Question about Refrigerators
Westinghouse fridge turns it self off to defrost is this normal
I have a second hand fridge, it runs good for a week then stops running and defrosts, is this normal or is the fridge had it's day. Thanks, Paul.
If your second hand fridge is over 5 years old, then it might be time to buy a new one. Most fridges nowadays have a lifespan of 5-8 years the most. Danni
Posted on Jan 10, 2013
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
  • 958 Answers
SOURCE: Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Gets stuck in defrost cycle, new thermostat already fitted
If you would like to stop the defrost timer from intermittently causing this, the defrost timer will need to be replaced. It's a simple part to replace and not expensive. Thanks, Sea Breeeze
Posted on Apr 27, 2009
rylee_smith
  • 8619 Answers
SOURCE: defrost cycle not defrosting
Hi
Please check the defrost timer at the back of your refrigerator and also check the defrost thermostat. Defrost thermostat wiring(part #240) could be loose. You'll need to remove the back panel, held in place by 5 screws. Locate the defrost thermostat and disconnect it from the wire connection to another part. Due to the connection requirement, you may need to cut the wires from the original part and splice it with the connector with wires to the new part. After securing the spliced wires and covering in electrical tape, replace the panel and all the screws.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 14, 2009
  • 4793 Answers
SOURCE: magic chef mcbr1010w, fridge not
do a total, 24hour,defrost,with the doors open,(loads of towels)this should melt all the ice you cant see/get at.DO NOT use hairdryers/scrappers as they only do the surface ice.Wash out/spray all vents/drains with clorine bleach.(clorine is a gas and the smell will not permeate food if left to vent naturally) then switch onto fast freeze,check door seals are tight all round(hot cloth will help mould them).hope all works well for you/please leave feedback.ta!
Posted on Sep 22, 2010
Hotpoint F1810p not functioning after ice buildup
Normally when there is a frost build up, the defrost timer is not working properly. The fridge will not run when in defrost. Some of the newer refrigerators have printed circuit boards that control the operation. Most older units have a separate timer that controls the defrost cycle.
May 04, 2015 | Hotpoint Refrigerators
Defrost timer does not advance after defrost
During this time of defrost you manually advanced into, Did the heater turn off them self? If they did the defrost thermostat does work, if the heaters stayed on the entire time (1hr) than the thermostat needs to be replaced as well as the timer. The thermostat is a cut off device to prevent the over heating of the freezer and liner (safety device). Think of a defrost timer as an egg timer, this timer runs regardless of function just advances like a clock. The thermostat turns off the heaters when they reach a temp rather then time. I hope this answered your question, good luck
Aug 17, 2014 | Refrigerators
Fan in freezer has stopped working,have defrosted and fridge seems to be cooler.
Simply defrosting the freezer might solve your problem. Sometimes ice can form on the fan or fan motor, and of course, prevents the fan from turning.
If there is ice here, your refrigerator isn't defrosting properly. This sounds like a defrost problem that may need a part replaced. Check out this site for details and photos. Refrigerator Defrost Parts
May 07, 2014 | Refrigerators
Fridge section not getting cold whilst freezer operating as normal.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Westinghouse Refrigerators
Stopped cooling completely, still running
Hi.
If the compressor is starting and running normally try performing a complete defrost. If the fridge restarts working after defrost then it was either damper system, defrost control, or in some case electronic control of temperature.
If the fridge restarts working after defrost and fails again after days or weeks, then you have a defective defrost system.
If the compressor is working all the time and it is none of the above there may be low gas pressure because of a micro leak.
If the compressor does not start check compressor, starter relay or capacitor and depending on the model temperature control.
Try the defrost first. Problems caused by defrost system may result in same symptoms and are quite common.
Regards.
Ginko.
Dec 11, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
Freezer & fridge warms up on average every 6-8 weeks. Remedy turn off and leave 24 plus hours with doors open. On turning on the fridge and freezer cool down again to operating temperature....
Good day,
That's too long a period, for a normal. defrost system failure.
You'll have to wait until it quits, then remove the rear panel and look for ice (not frost) building up somewhere in the freezer compartment.
I have solved similar problems on this model, by replacing the defrost thermostat with a GE 60 degree thermostat, and a WR9X330 GE 6 hour defrost timer to get this model to defrost completely.
It's also possible that the refrigerant charge is slightly low, causing the defrost thermostat not to reach a cold enough temperature to perform a good defrost cycle. (building ice over a long period of time).
Make sure Freon 12 was used when replacing the compressor.
Some substitutes caused the evaporator coil to act as if it was
slightly low on charge.
Nov 08, 2009 | Westinghouse Refrigerators
Flashing lights super chill super freeze
This is probably because you turned off the fridge at the mains (to defrost??). To stop the flashing lights and to restore normal operation, turn both the Supercool and Superfreeze knobs counterclockwise to "off" and then back to the operating position. Thats all!
Dec 21, 2008 | Refrigerators
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Westinghouse Fridge Problem
Is the fan in the freezer running? You should be able to hear it. If not, that is your problem. Check the door light/fan switch or check if the fan has power to it when you press the door switch in by hand. If fan is running, you could have a defrost problem. The defrost timer or the defrost heater could be faulty.
Nov 04, 2007 | Refrigerators
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
