Question about HP IBM 42T0181 THINKPAD X41 1.6GCPU 512MB RAM MOTHERBOARD
Need more ram - HP IBM 42T0181 THINKPAD X41 1.6GCPU 512MB RAM MOTHERBOARD
  • HP Master
  • 3,606 Answers
ThinkPad X41
Standard Features
This ram module, can bought in a computer store, or in a online shop. I recommed 2 gb, for better perfomance.
A computer repair shop can help you change the ram module.
This ram type cost around 100 dollars each.
More info here:
http://www.thinkwiki.org/wiki/Category:X41
LENOVO has the support for your pc:
http://support.lenovo.com/en_US/downloads/default.page?selector=expand
At this site you can find more files, like drivers and the manual.
Good luck
Posted on Jan 10, 2013
My motherboard doesnt work...damn it!
The RAM module/s may be faulty or need reseating.
When you reseat the RAM and the computer still does not boot up then remove the RAM and take them to your friendly computer repair shop and get them to test the RAM for you. If the RAM is faulty then you need to replace the RAM.
Jun 09, 2011 | Computers & Internet
Tip
Ram upgrades
This is a tip explaining exactly what you should keep in mind when you want to upgrade your ram modules in your Desktop computer. This will also act as a guide which will give you step by step instructions on how to replace the ram module.
Firstly, before we start buying, we need to be sure that the upgraded ram modules are compatible with your motherboard. Here are a couple of tips you need to keep in mind.
Frequency:
You need to have a look at the frequency of the ram you are using at the moment, as well as the supported frequency of your motherboard. If your motherboard is compatible with a higher ram frequency than your current ram, you can use the frequency which the motherboard stated as maximum for optimum performance. Remember, if yu want to add ram modules, all ram will be downgraded to the ram with the lowest frequency.
Ram model:
You need to know if you are using DDR, DDR1, DDR2, DDR3 ram, some motherboards supports both DDR2 and DDR3. If your motherboard does not support a certain model, it will not fit in the slot on the motherboard, hence, it will be useless. Thus, you need to have a look at the ram model supported by your motherboard.
Latency:
Lastly, you need to have a look at the latency of the ram. The lower the latency, the better the performance.
After you have bought the new upgraded ram modules, we can install them. The following steps will guide you through the installation process.
Step 1
Shut down your computer and unplug all cables. Also, you need to take of the side panel of your computer. Remember to stay grounded at all times when you start working with the hardware of your computer.
Step 2
The second step will be to either take out the current ram modules to upgrade them, or insert the new ram modules into the other available ram slots on the motherboard. Remember to keep yourself grounded at all times while touching the any of the computer hardware. Also, handle the ram at the length end at all times, not at the width end. There will be 2 small hinges on both sides at the base of each ram modules end. You need to pivot the outwards before the ram module can be removed or inserted.
Step 3
The last step will be to screw back the side panel after you have inserted the ram modules(Be sure that you remember to clip back the hinges to ensure that the ram module is places in correctly. Never force the module, line up the ram module with the slot on the motherboard.) Also, plug back all cables into the Computer case, and enjoy your handwork.
At the links below you will be able to have a look at sme competative prices on ram modules.
http://www.crucial.com/
http://www.kingston.com/ukroot/
http://www.upgradecomputermemory.com/
http://www.memory-up.com/Memory/GatewayPerformance.html?gclid=CJesovOPiaACFaFi4wodjBrVkQ
Please let me know if you have found this to be helpful.
Kind regards
Andrea
on Feb 23, 2010 | Computers & Internet
Is it possible to install windows vista in this computer?
No, it needs at least 1GB of RAM and a much better video card.
Jan 16, 2011 | HP Hewlett Packard Compaq D51S Intel...
Slow computer with 256 MB,
efore you make any purchases, you need to know how much memory you have and what type of memory to buy.Find out how much RAM your computer has:
Windows 7
Windows Vista
In Windows XP, go to the Start menu, click Settings, and then click Control Panel. Click System and then select the General tab. At the bottom of the page you should see the amount of RAM.
Most games will specify the minimum amount of RAM you need to install them and play. For example, Harry Potter And The Prisoner of Azkaban requires 256 MB. This amount includes RAM that the computer needs to do its own background work as well as to run the game.
The amount of RAM you need depends on the operating system you are using. For systems running Windows 7, Windows Vista, or Windows XP, you will need the minimum recommended amount, but more is often better, depending on your needs. If you just use your PC for surfing the Internet and writing letters, you need 512 MB to 1 GB. For more RAM-intensive programs, such as games or photo editing, or if you like to use a lot of applications at the same time, such as desktop publishing and video rendering, more than 1 GB is recommended. Each program should come with system requirements that show both the minimum RAM needed to run the program, and the amount of RAM needed for its best performance.
RAM modules can be purchased in a variety of sizes.
Figure out what type of RAM you requireTo determine the maximum amount of RAM your computer can handle as well as the speed, consult your PC's owner's manual, which should show you the number of slots (the place where you insert the RAM), how much each can take, and the maximum your system can use.
May 14, 2010 | IBM PC 300GL PC Desktop
RAM QUESTION!!
Greetings my friend, regarding on your problem you will notice that if your computer/Laptop need to have additional RAM when your computer runs a program large enough to consume your RAM. You can add RAM anytime if you want to make your computer runs/loads program faster. RAM is used as a temporary storage of your running program or software so therefore if you have a large size of RAM then you can load large and lots of programs in your computer/Laptop with out experiencing log or slow in executing some of your request programs or applications. Also if your current RAM is not functioning well just like it is always restart your computer or dumping some programs and continues beep sound of your System Unit when you restart your Computer then that's the time you need to have a new RAM for your Computer/Laptop.
Jun 16, 2009 | Dell Inspiron 1521 Notebook
Beeping on start up
Your motherboard has 64Mb built-in RAM and the video card needs some video RAM and has grabbed 8Mb of RAM which leaves the system with 56Mb of RAM. When you insert a 64Mb RAM module you have a total of 128Mb of which the video has grabbed 8Mb which leaves the system with 120Mb.
You can't change stop the video card from grabbing 8Mb of RAM, the RAM is essential for the video to work.
You can upgrade the RAM by removing the 64Mb RAM module and insert a 128Mb or 256Mb RAM module. You may even be able to insert a 512Mb RAM module if the motherboard will accept it, you need to check the specification of your laptop to see the maximum amount of RAM the laptop can handle.
May 21, 2009 | Compaq Evo Notebook N150 Notebook
I have an ibm a20m 700 speed. installed 2 256 ram does not work
I REALY DEPENDS HOW MUCH THE VENDER SET THE SOFTWARE AND HARDWARE WILL SUPPORT
MY NEW LABTOP HP DV9000 CAME WITH 2GIG
AND THEY SAID 3GIG OKAY BUT WE RECOMMAND 4GIG RAM BECAUSE YOUR VIDEO RAM SHARE THE RAM UP TO 799 MB
RAM, SO SHARE VIDEO RAM AND MEMORY RAM, WHEN ALL IN DONE AND THE COMPUTER DOES ALL IT CALCULATION IT SAYS I HAVE 2-3GIG RAM AVAILABLE TO RUN OTHER SOFTWARE
ALSO WHEN YOU GO TO PRICE IT 1-2GIG CHIP MAY COST 50-100.00 DOLLARS
AND A SET OF 2-2= 2 PEACE OF RAM EACH ONE HAS 2GIG OF RAM
A SET MAY COST 40-140.00 DOLLARS
YOU NEED TO KNOW IF YOU NEED DUAL CHANNEL
PARITY AND NON PARITY
ASK ALOT OF QUESTIONS FROM THE VENDER FIRST
THAN GO TO WWW.FRYS.COM
RODGANDYSR
Jan 25, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
1024 RAM
You will need to remove the 2-512MB ram that are installed on your computer and buy 2-1GB sticks. There is no other way around this. Download CPU-Z program to find exact memory module needed before you buy the wrong one. Good luck.
May 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
I need Acer g710 Ram
If you need Ram, you need to contact your server manufacturer to find a product number for your server and memory model/size.
You can add up 16GB of RAM DDR2.
Many manufacturers also provide compatible memory like Transcend or Kingmax.
Can i help you with anything else ?
Mar 29, 2008 | Acer Altos G710 Server
HP IBM 42T0181 THINKPAD X41 1.6GCPU 512MB RAM MOTHERBOARD Logo
56 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
