Question about Sharp Aquos LC37D44U 37 in. LCD HDTV
White dots and lines appear on my sharp aquos tv
  • 103 Answers
SOURCE: Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Posted on Mar 05, 2008
  • 33 Answers
SOURCE: Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Posted on Feb 19, 2009
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
rustym62
  • 201 Answers
SOURCE: My (sharp aquos lc 52d62u) tv fell to the ground. Image of broken glass and colored lines appear
Unfortunately the panel is cracked internally can't can't be repaired the whole panel has to be replaced. most times the panel will cost as much as you paid for the set. My son cracked ours when it was only 3 weeks old it doesn't take much force to ruin one.
Rustym62
http://www.the-tv-dude.typepad.com
Posted on Apr 26, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Sharp aquos has railroad looking static lines horizontally from top to bottom
The circuit board that is nearly in the center of the TV with a metal cover and 2 flat ribbon cables on it is bad.
Feb 17, 2014 | Sharp AQUOS LC-55LE620UT 55" LCD TV
My sharp aquous tv has white lines running vertically like a pin-striped suit.
my 32 inch sharp Aquos has white lines running in the background of the screen
Jan 28, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
My 42 aquos lc-42d62u is just over 3 months old.Last week the screen had many white dots appear but they went away the next day.Now I have blueish lines moving across my screen.They have been on all day...
With a new unit like this call Sharp at 1-800 BE SHARP and they wil refer you to an authorized service center to get this resolved under warranty.
Apr 13, 2008 | Televison & Video
Feb 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
52 inch aquos sharp tv, d9 model
There are 4 settings for the TV like zoom, stretch, smart stretch, and dot by dot... I personally like dot by dot it has the clear and fitted picture that you might want... Especially with HD chanels put it on the dot by dot setting...
Dec 28, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC37D44U 37 in. LCD HDTV Logo
135 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
