Question about MicroBoards GX2-1000 Model GX Disc Refurbished Publisher, 18X DVD / 48X CD burning, 50-disc capacity, automated printer, Print Resolution 4800 dpi, Patented disc-movement technology enhances speed and reliability, Typical Weekly Throughput 25-100 Discs, PrassiTe
Microboards GX2 unload failed
Disc drops out of burner onto belts and error message comes on "upload failed" nothing else happens, belts are working fine otherwise is this some sort of sensor problem?
3 Suggested Answers
techwaredist
  • 30 Answers
SOURCE: Microboards PFII just keeps rolling discs and will not print
Di arleady did the first thing that we advise of customers to do - reload the PF-2 print drivers. Since that did not work you a most likely looking at needing the print engine replaced. This typically costs $600+ depending on how full of ink the inside of your printer is. Hoefully your printer is still under warranty with Microboards. If not, you can call Microboards at 952.556.1639 or check ou this repair company
http://www.techwaredist.com/repairshop.asp
Posted on Nov 14, 2008
  • 9 Answers
SOURCE: Black ink too heavy - Microboards PF2
you can adjust the dry time. go to printer and faxes and right click select preference, there should be tabs select features then below should be advance features select that and there you can adjust the dry time and amount of ink.
Posted on Feb 06, 2009
Target drive not ready
This message means that the burning drives are not recognizing the blank media. There are a few things to try and remedy this though the unit may need repaired.
First, try using all of the duplicator bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.
2nd, try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.
3rd, It is OK per Microboards to open the unit and check for a loose drive cable. A loose cable can cause this error too.
Finally, try cleaning the drive bays by using compressed air to blow any dust out of the system.
If the error still continues then call Microboards tech support at 952 556 1639 to set up a repair.
Apr 15, 2013 | MicroBoards (DSRDVDD882) Burner
Is there a print driver available for Windows Vista for the MicroBoards DX-2 Disc Publisher?
According to the manufacturers web site, Vista and Windows 7 are not supported.
Regards,
Matt
Apr 20, 2011 | MicroBoards DX-2 Disc Publisher...
Product: Microboards mx-1 I cannot get it to print. it says: disc not detected printer not seeing disc. can't figure out. Nolan
Several solutions for you
first check cables.if theyare connected,try to install the driver.in device manager scan it again & let to plug & play to find it.then restart the pc (If you have it connected to a pc)
2. Try shutting down both the system and publisher 3 Restart the PC first before the pub. 4. Once you connect the pub. allow it to be detected by the system 5. If your given any errors, please list them out 6. If no errors occur, try to burn another disk 7. If the disk stops half way, let me know 8. If it is a success, then problem solved.
Please follow up
Nov 21, 2010 | MicroBoards MX-1 Disc Publisher Burner
Got a disc that will not unload. What do I do?
Look for a small pin hole on the front of the player,you'll need to push a button thats inside that hole,its a master switch for opening the tray.Hope I've helped...Don't forget to rate ;-}
Jun 17, 2010 | MicroBoards GX-1 50 Disc DVD/CD Publisher...
MICROBOARDS PRINTER LANGUAGE MONITOR........UNABLE TO READ DEVICEID......................this is the error i get when trying to print to my Microboards GX auto printer
The Microboards G3 is the worst duplicator I have ever owned. It has worked a total of 4 times, no response from the company, software is terrible and faulty and I'm pretty much over it. Good luck.
May 17, 2010 | MicroBoards GX-1 50 Disc DVD/CD Publisher...
Microboards pf pro refill cartridge
you can now get continuous inking systems for the microboards pf-pro machines
see here:
http://www.jpldisplays.com.au/catalog/product_info.php?products_id=4150
Mar 17, 2010 | Microboards PF-3 Print Factory Printer and...
Single blank disk inserting wont work (Mircoboards PF2)
You may have a disc loading error. To correct this follow these instructions:
Disk Loading error:
If a disc is not loaded correctly, it could cause the out of paper indicator to come on. Press the out of paper button on the interface. The printer will attempt to load another disc. If this does not clear the error, remove the discs from the input bin. Check to see if there are any discs on the belt. Remove any discs that are left on the belt.
Lift the cover and check for any discs on the front part of the printer. Remove any discs found on the belts. Close the cover.
Next, reload the input bin and press the out of paper button. The system will load the next disc and continue printing the remaining discs for that job.
If that doesn't work, and there are no obvious jams in the transport system, I'd call support and see if they can walk you through a fix. They can be reached at:
For technical questions or support issues, please contact Microboards Technology technical support at PH: 952-556-1639, FAX: 952-556-1628, by email at support@microboards.com or on the web at http://www.microboards.net.
Mar 19, 2009 | Microsoft Windows XP Home Edition
Oct 16, 2008 | MicroBoards PF-2 InkJet Printer
Open Questions:
The printer won't work on disclabel or other software. It only works good on the testing in the printer setup. Macbook with Microboards MX 2. It goes on till the printing fase. ERROR LOG:Process: DiscPrinter [607] Path: /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter Identifier: DiscPrinter Version: 2.1.0 (2.1.0.6) Code Type: X86-64 (Native) Parent Process: cupsd [577] Responsible: DiscPrinter [607] User ID: 26 Date/Time: 2015-11-03 12:41:50.899 +0100 OS Version: Mac OS X 10.11.1 (15B42) Report Version: 11 Anonymous UUID: AA3DFA29-60FC-5C3B-34A4-014DDC5F4116 Time Awake Since Boot: 1000 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY VM Regions Near 0: --> __TEXT 0000000100000000-00000001001f9000 [ 2020K] r-x/rwx SM=COW /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 com.Microboards.print.driver.cups.disc_printer 0x00000001000b2488 bool com_sps_cups_disc_printer_util_2_1_0::ABucket::FindNoThrow(std::string const&, EIOTypeValue&) const + 126094 1 com.Microboards.print.driver.cups.disc_printer 0x000000010001ac1d 0x100000000 + 109597 2 com.Microboards.print.driver.cups.disc_printer 0x000000010001b3a6 0x100000000 + 111526 3 com.Microboards.print.driver.cups.disc_printer 0x000000010001dada 0x100000000 + 121562 4 com.Microboards.print.driver.cups.disc_printer 0x000000010001ed07 0x100000000 + 126215 5 com.Microboards.print.driver.cups.disc_printer 0x0000000100028a1a void com_sps_cups_disc_printer_util_2_1_0::ABucket::Set(std::string const&, com_sps_cups_disc_printer_util_2_1_0::AHPString const&) + 34458 6 com.Microboards.print.driver.cups.disc_printer 0x000000010001917a 0x100000000 + 102778 7 com.Microboards.print.driver.cups.disc_printer 0x0000000100019462 0x100000000 + 103522 8 com.Microboards.print.driver.cups.disc_printer 0x0000000100010ef0 0x100000000 + 69360 Thread 1: 0 libsystem_kernel.dylib 0x00007fff8927350a read + 10 1 com.Microboards.print.driver.cups.disc_printer 0x000000010002919b void com_sps_cups_disc_printer_util_2_1_0::ABucket::Set(std::string const&, com_sps_cups_disc_printer_util_2_1_0::AHPString const&) + 36379 2 libsystem_pthread.dylib 0x00007fff9d56c9b1 _pthread_body + 131 3 libsystem_pthread.dylib 0x00007fff9d56c92e _pthread_start + 168 4 libsystem_pthread.dylib 0x00007fff9d56a385 thread_start + 13 Thread 2: 0 libsystem_kernel.dylib 0x00007fff8927278a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9d56c58c _pthread_wqthread + 1283 2 libsystem_pthread.dylib 0x00007fff9d56a375 start_wqthread + 13 Thread 3:: Dispatch queue: com.apple.libdispatch-manager 0 libsystem_kernel.dylib 0x00007fff892730a2 kevent_qos + 10 1 libdispatch.dylib 0x00007fff8ce2711d _dispatch_mgr_invoke + 216 2 libdispatch.dylib 0x00007fff8ce26d85 _dispatch_mgr_thread + 52 Thread 4: 0 libsystem_kernel.dylib 0x00007fff8927278a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9d56c58c _pthread_wqthread + 1283 2 libsystem_pthread.dylib 0x00007fff9d56a375 start_wqthread + 13 Thread 0 crashed with X86 Thread State (64-bit): rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x00000000001f8100 rdx: 0x0000000000000000 rdi: 0x0000000000000000 rsi: 0x0000000000000020 rbp: 0x00007fff5fbfe480 rsp: 0x00007fff5fbfe350 r8: 0x0000000000000001 r9: 0x0000000000000001 r10: 0x0000000000000002 r11: 0x0000000101d00000 r12: 0x0000000101d6ec10 r13: 0x00007fff5fbfe710 r14: 0x00007fff5fbfe710 r15: 0x0000000000000000 rip: 0x00000001000b2488 rfl: 0x0000000000010206 cr2: 0x000000010a8aa000 Logical CPU: 0 Error Code: 0x02000170 Trap Number: 133 Binary Images: 0x100000000 - 0x1001f8fef +com.Microboards.print.driver.cups.disc_printer (2.1.0 - 2.1.0.6) /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter 0x10024a000 - 0x10024ffff libcupsimage.2.dylib (435) /usr/lib/libcupsimage.2.dylib 0x100254000 - 0x1002eefef +libspsutils.dylib (1.2) /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/lib/libspsutils.dylib 0x7fff6c1ad000 - 0x7fff6c1e3f5f dyld (360.17) /usr/lib/dyld 0x7fff88482000 - 0x7fff8857dff7 libFontParser.dylib (158.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fff8857e000 - 0x7fff88805ff3 com.apple.CFNetwork (760.1.2 - 760.1.2) /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff88bdf000 - 0x7fff88beeffb com.apple.LangAnalysis (1.7.0 - 1.7.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff88c00000 - 0x7fff88c05fff com.apple.TCC (1.0 - 1) /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff88c06000 - 0x7fff88c0efef libsystem_platform.dylib (73.1.1) /usr/lib/system/libsystem_platform.dylib 0x7fff88d9c000 - 0x7fff8925afcf com.apple.vImage (8.0 - 8.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff8925b000 - 0x7fff89279fff libsystem_kernel.dylib (3247.10.11) /usr/lib/system/libsystem_kernel.dylib 0x7fff8927a000 - 0x7fff8927bfff libsystem_secinit.dylib (20) /usr/lib/system/libsystem_secinit.dylib 0x7fff89282000 - 0x7fff89285fff libCoreVMClient.dylib (119.5) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff89286000 - 0x7fff8928fff3 com.apple.CommonAuth (4.0 - 2.0) /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fff89299000 - 0x7fff892a4ff7 libChineseTokenizer.dylib (16) /usr/lib/libChineseTokenizer.dylib 0x7fff8951e000 - 0x7fff89523ff7 libmacho.dylib (875.1) /usr/lib/system/libmacho.dylib 0x7fff89524000 - 0x7fff89582fff com.apple.SystemConfiguration (1.14 - 1.14) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff8967b000 - 0x7fff8976afff libxml2.2.dylib (29) /usr/lib/libxml2.2.dylib 0x7fff897a7000 - 0x7fff897c2ff7 libCRFSuite.dylib (34) /usr/lib/libCRFSuite.dylib 0x7fff897c3000 - 0x7fff897c6ff7 libsystem_sandbox.dylib (459.10.4) /usr/lib/system/libsystem_sandbox.dylib 0x7fff8aade000 - 0x7fff8ab0fffb com.apple.GSS (4.0 - 2.0) /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff8ab7a000 - 0x7fff8ab93fff com.apple.CFOpenDirectory (10.11 - 194) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff8ae6f000 - 0x7fff8b0eefff com.apple.security (7.0 - 57336.10.29) /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff8b0ef000 - 0x7fff8b0f5fff com.apple.IOAccelerator (203.10 - 203.10) /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0x7fff8b29e000 - 0x7fff8b2d8fff com.apple.QD (3.12 - 302) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff8b2dc000 - 0x7fff8b30aff7 com.apple.DictionaryServices (1.2 - 250) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff8b343000 - 0x7fff8b460fff libsqlite3.dylib (216.4) /usr/lib/libsqlite3.dylib 0x7fff8c222000 - 0x7fff8c34efff com.apple.CoreText (352.0 - 494.5.1) /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff8c34f000 - 0x7fff8c351ff7 libRadiance.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff8c355000 - 0x7fff8c3aafff com.apple.AE (701 - 701) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff8c6c7000 - 0x7fff8c6d5ff7 libbz2.1.0.dylib (38) /usr/lib/libbz2.1.0.dylib 0x7fff8c6d6000 - 0x7fff8c749fff com.apple.framework.IOKit (2.0.2 - 1178.10.1) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff8c9e7000 - 0x7fff8c9f2fff libkxld.dylib (3247.10.11) /usr/lib/system/libkxld.dylib 0x7fff8cc1c000 - 0x7fff8cc32ff7 libLinearAlgebra.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x7fff8cc33000 - 0x7fff8cc83fff libcups.2.dylib (435) /usr/lib/libcups.2.dylib 0x7fff8cc84000 - 0x7fff8ccc2ff7 libGLImage.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff8ccc3000 - 0x7fff8cde8ff7 com.apple.LaunchServices (728.4 - 728.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff8ce1f000 - 0x7fff8ce4cfff libdispatch.dylib (500.10.1) /usr/lib/system/libdispatch.dylib 0x7fff8ce4d000 - 0x7fff8ce50ff7 libCoreFSCache.dylib (119.5) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x7fff8d075000 - 0x7fff8d092fff com.apple.AppleVPAFramework (2.0.15 - 2.0.15) /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA 0x7fff8d12a000 - 0x7fff8d199fff com.apple.SearchKit (1.4.0 - 1.4.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff8d410000 - 0x7fff8d414fff libcache.dylib (75) /usr/lib/system/libcache.dylib 0x7fff8d41b000 - 0x7fff8d4d4ff7 libvMisc.dylib (563.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff8dc7e000 - 0x7fff8dcadfc3 libsystem_m.dylib (3105) /usr/lib/system/libsystem_m.dylib 0x7fff8dd01000 - 0x7fff8dd43ff7 com.apple.Metal (54.26.3 - 54.26.3) /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x7fff8dec4000 - 0x7fff8f12fff7 com.apple.CoreGraphics (1.600.0 - 938) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff8f137000 - 0x7fff8f13ffff com.apple.CoreServices.FSEvents (1222.1.1 - 1222.1.1) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x7fff8f146000 - 0x7fff8f14efff libGFXShared.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff8f573000 - 0x7fff8f57dfff com.apple.NetAuth (6.0 - 6.0) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff8f57e000 - 0x7fff8f5c9ffb com.apple.print.framework.PrintCore (11.0 - 472) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff8f6be000 - 0x7fff8f6d8fff com.apple.Kerberos (3.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff8f6d9000 - 0x7fff8f7cbff7 libiconv.2.dylib (44) /usr/lib/libiconv.2.dylib 0x7fff8f7cc000 - 0x7fff8f811ff3 libFontRegistry.dylib (155) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fff8f93d000 - 0x7fff8f940fff com.apple.IOSurface (108.0.1 - 108.0.1) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff8fc06000 - 0x7fff8fc07ffb libSystem.B.dylib (1225.1.1) /usr/lib/libSystem.B.dylib 0x7fff8fc08000 - 0x7fff8fc0dff7 libheimdal-asn1.dylib (452.1.1) /usr/lib/libheimdal-asn1.dylib 0x7fff8fc0e000 - 0x7fff8fc1cfff com.apple.opengl (12.0.34 - 12.0.34) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff8fc30000 - 0x7fff8fc4cff7 libextension.dylib (78) /usr/lib/libextension.dylib 0x7fff8fc4d000 - 0x7fff8fc58ff7 libcommonCrypto.dylib (60074) /usr/lib/system/libcommonCrypto.dylib 0x7fff8fd0b000 - 0x7fff8fd0bfff com.apple.CoreServices (728.4 - 728.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff90895000 - 0x7fff908baff7 libPng.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff9092d000 - 0x7fff90939fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff90959000 - 0x7fff90a6bfef libvDSP.dylib (563.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff90d13000 - 0x7fff90d16ffb libdyld.dylib (360.17) /usr/lib/system/libdyld.dylib 0x7fff90d31000 - 0x7fff90d33fff libsystem_coreservices.dylib (19) /usr/lib/system/libsystem_coreservices.dylib 0x7fff90f60000 - 0x7fff90f64fff libpam.2.dylib (20) /usr/lib/libpam.2.dylib 0x7fff90fa2000 - 0x7fff91016ff3 com.apple.securityfoundation (6.0 - 55126) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff912e5000 - 0x7fff912e7ff7 libquarantine.dylib (80) /usr/lib/system/libquarantine.dylib 0x7fff91302000 - 0x7fff91306fff libGIF.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff91374000 - 0x7fff913e7ffb com.apple.Heimdal (4.0 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff91ba2000 - 0x7fff91bc6ff7 libJPEG.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff91cc4000 - 0x7fff91cc4ff7 liblaunch.dylib (755.1.19) /usr/lib/system/liblaunch.dylib 0x7fff92319000 - 0x7fff9235eff7 com.apple.coreservices.SharedFileList (24.4 - 24.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x7fff928b9000 - 0x7fff928bafff liblangid.dylib (122) /usr/lib/liblangid.dylib 0x7fff9313c000 - 0x7fff93141fff com.apple.DiskArbitration (2.7 - 2.7) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff934f9000 - 0x7fff93557fff libsystem_network.dylib (582.1.4) /usr/lib/system/libsystem_network.dylib 0x7fff94247000 - 0x7fff94249fff libCVMSPluginSupport.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff94393000 - 0x7fff94393fff com.apple.ApplicationServices (48 - 48) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff94470000 - 0x7fff94506ff7 com.apple.ColorSync (4.9.0 - 4.9.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff94542000 - 0x7fff94542fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff9454c000 - 0x7fff94551ff3 libunwind.dylib (35.3) /usr/lib/system/libunwind.dylib 0x7fff945d1000 - 0x7fff945d1fff libOpenScriptingUtil.dylib (169) /usr/lib/libOpenScriptingUtil.dylib 0x7fff945d2000 - 0x7fff949d4fff libLAPACK.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff95587000 - 0x7fff959fcff7 com.apple.CoreFoundation (6.9 - 1255.1) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff95a62000 - 0x7fff95a70fff libxar.1.dylib (302) /usr/lib/libxar.1.dylib 0x7fff95b84000 - 0x7fff95b94fff libbsm.0.dylib (34) /usr/lib/libbsm.0.dylib 0x7fff95b95000 - 0x7fff95b9cff7 libcompiler_rt.dylib (62) /usr/lib/system/libcompiler_rt.dylib 0x7fff95d16000 - 0x7fff95ebbff3 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff95ebc000 - 0x7fff960c9fff libicucore.A.dylib (551.30) /usr/lib/libicucore.A.dylib 0x7fff96188000 - 0x7fff961d6ff7 libstdc++.6.dylib (104.1) /usr/lib/libstdc++.6.dylib 0x7fff965e2000 - 0x7fff9666fdd7 com.apple.AppleJPEG (1.0 - 1) /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x7fff96673000 - 0x7fff966e1ff7 com.apple.ApplicationServices.ATS (377 - 394.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff966e2000 - 0x7fff96782fff com.apple.Metadata (10.7.0 - 972.9) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff967dd000 - 0x7fff967f9ff7 libsystem_malloc.dylib (67) /usr/lib/system/libsystem_malloc.dylib 0x7fff967fa000 - 0x7fff968ecff7 libJP2.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fff968ed000 - 0x7fff968edfff libmetal_timestamp.dylib (600.0.41.2) /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib 0x7fff968fc000 - 0x7fff96959fff com.apple.CoreServices.OSServices (728.4 - 728.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff9695a000 - 0x7fff96971fff libmarisa.dylib (4) /usr/lib/libmarisa.dylib 0x7fff96b6c000 - 0x7fff96e01fff libmecabra.dylib (696.1) /usr/lib/libmecabra.dylib 0x7fff96e55000 - 0x7fff96e89ff7 com.apple.CoreVideo (1.8 - 191.1) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff96f38000 - 0x7fff96f49fff libz.1.dylib (60) /usr/lib/libz.1.dylib 0x7fff9701e000 - 0x7fff97038ff3 liblzma.5.dylib (10) /usr/lib/liblzma.5.dylib 0x7fff97507000 - 0x7fff97508fff libsystem_blocks.dylib (65) /usr/lib/system/libsystem_blocks.dylib 0x7fff97fcd000 - 0x7fff97fd5fff libcopyfile.dylib (127) /usr/lib/system/libcopyfile.dylib 0x7fff98031000 - 0x7fff98032fff libDiagnosticMessagesClient.dylib (100) /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff98033000 - 0x7fff9839dddf libobjc.A.dylib (680) /usr/lib/libobjc.A.dylib 0x7fff9839e000 - 0x7fff9839eff7 libkeymgr.dylib (28) /usr/lib/system/libkeymgr.dylib 0x7fff983c1000 - 0x7fff983d1fff libSparseBLAS.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x7fff98ca3000 - 0x7fff98d30fe7 libsystem_c.dylib (1081.1.3) /usr/lib/system/libsystem_c.dylib 0x7fff98ea0000 - 0x7fff98ef3ff7 libc++.1.dylib (120.1) /usr/lib/libc++.1.dylib 0x7fff99073000 - 0x7fff9907bfff com.apple.NetFS (6.0 - 4.0) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff990cc000 - 0x7fff990ceff7 com.apple.xpc.ServiceManagement (1.0 - 1) /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff992b2000 - 0x7fff992c9fff libsystem_asl.dylib (322) /usr/lib/system/libsystem_asl.dylib 0x7fff992cd000 - 0x7fff99573fff com.apple.CoreData (120 - 640) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff9a401000 - 0x7fff9a5caff7 com.apple.ImageIO.framework (3.3.0 - 1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff9a5cb000 - 0x7fff9a5d6fff libGL.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff9a5d7000 - 0x7fff9a5d7fff com.apple.Accelerate (1.10 - Accelerate 1.10) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff9a6aa000 - 0x7fff9a6fbff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff9a6fc000 - 0x7fff9a725ff7 libsystem_info.dylib (476) /usr/lib/system/libsystem_info.dylib 0x7fff9a89d000 - 0x7fff9a8a6ffb libsystem_notify.dylib (149) /usr/lib/system/libsystem_notify.dylib 0x7fff9aa0d000 - 0x7fff9aa36fff libxpc.dylib (755.1.19) /usr/lib/system/libxpc.dylib 0x7fff9aa37000 - 0x7fff9aa39ff7 libsystem_configuration.dylib (801.10.2) /usr/lib/system/libsystem_configuration.dylib 0x7fff9aa6c000 - 0x7fff9aa7dff7 libsystem_trace.dylib (200) /usr/lib/system/libsystem_trace.dylib 0x7fff9aa7e000 - 0x7fff9aa86fff libsystem_networkextension.dylib (384.1.2) /usr/lib/system/libsystem_networkextension.dylib 0x7fff9ac9f000 - 0x7fff9acc8ff7 libxslt.1.dylib (14) /usr/lib/libxslt.1.dylib 0x7fff9adec000 - 0x7fff9adedffb libremovefile.dylib (41) /usr/lib/system/libremovefile.dylib 0x7fff9b218000 - 0x7fff9b218fff libenergytrace.dylib (10) /usr/lib/libenergytrace.dylib 0x7fff9b219000 - 0x7fff9b25aff7 libGLU.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff9b396000 - 0x7fff9b398fff com.apple.loginsupport (1.0 - 1) /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0x7fff9bbf9000 - 0x7fff9bc1dfff com.apple.MultitouchSupport.framework (304.9 - 304.9) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff9bc7f000 - 0x7fff9bc87ffb libsystem_dnssd.dylib (624.10.1) /usr/lib/system/libsystem_dnssd.dylib 0x7fff9bc88000 - 0x7fff9bca4ff3 libresolv.9.dylib (60) /usr/lib/libresolv.9.dylib 0x7fff9cd6e000 - 0x7fff9cd7ffff libcmph.dylib (6) /usr/lib/libcmph.dylib 0x7fff9cd80000 - 0x7fff9cdabffb libarchive.2.dylib (32.10.1) /usr/lib/libarchive.2.dylib 0x7fff9cdaf000 - 0x7fff9d094ff3 com.apple.CoreServices.CarbonCore (1136 - 1136) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff9d095000 - 0x7fff9d0adfc7 libcompression.dylib (23) /usr/lib/libcompression.dylib 0x7fff9d0c4000 - 0x7fff9d13bfc7 libcorecrypto.dylib (334) /usr/lib/system/libcorecrypto.dylib 0x7fff9d13c000 - 0x7fff9d148ff7 com.apple.OpenDirectory (10.11 - 194) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff9d14c000 - 0x7fff9d198ffb com.apple.HIServices (1.22 - 548) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff9d19f000 - 0x7fff9d4f3fff com.apple.Foundation (6.9 - 1255.1) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff9d569000 - 0x7fff9d572ff7 libsystem_pthread.dylib (137.1.1) /usr/lib/system/libsystem_pthread.dylib 0x7fff9db15000 - 0x7fff9dcd5feb libBLAS.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff9dee0000 - 0x7fff9dee0ff7 libunc.dylib (29) /usr/lib/system/libunc.dylib 0x7fff9dee1000 - 0x7fff9df27ff7 libauto.dylib (186) /usr/lib/libauto.dylib 0x7fff9e491000 - 0x7fff9e4bafff libc++abi.dylib (125) /usr/lib/libc++abi.dylib 0x7fff9e529000 - 0x7fff9e53dfff libsystem_coretls.dylib (82) /usr/lib/system/libsystem_coretls.dylib 0x7fff9eacf000 - 0x7fff9eb76fff com.apple.LanguageModeling (1.0 - 1) /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x7fff9eb88000 - 0x7fff9ebe3ff7 libTIFF.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 912 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=178.5M resident=0K(0%) swapped_out_or_unallocated=178.5M(100%) Writable regions: Total=39.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=39.5M(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Activity Tracing 2048K 2 Dispatch continuations 4096K 2 Kernel Alloc Once 4K 2 MALLOC 21.6M 18 MALLOC guard page 32K 7 Process Corpse Info 2048K 2 STACK GUARD 56.0M 6 Stack 9824K 6 VM_ALLOCATE 20K 3 __DATA 8572K 144 __LINKEDIT 91.2M 6 __TEXT 87.3M 149 __UNICODE 552K 2 mapped file 25.1M 2 shared memory 20K 5 =========== ======= ======= TOTAL 307.8M 341 E [03/Nov/2015:12:41:50 +0100] [Job 31] Job stopped due to filter errors; please consult the error_log file for details. D [03/Nov/2015:12:41:50 +0100] [Job 31] The following messages were recorded from 12:41:50 to 12:41:50 D [03/Nov/2015:12:41:50 +0100] [Job 31] Adding start banner page "none". D [03/Nov/2015:12:41:50 +0100] [Job 31] Queued on "Microboards_PF_Pro" by "dennis". D [03/Nov/2015:12:41:50 +0100] [Job 31] File of type application/pdf queued by "dennis". D [03/Nov/2015:12:41:50 +0100] [Job 31] Setting job-hold-until to no-hold D [03/Nov/2015:12:41:50 +0100] [Job 31] Adding end banner page "none". D [03/Nov/2015:12:41:50 +0100] [Job 31] Job released by user. D [03/Nov/2015:12:41:50 +0100] [Job 31] time-at-processing=1446550910 D [03/Nov/2015:12:41:50 +0100] [Job 31] 1 filters for job: D [03/Nov/2015:12:41:50 +0100] [Job 31] /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter (application/pdf to printer/Microboards_PF_Pro, cost 100) D [03/Nov/2015:12:41:50 +0100] [Job 31] job-sheets=none,none D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[0]="Microboards_PF_Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[1]="31" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[2]="dennis" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[3]="Microboards PF-Pro - Untitled1 - DiscLabel" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[4]="1" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[5]="AP_ColorMatchingMode=AP_VendorColorMatching AP_D_InputSlot= noBookletBinding..b. BookletType..n.=0 nocollate com.apple.print.DocumentTicket.PMSpoolFormat=application/pdf com.apple.print.JobInfo.PMApplicationName=DiscLabel com.apple.print.JobInfo.PMJobName=Microboards\ PF-Pro\ -\ Untitled1\ -\ DiscLabel com.apple.print.JobInfo.PMJobOwner=Dennis com.apple.print.PageToPaperMappingMediaName=cd-120mm com.apple.print.PageToPaperMappingType..n.=1 com.apple.print.PrinterInfo.PMColorDeviceID..n.=16828 com.apple.print.PrintSettings.PMColorSpaceModel..n.=2 com.apple.print.PrintSettings.PMCopies..n.=1 com.apple.print.PrintSettings.PMCopyCollate..b. com.apple.print.PrintSettings.PMDestinationType..n.=1 com.apple.print.PrintSettings.PMFirstPage..n.=1 com.apple.print.PrintSettings.PMLastPage..n.=2147483647 com.apple.print.PrintSettings.PMLayoutColumns..n.=1 com.apple.print.PrintSettings.PMLayoutRows..n.=1 com.apple.print.PrintSettings.PMPageRange..a.0..n.=1 com.apple.print.PrintSettings.PMPageRange..a.1..n.=2147483647 DestinationPrinterID=Microboards_PF_Pro media=cd-120mm PaperInfoIsSuggested..b. pserrorhandler-requested=standard SPSClippingDiameters={\ Inner=360\ Outer=1180\ } SPSClippingHubDiameters={\ Inner=220\ Outer=360\ } job-uuid=urn:uuid:484af430-bba9-369f-4b62-be25bc4f6ac7 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1446550910 time-at-processing=1446550910 document-name-supplied=Microboards\ PF-Pro\ -\ Untitled1\ -\ DiscLabel job-impressions=1 com.apple.print.PrintSettings.PMTotalSidesImaged..n.=1 sides=one-sided Duplex=None com.apple.print.PrintSettings.PMTotalBeginPages..n.=1 PageSize=cd-120mm" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[6]="/private/var/spool/cups/d00031-001" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[0]="" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[1]="CUPS_CACHEDIR=/private/var/spool/cups/cache" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[2]="CUPS_DATADIR=/usr/share/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[3]="CUPS_DOCROOT=/usr/share/doc/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[4]="CUPS_FONTPATH=/usr/share/cups/fonts" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[5]="CUPS_REQUESTROOT=/private/var/spool/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[6]="CUPS_SERVERBIN=/usr/libexec/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[7]="CUPS_SERVERROOT=/private/etc/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[8]="CUPS_STATEDIR=/private/etc/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[9]="HOME=/private/var/spool/cups/tmp" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[10]="PATH=/usr/libexec/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[11]="SERVER_ADMIN=root@macbookandennis.lan" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[12]="SOFTWARE=CUPS/2.1.0" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[13]="TMPDIR=/private/var/spool/cups/tmp" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[14]="USER=root" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[15]="CUPS_MAX_MESSAGE=2047" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[16]="CUPS_SERVER=/private/var/run/cupsd" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[17]="CUPS_ENCRYPTION=IfRequested" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[18]="IPP_PORT=631" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[19]="CHARSET=utf-8" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[20]="LANG=nl.UTF-8" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[21]="APPLE_LANGUAGE=nl" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[22]="PPD=/private/etc/cups/ppd/Microboards_PF_Pro.ppd" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[23]="RIP_MAX_CACHE=128m" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[24]="CONTENT_TYPE=application/pdf" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[25]="DEVICE_URI=usb://Microboards/PF-Pro?serial=PFP0004319" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[26]="PRINTER_INFO=Microboards PF-Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[27]="PRINTER_LOCATION=MacBook van Dennis" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[28]="PRINTER=Microboards_PF_Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[29]="PRINTER_STATE_REASONS=none" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[30]="CUPS_FILETYPE=document" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[31]="FINAL_CONTENT_TYPE=printer/Microboards_PF_Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[32]="AUTH_I****" D [03/Nov/2015:12:41:50 +0100] [Job 31] Started filter /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter (PID 607) D [03/Nov/2015:12:41:50 +0100] [Job 31] Started backend /usr/libexec/cups/backend/usb (PID 608) D [03/Nov/2015:12:41:50 +0100] [Job 31] usb: AppleLanguages="nl" D [03/Nov/2015:12:41:50 +0100] [Job 31] STATE: +connecting-to-device D [03/Nov/2015:12:41:50 +0100] [Job 31] Looking for 'Microboards PF-Pro' D [03/Nov/2015:12:41:50 +0100] [Job 31] Opening connection D [03/Nov/2015:12:41:50 +0100] [Job 31] Directory '/System/Library/Printers/Libraries/USBGenericPrintingClass.plugin' heeft juiste bevoegdheden (040755/uid=0/gid=0). D [03/Nov/2015:12:41:50 +0100] [Job 31] load_classdriver(/Sys
Nov 03, 2015 | MicroBoards MX-2 Disc Publisher MX21000
MicroBoards GX2-1000 Model GX Disc Refurbished Publisher, 18X DVD / 48X CD burning, 50-disc capacity, automated printer, Print Resolution 4800 dpi, Patented disc-movement technology enhances speed and reliability, Typical Weekly Throughput 25-100 Discs, PrassiTe Logo
27 people viewed this question
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
