Question about Tilia FoodSaver V2240
Foodsaver model v440 will not vaccum - Tilia FoodSaver V2240
Need to replace the heat stripe tape on my tilla foodsaver vaccum sealer
concerning my food sealer: the strip under the heating wire came loose & would not stay in place. i almost threw the unit away but its at least $40 to buy another. i decided to buy a roll of PTFE Coated Fiberglass Fabric With Silicone Adhesive Tape. PTFE is Teflon but u cant use Teflon as a search term because of the copyright. i found a roll on ebay for $3 (free ship) from China (how do they do that!). it took about 2 weeks for the roll to arrive. I cut a strip to fit under the wire. The wire had burned & partially buried itself in the unprotected plastic. Be gentle when nudging it out & clean off any material that has attached itself to the wire. Seals & works like new!
would you like to buy the rest of the roll? the roll has about 28 feet left.
Dec 27, 2012 | Kitchen Appliances - Others
Foodsaver tilia v3240 manual
There does not seem to be a manual specific to this model. There is an extensive description of the product available on Amazon.com including a demo video.
See here:
http://www.amazon.com/FoodSaver-V3240-Vertical-Vacuum-Sealer/dp/B003U738ZE
You may also find one of the manuals from the 3000 series to be helpful. These and FAQs are available here:
http://www.foodsaver.com/manuals.aspx?cid=1177
Trust this is helpful.
Apr 16, 2012 | Tilia FoodSaver V3240 verticle vacuum food...
Trying to find a gasket for ......food saver vac 820
Replacement parts for the Tilia Foodsaver products can normaly be found here:
http://www.foodsaver.com/parts.aspx?search=420
However I am having trouble with your model number. Are you sure it is correct?
Suggest you inquire with the company as to which listed model would be compatible with your model . You may contact them over the web here:
https://secure.foodsaver.com/contactus.aspx
Aug 14, 2011 | Tilia FoodSaver VAC420
My sealing gasket is broken and it will not seal my food anymore. model 1050
Replacement parts for your product may be ordered online here:
http://www.foodsaver.com/Category.aspx?id=r
If you are unsure which gasket to order contact FoodSaver via their website:
https://secure.foodsaver.com/ContactUs.aspx
Feb 08, 2011 | Tilia FoodSaver V2240
I have a Tilia Foodsaver Bagvac 35-0500. Are ther replacement parts available for this model?
Write to customer service. Company is now owned by Jarden Inc.
http://www.foodsaver.com/Support.aspx?id=sfaq&fgid=21
Oct 27, 2010 | Tilia FoodSaver VAC420
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
Vaccum has to be shut off manually when closing a bag or pumping out a cannister
The problem you describe can happen because the Foodsaver cannt detect a complete vacuum and is likely caused by the gaskets around the vacuum channel. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Jul 03, 2010 | Tilia FoodSaver V2240
My foodsaver v2490 will not vaccum the air out the bags...it is almost new with very little use
the problems with vac is allmost allways the gasket or the tubing in the unit there is a few fittings that get britlle over time and the heat in the unit and the china parts dont help i have got a bunch of these broken units on ebay and fix with drip irr fittings
Oct 21, 2009 | Tilia FoodSaver VAC420
What is a heat seal I see one on ebay but say it needs heat seal what are they talking about were can i get one or some for thev3825 foodsaver
the function that seals the bag after the vaccum process (melts the plastic to itself) Hope this helps
Jul 13, 2009 | Tilia FoodSaver V2240
Tilia FoodSaver V2240 Logo
60 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
