How to format my wd passport0740 without loosing my pictures and documents
When i connect it to my lop top it recognized it but immediately it says to format it
  • 6 more comments
  • umagania
    umagania Jan 12, 2013
    it didn't work the disk check could not be performed because windows can't access the disk
    then i removed my drive and put it to drive G it told me its not accessible it say DATA ERROR [cyclic redundancy check
    then it says to format drive so i can used it
  • Brian Sullivan
    Brian Sullivan Jan 12, 2013
    The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access. The root of this problem could either be a damaged storage device or a corrupt file. Click on the "Start" menu in the bottom left-hand corner and click "Run." Type in "cmd" and press "Enter" on your keyboard. This will open a black command prompt box.Type in "chkdsk /f" and press "Enter." If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu. Wait for the disk scan to reach 100 per cent. This may take awhile. When it completes, your drive errors may be fixed. Avoid future problems with this type of error by replacing the file that caused the problem. For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time). Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
  • umagania
    umagania Jan 13, 2013
    i did what you told me i typed "cmd" it did open a command prompt box when i typed "chkdsk/f" it said access denied as you do not have sufficient privileges. you have to invoke this utility running in elevated mode that's what it told me thanks for you trying to help i really appreciate it
  • Brian Sullivan
    Brian Sullivan Jan 13, 2013
    computers administrator ? You have to be the computers administrator to change any values on any hard drive on your computer.Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
  • umagania
    umagania Jan 14, 2013
    i am the computer adminisstrater and have full control i repeated the steps and still tells me access denied do not have suficient privilige it says i need to invoke this utility running in elevatyed mode
  • Brian Sullivan
    Brian Sullivan Jan 14, 2013
    which operating system ? sorry if its not your primary drive you might have to right click on this drive it could be E: or F: if its not your primary drive click start all programs windows explorer right click on your drive select properties tools check now tick in one box to automatically fix files
  • umagania
    the drive is local "G" so i right click on it select properties before i go to tool i checked the general on my drive t he little box is blue it says 0 bytes the other box says 0bytes also and capacity 0 bytes so i go to tools click on check now it says disk could not be performed because windows can't access the disk
  • Brian Sullivan
    can you acces the drive in disk management ? click start control panel administative tools computer management disk management your drive might need a drive letter to be alocated if windows cant access it right click select new letter or something similar depending on your operating system
  • Computers & ... Master
  • 27,725 Answers
Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box I have found better results ticking the first box then reurn and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have full control in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Hope this helps
Posted on Jan 10, 2013
How can Western Digital hard disk drives be recognized by third party USB external docking stations?
The format on a disk, will not be relevant of recognition via an USB connector. To connect a drive via USB, the computer must have the correct driver for the hardware you are connecting. Be sure you connect the HD coerce to the external harness and make sure it is supplied with the correct voltages.
When you connect a working system on the USB connector and the drive does not have a format, the computer will see that and ask you if it should format the drive.
Mar 04, 2015 | Western Digital Computers & Internet
Western digital my book data recovery
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. So really, you need to act quickly.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
May 08, 2012 | Computers & Internet
Unable to use with Windows 7. Are there any updated drivers?
if the drive is formatted correctly the device should be functional without the need for additional drivers. make sure the device is recognized under the hardware manager. if not the device might need to be initalized and formatted.
Mar 23, 2011 | Western Digital WD Passport 250GB Portable...
WD WD1200B008-RNN not recognized by laptop/desktop
I had a similar problem with some other brand of external drive. I disconnected it without being stopped and then nothing would recognize it. It was new when this happened, I contacted the manufacturer and they sent me a files with software and instructions to recover it. It was not that easy since I'm no computer geek, it took quite a while but finally the drive worked again. Info was lost since I had to formated it, can't remember exactly is low level formatting but alive again.
Also try to go to my computer icon on the desktop and right click, go to "manage" there you'll see an option for disk management, there you might be lucky and make it work again.
Hope this helps, regards.
Feb 14, 2010 | Western Digital 120 GB USB 2.0 Hard Drive
Cant format my Hard drive to work with mac and pc
Unfortunately when you format a hard drive it deletes anything on it so if you did this after putting the documents onto it they are now gone.
Jan 30, 2010 | Western Digital Passport 320GB External...
My computer recoginzes that the drive is connected because the WD icon shows up in the tray, but the drive does not show up in "my computer" as a drive. I have a Western Digital 5000 Essentials external...
You might have to go in Administrative Tools, Computer Management, Disk Manager ... from the Control Panel - and then Format that disk before it will be recognized as a Letter drive like D or G or something like that.
I have a WD and another brand of external drives. And I had a similar issue with the 2nd one - I had to format it 1st.
A customer of mine formatted a drive for Mac OS X and thus cannot use it in WIndows. Mac can read NTFS from Windows I believe, but Windows cannot read the Mac OS X format.
Nov 23, 2009 | Western Digital My Book Essential Edition...
My WD 250GB passport portable hard drive is not recognized
If your system detects the connected device that is a good start. Was the drive formatted for another operating system? Certainly try the drive on another system and/or another drive on your system.
Aug 26, 2009 | Western Digital WD Passport 250GB Portable...
WD 1TB Hard-drive, worked perfectly now it won't :'(
If you go into Administrative Tools, Computer Management, you will see a tree for disk management. It should be listed there - probably without a drive letter..
You can partition and format there.
To get to administrative tools: Go into your control panel - click on classic view and it is one of the top options.
Jul 12, 2009 | Western Digital Elements powered by WD 320...
Driver scanner benq 3300u
If you have a BenQ Scan to Web 3300U, just plug in the scanner to your USB port on the computer and plug the power into the power bar. XP will recognize that you have connected the scanner to your pc. It will install the scanner immediately.. Go to MY PICTURES. The top option on the left hand side of the screen will be "to obtain pictures from a scanner or a camera". Click on this.. It will tell you that you have a flatbed#23 . Click on next. Using the preview button, scan the document. Using your mouse, make the scan box fit your picture or document. Then click on scan. Save your scan job . You can then view your scan job.
Dec 24, 2008 | BenQ Scan to Web 3300U Flatbed Scanner
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
