Question about GE Profile JTP56 Electric Double Oven
Frigidaire oven error code f1 modle # FEFL77ABE
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Keep getting F1 error code (constant beep) on my GE profile oven.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%#$TEF
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error code -F1- and broken glass door in lower oven
@$#Y^T
blueextc3221
  • 15935 Answers
&%YR
Frigidaire oven displaying the f1 error code
You are experiencing a runaway temperature, or too hot of a temperature for the control board and sensors within the unit. When the unit gets this error code it shuts down for safety reasons. You would need a professional to diagnose the connections and control wiring to the control board, and the elements for safety.
Dec 30, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Our frigidaire stove or the oven is locked and it just keeps making this beep noise and the oven wont unlock so we really need help unlocking the oven and stoping the been noise thanks
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Read more: How to Troubleshoot a Frigidaire Oven F1 Code ' eHow.com http://www.ehow.com/how_10004808_troubleshoot-frigidaire-oven-f1-code.html#ixzz2EhW21T4n
Dec 11, 2012 | Ovens
I have a frigidaire range/stove. I was roasting dinner at 300 then turn the oven up to 400 near the end. Shortly after there was a pop that sounded like it came from inside the oven. I thought a potato...
F1
  • The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement. If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC). If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven. If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary. If the oven is actually overheating, replace the EOC. If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Read more: Frigidaire Oven Error Codes ' eHow.com http://www.ehow.com/list_7105089_frigidaire-oven-error-codes.html#ixzz1OVfekgRx
Jun 06, 2011 | Frigidaire Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Our Fridigaire range oven will not shut off. In
F1 is a bad oven control. (clock).
It must be replaced.
Unplug the range.
Remove the screws from the rear panel.
Remove the wires from the (clock).
Replace the EOC (clock) with a new control and bake me some cookies.
Feb 02, 2010 | Frigidaire Ovens
I have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Jun 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gas wall oven clock unit sometimes says F1 and beeps.
F-1 is USUALLY a touch pad error, it thiniks something is stuck. The sensor error code is F-3.
Mar 17, 2009 | Frigidaire 24" Built-In Single Gas Wall...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
GE Profile JTP56 Electric Double Oven Logo
63 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
