Question about Pioneer AVIC-D3 Car DVD Player
Sound problem with avic d3 xm and av2 sources
I have an Avic-D3 with a GEX-P920XM unit installed in a 2004 GMC Sierra 2500HD LT came with bose but without onstar. the factory bose amp and sub are gone as well as all the speakers. 2 days ago I replaced the battery in my truck, and since then I have had a problem with the sound from the xm and the aux input on the front (which i plug into the headphone jack on my iphone). Normal AM/FM/CDs all sound fine, but when I switch to xm or av2 the only sound I get is all bass from the subs, if i turn sub off it get no sound at all. I have reset the GEX-P920XM unit via the pinhole reset button, checked the connections cycled the power etc. I get the xm channel information, and can tell there is music playing, but the normal speakers do not get any sound. also in the menu under xm status, it says it is not connected and does not display the radio id. additionally tonight I pulled it out of the dash to check all of my connections. I figured I would disconnect everything to ensure a reset. When I had everything connected and was putting it back in I couldn't get power, after searching I could not find anything loose or disconnected, suddenly it started working again, I thought it had to do with a connection to the door chime module thing so I ensured all those connections were good and taped them back up. the sound for xm and av2 were still messed up but everything else was back to normal. then when I was getting out of the truck I noticed when I turned my truck off and opened the door that the radio did not turn off. the end result was me disconnecting the ACC wire and calling it a night. I suspect that the door chime module is going out. but I don't think that would cause issues with the sound from xm and av2. additional info, I have a toggle to bridge the ill wire and the ACC wire to work as a day/night switch. and I also have the bypass for the e-brake so that a dvd will work without the ebrake on.
PIONEER AVIC D3 - Just had the BT unit installed. I can make and recieve calls BUT I can't hear anything from the caller. They can hear me though and I can hear the phone ring when I get an incoming call...
Who ever installed the BT unit installed it backwards. This is a common problem. To fix it you need to remove the IP-Bus cable from the BT Unit and the D3, and then make sure the colors match. (Blue on Blue at the D3 and Gray on Gray at the BT Unit). That will fix your problem
Mar 09, 2009 | Pioneer AVIC-D3 Car DVD Player
AVIC - D3 Displays that it may be reversed
This happen most of the time when you are switching to rear camera mode. Go in and play around with your source of video and see if it help. Goodluck.
Nov 05, 2008 | Pioneer AVIC-D3 Car DVD Player
How do you unlock the disk
I had the same problem when purchasing mine open box from CircuitCity. But this is how you do it. Pass it on.
While the unit is turned on, press and hold "MENU" and "Back (Track Left)" buttons simultaneously. Next, push and release reset button. Continue to hold "MENU" and "Back (track left)" until the unit reboots.
Jul 30, 2008 | Pioneer AVIC-D3 Car DVD Player
AVIC D3
I might be wrong but I think bluetooth module only work with the Avic Z series. Please let me know if it is compatible with the D3. Thank you.
Mar 30, 2008 | Pioneer AVIC-D3 Car DVD Player
Problems with pioneer avic d3
I have had the same problem here in Australia and i have been told that Pioneer has a software upgrade. So take it back to your retailer and get them to reinstall the new software.
Good Luck
Tony Turner
Mar 10, 2008 | Pioneer AVIC-D3 Car DVD Player
Help...
Look really hard on avic411.com. Goodluck buddy.
Mar 05, 2008 | Pioneer AVIC-D3 Car DVD Player
Pioneer AVIC-D3
Check your EQ setting for each source, sometime on certain unit each source can have it own setting. May be try to reset it by disconnect the battery and reconnect. If you still have a remained warranty, contact Pioneer and send it in for service. Hope that would help.
Feb 26, 2008 | Pioneer AVIC-D3 Car DVD Player
No XM Audio, no fault indication
Buss cable is plugged into the wrong connector on the GEX-P920XM. The installation manual is not clearly written, the figure in the manual is correct.
Sep 22, 2006 | Pioneer GEX-P920XM Satellite Radio...
Pioneer AVIC-D3 Car DVD Player Logo
37 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
