009 | Samsung AW1203B Air Conditioner
Control panel lights constantly flashing
You should have a dedicated line that feeds the equipment power look at your main electrical panel or search around your equipment for a pull out disconnect switch or sometimes they will wire it to a light switch. by shutting down the main power and turning it back on it should reset anything.
Jan 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
763 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
