Question about Mintek DVD-1600 DVD Player
Can i vacume my minteck dvd player to try and get it to play again
We have a 23" Toshiba with a internal DVD player.
No,tv internal DVD player are not on sale by itself as a seperate unit,only can buy it from the tv corporations themselves and it not cheap and have to have experience to putting it in into the tv internal tv itself.The tv internal DVD player now,could be the laser eye data reader have problems reading mp3 and mp4 files on the DVD disc,which are video files.Now tries to play more than one DVD movies dic,tries like to play like 5 to 6 original DVD movies.One disc don't play tries another DVD disc.Tries this might forcing the laser eye reader to read DVD dics again and than might fix it to read video files again.Or just buy an external DVD player hook it up to the tv and play DVD disc on to the tv video modes.DVD players external devices are really cheap these day,like can buy new one for $40.
Mar 25, 2011 | Toshiba 23HLV84 23 in. TV/DVD Combo
I place the dvd in the holder, and it closes, but does not play. It says loading and then nothing. please help.
Tries the tv DVD player,play it with many other DVD discs too?Some the disc u trying to play it might just be bad like the reading shinning laser surfaces are scratches,smushes or grims and dirts on the disc reading surfaces?Tries washes the DVD disc,with some dish washing liquid,dries it with a cloth wait like two mins.Try the DVD disc again.If it have problems,but all DVD discs or with many other DVD discs too?Tries websites like Ebay.com or Amazon.com buy a Disc cleaning kit put Disc in the DVD player to play it have 50/50 chances to clean the DVD player laser eye reader.If not more like the DVD player laser eye it is dead.Tv still work fine?Don't take the tv aparts,tries to clean it laser eye manally,because,if u putting tv back together again might causes tv problems too.Just buy a DVD player unit plug it in the tv and play ur DVD Discs.DVD player extenal unit it very cheap these day.Don't take chances,like take ur tv aparts.
Feb 12, 2011 | Naxa Electronics NX-542 13 in. Portable TV
Dvd player stopped working. I put dvd in and it starts turning and says loading and then says no disc & stops turning.
Hi there
Two things can cause the problem you are experiencing,
1.the dvd you are trying to play is bad or
2. the lens of your dvd player is bad
What you should do is to try playing several dvd's to see if they work,if they all do then the particular dvd you are trying to play is bad
If some do not play then the lens is bad ad you should open up the dvd player and clean the lens with a cotton wool dabbed in a little bit of methylated spirit
after cleaning,test the dvd again to see if it plays.
If the problem occurs again,the best solution is to replace the lens of the player because it has become too weak..
Jul 04, 2010 | Audiovox D1718PK Portable DVD Player with...
I bought a DVD and I played it on my laptop. It worked on the laptop but when i put it into the DVD player it wouldn't play. So I tryed playing the DVD in the PC and it also worked on there. Again I...
DVD movies have region codes, and they typically only play on a player or DVD-ROM drive sold in the country where the DVD movie was sold.
The actual region code is in one byte on the DVD (digital versatile disc). The DVD player or drive has a region code in its firmware. Personal computer DVD-ROM players often have the code in the software or MPEG-2 decoder. The two codes must match for the player or drive to play the movie. The code is also printed on the back of a DVD package, superimposed on a small image of the globe.
DVD regional locking is used to control which DVD movies play in which countries or groups of countries. Movies are often released on different dates around the world. Region 1 has its own player that will only play Region 1 discs. Likewise, Region 2 players can only play Region 2 discs and not play any of Region 1's discs. The six codes are:
  1. United States and Canada
  2. Europe and Japan
  3. Southeast Asia
  4. Latin America and Australia
  5. Russia, rest of Asia and Africa
  6. China
please check the DVD region code again and what PLAYER u are using to play on PC / LAPTOP??
where did you buy the DVD player??
Jul 23, 2008 | Televison & Video
The player gives a "cannot play" message for all types of media
Unit probably has a defective disk motor that is in border line failure. When problem again arises, have the motor replaced
Apr 16, 2008 | Sony DVP-NS575P DVD Player
DVD's not playing
Change tha flat cable who connects the laser with the main board.Good luck
Apr 13, 2008 | Televison & Video
Minteck 1030
could be bad motherbord then or screen ok
Feb 01, 2008 | Mintek MDP-1030 Portable DVD Player
No disk
Try playing Different DVDs, Second Make sure which Region Disk your playing is it Region 1 or Region 2, If your DVD player is Manufactured in USA it plays only Region 1, If its manufactured in UK it plays only Region 2, If still you face same problem Use Lens Cleaner, If still you face same problem do Reset.
To Reset Dvd player, Remove DVD from Dvd Player, Unplug Power chord from Walloulet for 15minutes so player goes to Defult Factor Settings, Then plug back again Power chord. Turn on Dvd player insert DVD, It should Play or else Claim Warranty.
Nov 29, 2007 | Curtis DVD8017 Portable DVD Player
Ii own a minteck lcd dvd combo
I have a Mintek lcd/dvd combo which when turned on , comes on with picture and sound but the picture goes off in about one second. I removed the back and can see that the back lighting is going off. I measured some voltages at a terminal strip that i believe provider the back lighting for the set. The results seemed to be normal to me. Can you suggest where I should look further.
Nov 24, 2007 | Philips 42PF7220A 42 in. Plasma Television
Mintek DVD-1600 DVD Player Logo
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
