Question about Refrigerators
Refrigerator quit working, power to compartment lights OK
Refrigerator suddenly quit...no water, no fan, no compressor, no temp control. Both compartment lights work when doors are open. Recycled power several times. Prior to stopping, vertical divider between freezer and cooler noticeably hot to the touch and freezer defrost coils occasionally glowed red. Could use some thoughts on troubleshooting.
  • Refrigerators Master
  • 4,654 Answers
If this is an American model refrigerator I will need to know the model number to see what may be happening. Can you post the model number? Thanks Sea BreezeRefrigerator quit working, power to compartment li - 1_10_2013_2_30_52_am.jpg
Posted on Jan 10, 2013
  • 6 more comments
  • Rob Hughes Jan 10, 2013
    SeaBreeze: GE Profile Artica PSC23 NGNA BB
  • John Tripp
    John Tripp Jan 10, 2013
    Thanks that was quick. Are you able to test some parts? This sounds like the=>https://www.pcappliancerepair.com/part-d... Please unplug power and remove the motherboard cover on the back of your refrigerator. Take it out and look over both sided for burn marks. Not all mother boards will show burn marks and will still be the motherboard as the source of the problem. How old is your refrigerator?http://appliancepartsseabreeze.com/appli...
  • Rob Hughes Jan 11, 2013
    Thanks. Done. Fridge is 10 years old. Condenser coils were pretty clogged with dust...vacuumed, cleaned...ordered new mother board and new fan motor. Will keep you posted on results.
  • John Tripp
    John Tripp Jan 11, 2013
    Great! You are juming on in there! Yes tell me how it goes. You have been doing some reading....JT
  • Rob Hughes Jan 16, 2013
    Parts arrived today. Motherboard was easy to install, though the supplier of this part had changed the location slightly of the left hand primary power connector, so...it was a bit of a stretch, but not awful.
    Replacing the condenser fan was a bit more bothersome, but we got 'er done.
    Hooked up the power and the lights came on, the fan is purring, the compressor is compressing, the water spout is working, and the temp is coming down inside.
    So...great solution! I appreciate the helpful advice!
  • John Tripp
    John Tripp Jan 16, 2013
    Thank you for your rate! Was the condensor fan an issue that could have also damaged the board? Thanks John Tripp
    JT: Not sure what degree the motor was a factor. Although, the motherboard did not show any burn marks, I did notice that the primary capacitors (there are two on this design) were swollen indicating an abnormal power draw from something. The extreme amount of dust on the condenser coil led me to an assumption of "guilt" that the condenser fan was probably working really hard and had probably exceeded its design limits. So...since I had the back off, and since I had cleaned the entire underneath...it seemed like a prudent thing to do. Interestingly, swapping out the motor turned out to be a bit of a bear and if I ever have to do it again, there are some tricks I could possibly pass on! Checked the fridge this morning...temp is stable at 37F in the fridge and 0F in the freezer...almost like having a new refrigerator!
  • John Tripp
    John Tripp Jan 17, 2013
    Reason I asked was sometimes fan motors cause the motherboard failures. In your case I do believe a surge caused the capacitors to swell. Ten years for a Artica/Profile is a good long time unless you had repairs before. Anyway thanks again and good luck, John Tripp
3 Suggested Answers
  • 1462 Answers
SOURCE: Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Posted on Oct 02, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
Ref has quit running/cooling. Lights inside are on, the lights on the temp controlls are off. Any isea?
I ran into this problem last year on the same or similar model.
if there is no cooling or fans or compressor running ,but lights are on in both compartments,and no control numbers are on the electronic control mounted to the left of the compressor is the cause of the
problem. It is expensive but rebuilts are available on Ebay .Ive
used national rebuilder parts many times,with excelent results.
Apr 30, 2014 | KitchenAid Superba Architect KSCS25INSS...
Compressor not working after performing maintenance ( vacuuming out condensor coil/ fan/compressor compartment )
If you have a start relay , remove and shake - if you hear anything it is toast. with a cap either use a cap tester or just replace it and cross your fingers.
Mar 30, 2017 | GE Refrigerators
GE Profile, Side by Side model # PSCF5RGXAFBB. Al of a sudden, both Refrigerator and Freezer sides started warming. Checked power supply. Appliance lights are on and the the House Circuit breaker is...
I also have the PSCF5RGXAFBB, it quit working completely. Mother Board and Evap fan replaced 2 times. Had 5 appointments with repairman. They finally decided it was a Sealed System Leak - covered by warranty.
Feb 03, 2011 | Refrigerators
SHUT DOWN WITH TEMP SWITCH IN REFRIG COMPARTMENT, UNIT WILL NOT COOL, POWER OK LIGHT ON FANS RUNNING.
Sounds like the overload/relay , is bad on the compressor . This piece just plugs on to the side of the compressor . Take your model number with you to get the correct part .
Nov 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have GE Profile refrigerator Quit Working
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Refrigerators
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Arghhh...Only 2years old and a bunch of room temp food!!
Very simply it is the Jazz circuit board which is also the board with the digital lighting the control board. Any questions hit me up.Ed
Feb 03, 2008 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
