Question about Toys
Change alternator on john deere 620i gator - Toys
momsjustknow
  • 149 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
mikeramesar
  • 37 Answers
SOURCE: cannot find out how to get to the battery for a
Where the front bully bar is, there is an indent in the middle , enough for your phillips head screw driver to get into, you must undo that screw and there will be a tab on either side of that panel to pull and the front bummer assembly will hinge out towards you, you can then unplug the battery and connect your charger..
Good luck!!
Posted on Dec 27, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
Samir3050
  • 70 Answers
SOURCE: where is the charging port
behind the "brush guard", pry each side of the panel attached to the brush guard and it will fold down, there you will see the battery. Next slide metal brace bar to the right and it will come out near the driver side wheel well, disconnect battery, and charge(if you want you can take it out then and charge battery inside or even bring it in to store on colder seasons to keep a longer battery life).
Posted on Mar 01, 2011
I have a gator xuv 4x4 620i and it won"t start but makes a clunking sound instead
check starter bolts pull plug and do a compression test clunk in engine never good possible spun rod bearing
Jul 27, 2016 | John Deere 2010 Gator XUV 4x4 620i
How do I fix john deere 620I gator steering assembly
then why do you not look for the bent rod and unbend it or replace it .
May 26, 2016 | John Deere 2010 Gator XUV 4x4 620i
How do i adjust the throttle position switches on a john deere gator 620i
YOU DONT! Factory specs are need to test and set it!
First off what is the problem you are having????
All the TPS does is switch from one timing curve to the other on the cdi, and is also connected to the fuel management computer to tell it when to increase fuel delivery.
If you are having running problems start with old fuel, fuel pump pressure, and last if you have modified the airbox or exhaust in any way it will run like crap! On fuel injection you have to get a tunable fuel management computer when increasing air-flow or exhaust flow. The fuel injection is set from the factory based on the OEM parameters.
How many hours/ miles on your unit?
Have the valves been adjusted if it has over 200 hours of use?
are there any codes being flashed on display when key is turned to on position but not running?
Aug 29, 2014 | John Deere 2008 Gator XUV 4x4 620i
How to remove the bolts on the starter John Deere Gator 620i
This is what I did to remove starter on 620i xuv gator. Remove starter solenoid and use extension 3/8 drive with universal joint to remove top bolt or remove front half of plastic shroud over drive belt assy , drill hole into cover in line with top starter bolt, insert extension with socket onto top starter bolt. Be sure to cover drilled hole with suitable material.
Jun 30, 2012 | John Toys
How do I open hood of john deere gator 620I 2008
the hood doesn't open on this toy but the front grill does flip down
May 20, 2012 | Peg Perego John Deere Gator HPX
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
Toys Logo
171 people viewed this question
Top Toys Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
