Question about Dell Dimension 9200 PC Desktop
Error !! Oxc0190036 !! 5259/88123 (sidebarLock.dat)
Running windows vista. When I turn the PC on I get the screen that asks me if I want to run in safe mode and what not, it shortly goes to the screen that is all black with "!! Oxc0190036 !! 5259/88123 (sidebarLock.dat)" toward the top of the screen. I purchased windows vista to fix this issue but when I put the disk in the system there is no response from my computer on the monitor.
  • Dell Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps. Hope it helps.
Posted on Jan 10, 2013
ronaldsuboc
  • 449 Answers
SOURCE: Computer goes to blue error screen 0x000000FC
Hi!!!!!
try to open up the tower
check the ram of your computer
try unset it and clean
and put it back properly!!!
if it is happen again!!!!
and try re-installe your video card
and if it is happen again!!
try to diagnost or surface scan of your harddisk if it has a badsector
it it is happen again try to reformat your
your operating system if you know how
to format and buck up all the files that u need
and if it is happen again in again
try to replaced your
Ram must be on the same speed or borrow from your friends
or
the hardisk may be had a bad sector try to bowrrow from your friends
try it!!!!
good luck
Posted on Sep 20, 2008
Teis
  • 340 Answers
SOURCE: my sons dell e520 wont
Have you tried to put a disk in the floppy drive when it starts up?
It probably had a disk in before last close down, and is looking for it now when you start up.
Please vote if this was helpfull :-)
Posted on Nov 29, 2008
  • 18 Answers
SOURCE: trying to restore dell 4400 and cannot get to a dell screen for f-12
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
Posted on Dec 06, 2008
Fixe_You
  • 1800 Answers
SOURCE: Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
Posted on Feb 06, 2009
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
Posted on May 14, 2009
When I turn on my laptop it goes from the Dell Logo page to the black screen that says Windows Error Recovery. I've tried the steps they told me to take but nothings work I do not have the system
turn on your computer, and while its booting up, keep pressing f8 till you get to the dos screen, and choose safe mode. lets try to run your pc on safe mode
Mar 22, 2013 | Dell Inspiron 1545 Notebook
Windows vista forgot password
WARNING if u want 2 play sims with vista well too bad becuz sims duznt work on vista so good luck with dat
Jan 24, 2012 | E-Machines eMachines Desktop PC
C:/Progam Files/blocktards/unins000.dat what is this error and how do i fix it
Hello crouch8323,
Welcome to FixYa.Com!
Unins000.dat is a files that if used by Blocktards' uninstaller to properly uninstall Blocktards off of your Desktop. If your are trying to uninstall Blocktards and you are getting an error message, I recommend that you uninstall Blocktards from the Control Panel's Add & Remove Program (for Windows XP) or Programs & Features (for VISTA or 7). If you still have the same error message, you can also try uninstalling Blocktards by going to the Start Menu, All Programs, Blocktards, and click Uninstall. If these steps give you the same error message, you may need to use Blocktards installer to uninstall the game, see if running the installer gives you the option to modify, remove or repair. And if all else fails you can always use a 3rd party uninstaller software like the option found in CCleaner.
Regards,
Deathschythe33
Aug 22, 2011 | Computers & Internet
We have a Gateway Laptop running on Vista. Turned it on this morning and got the "blue screen of death" that said it had a Fatal Error KnownDLL 000021a and a bunch of other numbers. We read that...
Just press and hold F8 on startup (before the Windows logo appears). You should get the screen with the title Advanced Boot Options and the following menu. (which I get on my Gateway NV5915h)
Choose Advanced Options for: Vista (Windows 7 on my Gateway NV5915h)
(Use the arrow keys to highlight your choice.)
Repair Your Computer
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Directory Services Restore Mode
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Start Windows Normally
Description: View a list of system recovery tools you can use to repair
startup problems, run diagnostics, or restore your system.
ENTER=Choose ESC=Cancel
Mar 18, 2011 | Computers & Internet
Laptop turns on but windows wont load. i ran diagnostic check and got error codes. error code 0f00:0244 uncorrectable data media or media is write protected
Please let us know which windows you are running and you mentioned that it doesnt load windows so doesnt it give you any message.
Also, Please try turnning on the pc in safe mode and let us know if its booting up there? Please follow the steps below.
1. Shutdown the pc.
2. Turn on the pc and as soon as you turn it on tap F8 key on the key untill you see advanced boot option.
3. Use the down arrow key on the keyboard and select safe mode with networking and press enter.
4. If it ask to select windows select windows and press enter.
5. It should show you the drivers loading window and then it should show you the normal screen with big icons.
Please let us know if it works and send us exact error and which windows (xp, vista)
Rashish
Aug 16, 2010 | Dell Inspiron 1000 Notebook
I have a dell inspiron lap top with window's vista. There is a problem with it. Even when I turn it on with safe mode it goes to the log in screen, then says welcome, and then it goes to a black screen...
Usually what happens with my Dell Inspiron desktop, even on safe mode it goes to the logon screen. I have never experienced that with my Dell Inspiron 1318. When you log in and it shows you the black screen, try pressing the function buttons. Try F8 or F12. You should be able to start the computer in Safe Mode. If possible, enter Safe Mode with Networking so that you are able to search the web. If you don't mind me asking, why is it that you need safe mode? Is it a virus?
Aug 08, 2010 | Dell Inspiron 1318 Notebook
I have an Acer Aspire 6530 running Windows Vista and today it started shutting off at random. When it shuts off the bottom 2/3 of the screen has blue stripes across it, and on the blue is text I cannot...
Good question.
Does the computer feel hot when it shuts off?
Does it always happen at the same exact time?
Can you try booting the computer into Safe Mode? (What Happens?)
First thing I'd try is uninstalling the video adapter driver under device manager and restart the computer.
Let me know what happens!
May 20, 2010 | Acer Aspire 6530-5143 Notebook PC
Safe mode
Get windows 7, or downgrade to xp. lol kidding. During the start up, i beleve its either f11 or f12 press them it should bring you to a boot screen. follow option. or you can use the compaqs built in recovery system. reinstall your system. vista has a option to save its old files for transfer.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
My gateway laptop doesn't boot up correctly. When I turn it on everything seems fine but then it goes to a page that says configuring updates 3 of 3 then restarts and does the same thing over and over. I...
Hello and thank you for using Fixya's services.
Are you running Windows XP or Vista?
It sounds like the Windows updating has caused a problem in your operating system.
If it is windows Vista, press F4 right when the comuter comes on. Instead of choosing safe mode, choose advanced options. This will give you a screen to do the windows restore.
Please let me know if you have any questions.
Nov 20, 2009 | Gateway MT6821 Notebook
White screen on Windows start.
this might be an issue with a corrupted settings on the windows normal mode. try doing msconfig on safe mode and uncheck everything on startup. if this wont fix it, reinstall windows.
Sep 17, 2009 | Computers & Internet
Dell Dimension 9200 PC Desktop Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
