Question about Iview 754TPC with WiFI 7" Dual Camera, Touchscreen Tablet PC
Iview 754tpc cannot connect to hotspot
Connecting to wifi
How do i make my tablet with a crack screen work again
You HAVE to replace the screen. Once its broken, the display might work; but it will loose touch sensitivity.
If you do have a usb jack for your tablet, you could connect a mouse and a keyboard to it and use it using these external input devices.
Jul 10, 2014 | Iview 754TPC Tablet PC
My screen froze
remove the battery for 10 seconds and reinstall again
Jan 12, 2014 | Iview 754TPC with WiFI 7" Dual Camera,...
Tablet reset
Hi ihave kimo tablete but not run & start but reset By power&vol+ key but not reset please help me for install os .... my email h_flightsazan@yahoo.com
or
flightsazan@gamil.com
my site:
www.airship.blogfa.com
Thanks
Hassan
Jan 05, 2014 | Iview 754TPC with WiFI 7" Dual Camera,...
My sons iview 754tpc cyper pad will not charge. it doesnt reconize that the charger is in it?
the charging port may be loose or broken on the inside same thing happened to my phone.
Nov 09, 2013 | Iview 754TPC Tablet PC
How can i fix the broken touch screen of my iview754tpc?
Ebay has replacement touchscreens available for a reasonable price.
Apr 04, 2013 | Iview 900TPC 9" Tablet
My tablet is asking me to sign in with gmail account but my wi-fi is turn off on the tablet so how do i sign in
you don't unless it has a cellular connection you will need to hard reset it/ many devices store this information in the device and can verify the account last associated with the device before it was locked, if you want to be able to recover you information from the device there are several way to hack security codes--Good Luck.
Jan 27, 2013 | Iview 754TPC with WiFI 7" Dual Camera,...
Too many pattern attempts to unlock my iview 754tpc but my wi-fi was switched off so how do i sign back in
only by putting a sim card with a active data connection in the device then attempt to unlock, you can not remotely turn on wifi very easily, may be a bit more simple if you have debug mode turned on but most people don't-Good Luck.
How to reset a iview-754tpc cyberpad tablet
how must i reset the iview 754tpc cyberpad
Jan 12, 2013 | Tablets & eReaders
Iview 754TPC with WiFI 7" Dual Camera, Touchscreen Tablet PC Logo
125 people viewed this question
Top Iview Tablets & eReaders Experts
Are you an Iview Tablet and eReader Expert? Answer questions, earn points and help others
