Question about KitchenAid KBMC140HSS Convection/Microwave Oven
Where is the light bulb in an emerson mico wave
  • KitchenAid Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
Either way, see these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 10, 2013
What kind of light bulb for an Emerson Microwave, MMWG9115SB?
Normally, small Edison Screw (ES) cap, and 25 watts appliance bulb. Take the old one out and look.
Feb 15, 2017 | Emerson Microwave Ovens
The light bulb in my emerson 8997B stopped working. It had come backThe light bulb in my emerson 8997B stopped working.
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Dec 16, 2012 | Emerson Black Microwave Oven
My mico wave has stopped working, a tin fell from the cupboard onto it and now it wont heat up...can you help please
Without you taking the cover off and looking at any damage all I can suggest is the services of a microwave engineer is required.
Hope that helps.
Feb 26, 2011 | DeLonghi Microwave Ovens
My problen is the mico is just a tad over one year old and the timer is working and the light is on inside, but tray is not turning and it is not heating up, could it be a fuse?
I would think it possible.
Remove the outer cover when the machine is unplugged and follow the mains lead in through the rear panel. There should be a couple of fuses nearby.
Always use the correct value fuse of identical type and size!
Hope that helps.
Feb 18, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
How to change a light bulb in a emerson mircowave model mw8115ss
If this is freestanding m/w:
1. disconnect from outlet
2. take the cover off.
3. light bulb located on right upper corner.
Nov 30, 2008 | Emerson Black Microwave Oven
I have a emerson micro wave. Its only been used lightly for 3 months. It just when dead no power at all, no lights.
If you bought it only 3 months ago, it should be fully under warranty.
I would suggest you let Emerson repair it for you at no charge.
Get help locating a servicer or parts at 1-800-695-0098.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 06, 2008 | Microwave Ovens
KitchenAid KBMC140HSS Convection/Microwave Oven Logo
19 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
