Question about Hitachi Televison & Video
The LED TV is in burn mode
There is a Burn Mode highlight at the centre top of the TV. Then I cannot control the TV with or without the remote ie cannot turn the volume up or down, cannot off the TV with the remote and had to switch off the TV manually
techman
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
  • 93 Answers
SOURCE: would like to switch tv mode to cable mode
go to the menu button,press it, in menu service you to choice either air or cable. then select the cable
Posted on Nov 07, 2007
SOURCE: Power comes on then goes back off.
A tech wants to charge $89 just to troubleshoot. So how much will convergence cost?
Posted on Dec 15, 2007
Joe fix
  • 7 Answers
SOURCE: vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Posted on Jan 14, 2008
  • 31 Answers
SOURCE: I have a philips Matchline
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Posted on Mar 08, 2008
Screen keeps changing colors and will not show picture
hi is it flashing red blue green, if so the tv is in screen burn mode, just press menu on the remote retune the tv, what is the model number of the tv you may need to go into the service menu turn screen burn mode off, thanks
shaun
Feb 25, 2017 | Televison & Video
How to exit burn mode on a QBell TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 19, 2015 | Televison & Video
Which board is it
hi this is screen burn mode, press the menu button on the remote to stop it you may have to retune tv back in, if this don't work, you will need to go into the service mode and turn the screen burn mode off,to do this press menu on the tv and menu on the remote, you should see another screen pop up, select screen burn mode to off if the first sequence don't work try ok on the tv and ok on the remote, thanks
regards
shaun
Mar 25, 2015 | LG 37LG60 37 in. HDTV LCD
How to reset sinotec tv without remote control
Without its remote control, you can't select its inputs.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 13, 2014 | Televison & Video
Technika lcd42 207 stuck in burn mode red blue green screen repeating over and over no other functions
Do a hard reset to this set, and check. Unplug the TV from AC wall outlet, and re-plug it back after 20 minutes or so. This must make it a hard reset. If it do not help you, you have to enter its service mode option, to release the burn in mode. To get more details, http://electronicshelponline.blogspot.com/
Nov 16, 2013 | Televison & Video
Matsui m32lw509
No There is no other way to get into its service mode, without its original remote control. Contact the authorized service centre for Panasonic to buy an original remote control.
Jun 30, 2013 | Televison & Video
Can't get closed captioning to work on westinghouse 46" 4680 led tv
What is the video source? Some set-top boxes send a closed caption signal that doesn't match the TV's CC interpreter. For those devices, you need to enable the captions on the set-top box.
I know how to enable captions on one particular Dish satellite box. The steps will depend on if your TV is TV1 or TV2 connected to the box. If the TV is TV2, you need to set the box in Single mode (so both TVs are set to the same channel). This is done with the Mode button on the box itself (highlight Yes and click Select using the Dish remote when prompted to go to Single Mode). If the box is in Single Mode, you won't get a prompt but the unit will go to Dual mode. There is a small LED on the box to indicate Single or Dual mode.
Next press Menu on the remote and go to Properties (9). Click Select and then navigate to Closed Captions (6). Click Select. Go to the Closed Caption On/Off line (1) and press the left arrow and then the up/down arrow to set to the captions to On. Press the right arrow and then Select with Done highlighted. Exit the Menu by hitting Cancel repeatedly.
I hope this helps.
Jul 24, 2012 | Westinghouse Televison & Video
How do you put the tv in game mode without a remote
Follow the steps below to switch your TV to game mode without using the remote:
1. Connect the game system to the TV using the AUDIO/VIDEO inputs on the FRONT of the TV.
2. Switch the game system on.
3. Press the "MENU" button on the front of the TV
4. Use the "CH" UP/DOWN buttons on the TV to highlight the "PICTURE" option. This is the first option so should already be highlighted.
5. Press the "VOL UP" button to select this option
6. Use the "CH" UP/DOWN buttons on the TV to highlight the "GAME MODE" option. This is the first option so should already be highlighted.
7. Press the "VOL UP" button to change the GAME MODE setting to "ON"
The TV should automatically switch to GAME MODE if you are using the inputs on the front of the TV.
8. Press "MENU" to exit and play your games.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 06, 2010 | Sylvania 6427FF TV
Tv/video mode with no remote
you should have a menu button on the
frount of the tv press it and then select
with the (ch up) (ch dn) to highlight the
input/sorce or ant select with the enter
button then (ch up ) ( ch dn) highlight
video 1 or 2 press enter .
If this was not helpful tell me the
model # and look it up on my data base.
Rob
Sep 21, 2009 | Microsoft Xbox 360 Console
Benq monitor flashes primary colours when switch on or off
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Dec 10, 2007 | BenQ FP71E 17" LCD Monitor
Televison & Video Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
