Question about Janome 2212 Sewing Machine
My daughter's brand new, right out of the box Janome 2212 machine is not working. The foot pedal is not engaging the motor so the needle doesn't move up and down. The wheel is pushed in as it
  • jdembishop
    jdembishop Jan 10, 2013
    It is a brand new machine - right out of the box and never been used. We were getting it set up to use it for the first time. I am an experienced sewer and know what to do. I am returning it.
  • Rose Ha
    Rose Ha Jan 06, 2014
    I had the exact same problem!! Brand new, out of the box, just finished winding the bobbin and threading the machine! Was all excited because I figured out how to front load the bobbin after taking apart the machine, which I wasn\'t suppose to do! Anyhoot, I\'m ready with my fabric to make the first stitch! I step on the foot press and I hear the engine but nothing is happening. Needle isn\'t moving and theres no reaction other than the noise from the sewing machine! At this point I figured I broke something! After an hour of fiddling, I gave up and chalked it up to a manufacturer defect. My bf comes over the next morning reads the instruction on how to wind the bobbin, pushes the hand wheel back into the machine and tada! Its working!!
  • 22 Answers
Sorry, but gotta ask is it plugged in and turned on? Check before you answer. (I ask this because it happened to me, set up, ready to go, and no power. After an hour and the machine was in pieces, My son asked if i plugged it in and I snapped "YES, DUH" not seeing him twirling he plug in his hand...he informed me that you must be 10% smarter than anything you operate or eat....at which point he was happy to inform me, the machine was 11% smarter. If it is plugged in and turned on, is the plug to the foot pedal plugged all the way in? Is the machine on? If you get zero reaction, no movement or sound of any kind, the foot pedal my be faulty, it can happen. Take it back to the dealer and they should replace the entire machine or the foot pedal. Good luck and happy sewing.
Posted on Jan 10, 2013
  • Rose Ha
    I had the exact same problem!! Brand new, out of the box, just finished winding the bobbin and threading the machine! Was all excited because I figured out how to front load the bobbin after taking apart the machine, which I wasn't suppose to do! Anyhoot, I'm ready with my fabric to make the first stitch! I step on the foot press and I hear the engine but nothing is happening. Needle isn't moving and theres no reaction other than the noise from the sewing machine! At this point I figured I broke something! After an hour of fiddling, I gave up and chalked it up to a manufacturer defect. My bf comes over the next morning reads the instruction on how to wind the bobbin, pushes the hand wheel back into the machine and tada! Its working!! **** it!
  • thinksewfast Jan 07, 2014
    its the simple basic things we forget that will make you the craziest.!!
louislevel_2
  • 374 Answers
SOURCE: needle wont go up and down.
well,it seem that your upper camshaft was stuck due to several factor on mechanical linkages and maybe on gears.You have to isolate the checking since you have clean lower bobbins free from dirt and thread/fabrics chips.If there an opening on top of machine open it to check some mechanical destorsion or breakage.Check some broken gears inside.If nothing try to open also at the bottom of machine cover and there are also belt and gears connected to the motors and bobbins shuttle holder if so oil all shafting oil port,oil port bushing specially on bushing near hand wheel there is port for oil,
check also motor assembly of machine,you can disconnect belt from motor release the bolt holding motor adjust to lower tension belt and release the belt.Take some tools such as monkey pliers or small pipe wrench that can hold hand wheel just crack in order to move suddenly after oiling for several hours sometime bushing and shafting rushes emerged or if you have anti rush spray put in on.After cracking and you can move a little crack only by your hand several time lleft and right until all linkages free from rush.If you can move all parts and hand wheel rotate freely.Check also motor by rotating the small pulley conncted to motor if free to move.if ok put back and reassembly all parts disconnected.try to move again by hand if free to move after all asssembly.Run machine using foot pedal.
Posted on Mar 15, 2009
  • 11 Answers
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Posted on Jun 16, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
  • 6 Answers
SOURCE: skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Posted on Oct 21, 2009
  • 1116 Answers
SOURCE: janome mylock 234 d
It may be rusted or a looper may be bent. Take it into a sewing machine dealer for service/repair.
Posted on Apr 20, 2010
The needle is not going up and down, the fabric is not feeding thru. The foot pedal is not working at all. How do I fix this?
Is it plugged in? (The foot pedal) Your machine may have power but in most setups the foot pedal is the master controller; since it controls motor speed everything mechanical is affected by whether it works or not.
Mar 06, 2016 | Sewing Machines
When I have the walking foot on the needle hits on the back of the foot.Janome 4800 memory craft
Is it a Janome brand walking foot? some generic feet and other brands don't fit the older Janomes.
Feb 12, 2015 | Janome Memory Craft 10000
Raising presser foot on Janime 2212
http://content.janome.com/userfiles/file/Inst%20book_%202212%28En_Sp_Fr%29.pdf
See p. 10 of the manual.
The presser foot lifter is on the right side of the leftmost part of the machine, towards the back of the machine. Press up to raise it.
Feb 16, 2014 | Janome Sewing Machines
My new janome 2212 isn't feeding my fabric
ok. Never pull fabric, it will bend the needle and cause you even more problem. So stop doing that.
Look in your manual for where the feed dog switch is. It might be under the "darning" area.
Good luck
Oct 02, 2012 | Janome 2212 Sewing Machine
It was working fine. Then stopped. When you depress the pedal the motor idles but the needle doesn't go up and down
it's possible that the foot pedal has gone out
check to make sure the power cord in inserted into the machine correctly & also the foot pedal
Apr 02, 2012 | Sewing Machines
Janome 2212
try changing needles-flat side to the back of the machine
check for any burrs around the needle plate area
check to make sure the tension is not to tight
check to make sure the bobbin is wound correctly & inserted correctly in the bobbin case
Mar 26, 2012 | Janome 2212 Sewing Machine
Upper thread not engaging bobbin thread...
Hiya Kandie. Usually when you can't pull the bobbin through, the wrong size needle is in, try a different size needle. Hope I was some help for you.
Feb 08, 2012 | Janome SEW MINI Mechanical Sewing Machine
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
The sewing machine works when switched on, the foot pedalhas no c
there is a clutch operated by foot pedal. if the clutch is continuously engaged then it will run own its own. so adjust clutch lever.
Nov 23, 2009 | Janome Sewing Machines
Janome 2212 Sewing Machine Logo
264 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
