Question about Fujitsu 24C1 Air Conditioner
Control seems to be working but unit not responding.
I have a Fujitsu AOT30RB split ac and the unit has been starting to not respond to the control, I hav changed the batteries and and took many trys to turn the unit off yesterday but today it wont respond at all. Thanks Snez.
  • 1 more comment
  • jenniferturn Jan 21, 2009
    I have two split pack a/c's in my house and neither respond to the remotes!! I have replaced the batteries. Any suggestions? The remotes appear to be working.
    Thanks,
    Jennifer
  • Anonymous Mar 19, 2014
    Compresor turns wont turn on. And when it does it turns back off
  • Carmen van Heyningen
    Carmen van Heyningen Apr 09, 2016
    I had the same problem with my remote. What happen is that the remote build up dust in side. To fix this problem you have to open the remote by unscrewing all the screws on/in the remote, even the screws that have the motherboard in place. Use WD40 and a dry cloth that will not leave any residue to clean the motherboard. Spray the WD40 on the cloth, not too much, and wipe the motherboard as if you are polishing it, wipe everything on the motherboard gentle. Then you remove all the push buttons (start/stop and the other buttons) on the remote and clean them also, even the slot and wires where the batteries sit. When you are done cleaning put everything back where they belong and your remote should work like new.
  • 236 Answers
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Posted on Jan 21, 2009
ASTA12JEC Fujitsu Air Conditioning unit. Dear sir or madam. My air conditioning unit is no longer responding to remote control but stays on. It used to work fine then one day it stopped responding.
Start by replacing the batteries to your remote control and make sure there is nothing blocking the IR receiver on the unit itself. If that is blocked by something hanging on it or tape over it from something hanging on it previously.
Jan 31, 2015 | Fujitsu Heating & Cooling
Where is the infrared receptor card in this equipment to change it. I have a split ac panasonic CS C24BKP and does not respond to remote control. I know the remote control is good because I saw thr...
There is a receptor on the below the front pannel but the problem could be :
1.Low battery charge in the remote control.
2.The signal cable that connects the receptor to the card(pc board) could be loose/disconnected
3.Try one receptor from a working unit
4.Try a remote control from a working unit
Regards,
Adamson
nyauadamson@gmail.com
May 02, 2014 | Heating & Cooling
AC power light blinks but not starts
The outside unit has a problem. Have it tested.
May 05, 2017 | Hitachi Heating & Cooling
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
We have a chunghop universal remote a/c Q-988e and are trying to locate the code for our fujitsu split system
Check in book let supplied along with your universal universal remote. If not listed, in your remote set and then press , or one by one press, still your unit responds. Where it responds, it's your code. Keep remember.
Jan 03, 2011 | Heating & Cooling
The remote control is working but the ac does not respond. How can I fix it. The AC starts manually. Thanks
Replace new battery and try. If still problem try with another remote of same. If problem remain same, the problem with your receiving sensor in PCB.Repair it.
Dec 19, 2010 | Sanyo Split System Air Conditioner
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
Have model ASTB24LDC/AOTS24LDC Inverter Fujitsu split system. As of Thursday 11th Nov, unit stopped working. Won't respond with remote. An electrician came to test it this morning, says there is power to...
I have same problem like yours to my newlyinstalled Fujitsu multi-split system (the first time use since system installed1 week ago). I rang the electrician whodid the installation; he said it must be the units themselves nothing to dowith electricity. Okay, then I rang Fujitsu and their local service agent. Theysuggested me to switch off C/B for an hour to reset the units. I followed theinstruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired tothe outdoor unit). So I used a multi-meter to test the power terminals of indoorunits (Danger! If you have no idea about this, don't even try! ): it seemed nopower supply even C/B is on. I turned to the isolator which next to the outdoorunit. The isolator was making arcing noise when I switched it on and off. Theindoor units suddenly turned on for few minutes then died again. So I figuredout the problem is that crooked isolator. I called the unhappy electricianto replace the isolator. End story....
I hope my experience will give a littlehelp to you...
Nov 13, 2010 | Fujitsu 24C1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
1,360 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
