Question about Whirlpool GB2FHDXWS Bottom Freezer Refrigerator
I have a whirlpool Modle GB2FHDXWSo4-freezer on the bottom. We keep getting ice build up in the bottom of the freezer. Once a week we have to chip the ice out or we start seeing water on the floor.
We keep getting ice build up on the bottom of the freezer. We started seeing water on the floor, but once we started to chip the ice out of the bottom once a week we don't get water on the floor. why is the ice building up on the bottom of the freezer?
Tech007
  • 63 Answers
SOURCE: water in bottom of fridge
THE DRIAN HOLE IS CLOGGED ITS IN FREZZOR IN THE BACK BEHIND THE BACK PANEL BUT YOU CAN LOOK UNDER THE FRIDGE AND FIND THE OTHER END OF THE DRIAN HOSE BLOW AIR TROUGH IT TO CLEAN IT OUT MAKE SURE THE FRIDG IS OFF FOR A DAY, OPEN FREEZOR DOOR TO MELT ICE IN DRIAN HOLE AND HOSE AIR PRESSOR MAY NOT BLOW THE ICE BLOCKAGE OUT DEFROST FOR A DAY THEN IT WILL CLEAN UP NICE
Posted on Aug 30, 2007
  • 1462 Answers
SOURCE: ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Posted on Jul 06, 2008
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
SOURCE: Freezer keeps thawing. There was an ice build up.
Check the "flap" in the door where the ice is released. If it has come undone it will thaw the ice in the maker and into the freezer...
Posted on Jul 17, 2009
louislevel_2
  • 374 Answers
SOURCE: Whirlpool Side by Side Freezer - Ice Build Up in Drain
hi there,
common problem,several factors can be check,check your thermostat setting it maybe too low or you have defective thermostat,if you have good thermostat otherwise the refrigerant charge is to low there could be leak on tube,check your amper rating using clamp ammeter if you got low amper rating recharge freon,but why has low refrigerant there might be leak,repair the leak,before you recharge.hope this solve your problem have a nice day
Posted on Jul 21, 2009
WHY IS MY SIDE BY SIDE WHIRLPOOL leaking water onto floor?
normally caused by a clogged drain in back of freezer . check to see if you have ice build up on bottom of freezer..... gently chip away ice in freezer and turkey baste hot water into drain hole until water flows freely
Aug 27, 2014 | Whirlpool Refrigerators
Jul 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Ice build up
You should to check the Whirlpool Gladiator Freezerator's door sealer to make sure all rubber or plastic seal very well to prevent air humidity come in to build up frost fast. Also, you have to defrost completely and wipe with cloth or paper towel to absorb all waters out and let it dry completely to prevent frost build up.
May 08, 2009 | Whirlpool Freezers
GE Fridge with ice maker. Water is slowly leaking
drain is clogh at the bottom of the freezer
Mar 29, 2009 | Refrigerators
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Ice build up under the freezer drawer
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
Whirlpool refrigerator with top freezer either model GR2 or 9FHTXT will not keep get cold
Sounds like the defrost drain has become iced over or clogged. This is why the ice builds up.
Jan 14, 2008 | Refrigerators
Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Dec 16, 2007 | Refrigerators
Whirlpool GB2FHDXWS Bottom Freezer Refrigerator Logo
146 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
