Question about Canon Eos Cameras
Got the cannot playback image
Fuji Finepix S5700 digital camera. LCD green-pink
try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
Dec 18, 2007 | Fuji FinePix S5700 Digital Camera
Full screen not displayed when viewing shot and playback
You mean that the image you take and playback is in 4:3 ratio. The default settings is 4:3. However, if you want to take widescreen (16:9 full LCD) images, just change the Image Size setting in the menu to 16:9 L (4288x2416 pixels) or 16:9 S (1920x1080 pixels). See the user manual page 30.
Oct 23, 2010 | Olympus SP800UZ Digital Camera
Problems trying to play back images on my CF card
Sometimes if you take the card from the camera to the computer and the computer rotates the file from landscape to portrait it will no longer playback on the camera.
Aug 05, 2009 | Canon EOS 40D Digital Camera
Nikon D90 Image playback Mode
Hi - My D80 allows the length of time the the image displays to be set using the menu system. You shouldn't have any trouble setting this. Mine can be set from 5 sec to 10 minutes. Lookup Monitor-Off in your manual.
Apr 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
How to turn off "highlight" image display on D-80
This happens when you accidentally press the up or down button when viewing images on the playback. If you press up or down a few times it goes to a screen that looks like normal playback but with the flashing highlights.
All you need to do is press up or down until it goes back to the normal screen.
Hope that helps!
Dec 25, 2008 | Nikon D80 Digital Camera with 18-135mm...
Dark playback image
It could be that the subject is too far away. so just Move closer to the subject.
Sep 15, 2005 | Toshiba PDR-M3 Digital Camera
How long does a fully charged battery last?
Approximate number of recording images : AA size Alkaline batteries: 240 frames *1 AA size Ni-MH batteries (2500mAh): 420 frames *1 Test condition Conforming to CIPA(Camera & Imaging Products Association): *1: LCD monitor on, Full-size images: 2560x1920, Standard image quality, No instant playback, Flash used with 50% of the frames, No full-time AF, one image at every 30 sec., turning the power on/off at every ten images. Approximate period of playback images: Test condition Based on Konica Minolta's standard test method: AA size Alkaline batteries: 240 min. AA size Ni-MH batteries (2500mAh): 330 min. *Since the performance may vary depending on conditions, recording mode, and subjects, these are approximate values only.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Playback modes
There are playback modes such as single-frame, Index (you can select the number of frames to display on the monitor from 4, 9 or 16 frames), Close-up (2x through 10x magnification), Slideshow (display the stored images one after another in succession) or playback images by rotating.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Cameras Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
