Question about LG Washing Machines
Lg wm2101hw door will not open
After wash door will not open, cleaned hose and pump filter. Turned machine on and off.
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
  • 3230 Answers
SOURCE: Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
  • 291 Answers
SOURCE: how to clean pump filter on lg wm2688hwm
No, probably have a bad water pump, very common for this washer. I would pull the washer out, lean it against your wall, brace or block it up so you can crawl under it. You will see where the drain hose comes out of the bottom left of the drum and enters the drain filter. Remove the hoses and check for debris or clothes in the hoses or where the drum outlet is. If no restrictions then replace your water pump. Good Luck, Appliance Specialists
Posted on Dec 20, 2009
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
THE WASHING MACHINE WASHES THE CLOTHES BUT WHEN IT COMES TO "SPIN"THE MACHINE STOPS. SPIN ICON KEEPS ON BLINKING.
Check your drain pump. It is on the front lower side of the machine. There is a small door which opens to it. Unscrew the filter and the pump cover. Be careful when you do this. There is a small drain hose next to it. Use this hose to drain to a pan before opening the filter lid.
Aug 16, 2014 | LG Washing Machines
Stops in cycle, not sure if its when rinsing? I notice it stops and an error code of OE ?
This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
Jun 18, 2011 | LG WM0642H Front Load
Error message to check drain hose and filter..what to do? Have water in the unit
Open the access door at the lower left on front of the machine. Use the hose there to drain the water out of the machine. Unscrew the big knob there and pull out the attached filter. Clean out filter and replace. If filter was clear, replace drain pump motor.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
LG washer getting an OE error. I have opened the pump and drained the water as well as ckeaned the filter...still not working propperly.
OE means your machine has failed to drain within 10 minutes. There are a few posibilities. Your drain hose could be kinked or clogged causing the machine not to drain. Try using a shop vac to remove the water from the end of the drain hose. If a shop vac won't **** out the water either, you have a clog somewhere ing the drain hose, of the hose from the tub to the pump. If it will drain the water you need a new pump. If there is no water in the machine then the problem is either the pressure switch, the hose going to the pressure switch, of the control board. The pressure switch is on the back by the control board. You will see a black rubber hose going attached to it. Remove it and see if you can blow through it. If you cant it is clogged somewhere. If it is not clogged then the most likely cause is your pressure switch and next the control board.
Jan 30, 2011 | LG WM2101HW 4.0 cu.ft. Washer
Where is the serial number on the machine? We have a front loading LG washing machine.
When you open the door it should be on a 2" x 3" white sticker around the door opeing
Nov 09, 2010 | LG WM2101HW 4.0 cu.ft. Washer
What does the flashing OE mean? My washer is flashing OE and the water will not drain after the cycle.
OE means the drain hose is clogged. UE means unbalanced or overloaded. This is decribed in the owner's manual page 31-32. Pull the hose from the back of machine and rinse it out. Then, check the lint filter on the bottom, front left side. Put drain hose back and close lint filter. Unplug the machine, press and hold the start button for 10 seconds to reset machine computer (not the on button...leave machine turned off and unplugged while resetting computer) plug back in, put on no spin and start the machine. It should drain.
Jan 20, 2010 | LG WM2487H Front Load Washer
Lg washer serial # 308kw00211
That OE is really DE (drain error). Open the access door at the lower left on the front of the washer. Drain remaining water using the small hose. (at least if it is not plugged) Unscrew and remove the large knob. Clean out filter. If filter was clean, you may need a new pump motor, or something may have made it past the filter and is jamming the pump impeller. You can remove the pump without taking the front off the machine. Do an "Ask Me" if you need to do that, and I'll give you further advise.
Oct 05, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
108 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
