Question about Boating
2000 90hp Yamaha 2 stroke starts but won't keep running
No issues until today. Running at 3/4 throttle motor just shut off. Starts but dies quickly.
  • Ron Beardemphl Jan 11, 2013
    Thanks everyone. Fuel had water in it. Runs great again. God bless. RB
Sounds like the jet is partially blocked
Posted on Jan 11, 2013
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Posted on Jun 23, 2009
  • 23 Answers
SOURCE: Yamaha 30 HP 3 cylinder 2 stroke
Did you change plugs? If you did chek the plug to see if piston has hit the end of plug. Do a compresion check Jim OMC retired Mech
Posted on Jul 07, 2009
  • 52086 Answers
SOURCE: motor dies once it gets warm.
sounds like you need to replace water pump .trolling slow it should never get hot .
Posted on Apr 26, 2010
  • 302 Answers
SOURCE: runs good for short while, then dies wait a few
coil is getting hot and shorting out.
Posted on Jun 19, 2010
2007 Yamaha V Star 1300 dies with throttle
Hi, Anonymous and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump or internal fuel line has pinholes.
17. Fuel injectors clogged or faulty.
18. Faulty throttle position sensor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.starbikeforums.com/forums/49-v-star/68346-650-starts-but-dies-throttle.html
Bike idles perfect but dies when given the slightest amount of throttle 93...
Yamaha XVS1300A 2007 Service Manual
https://www.partsfish.com/page/oem-parts-for-yamaha
YAMAHA XVS1300A Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 08, 2018 | 2007 Yamaha V Star 1300
1999 Cherokee starts but won't keep running without giving it throttle.
Assuming everything is working correctly, you may have to drive it up to 50 miles for the computer to relearn the basic perimeters.
I think you can also turn the key on, open the throttle to wide open, then close it 2 or 3 times to reset the memory in the computer.
Not sure about Jeeps.
Jan 30, 2013 | 1999 Jeep Cherokee 4WD
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
Won't stay running. starts but then dies within a few seconds
clearly sounds like fuel starvation, I would be looking at the throttle body, they need servicing every couple of years, they fill up with like grease and block tick over hole.....
Mar 06, 2018 | 1991 Mitsubishi Montero
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
Carb adjustments/ rule of thumb
Assuming that the adjustment screws 'H' and 'L' have slotted heads, turn both CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed-up, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine keeps running.
May 21, 2010 | Husqvarna Chain Saw 20" Bar
142 chain saw. Starts but will not pick up when
Check the fuel lines for hardness, cracking, splitting, or end rot. Check the muffler for plugging. Check the carburetor fasteners for tightness. Are you using fresh fuel mix? If the carburetor jets have been adjusted, try turning both CW to stops (lightly) then back out each CCW 1-1/2 turns. Engine should start and run--allow to warm up. Pull the throttle full on, and adjust H needle CW until the engine starts to speed up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Let idle and adjust L CW for fairly smooth running, but still allows the engine to 'follow the throttle'. Hope this helps!
May 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvana 65 chain saw will rev fully when idle but dies when introduced to timber
Sounds like the saw is running lean. Check the fuel filter, air cleaner and muffler for plugging. Check the condition of the fuel lines and that the fasteners on the carburetor are tight. If all ok, turn the 'L' and 'H' jet needles on the carburetor CW to stops (lightly), then back out each 1-1/2 turns CCW. This is a basic setting and the engine should start and run. Allow the engine to warm up, pull the throttle full on, and adjust H CW until the engine starts to speed up, but continues to 4-stroke. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces the most power and least heat. Allow to idle and adjust L CW until the engine runs fairly well, yet will allow it to 'follow the throttle'. Set the idle speed screw til the chain stops moving, but keeps the engine running. Hope this helps!
May 12, 2010 | Garden
Apr 27, 2009 | Boating
My TB475SS starts and then dies right away. i
It usually wont idle very well when it's cold, Goto #1 on the choke give the rope a couple of "quick" tugs, and then move it to #2 Give it one or 2 more tugs with a little throttle, now it should be running witha little throttle, let it run like that for a minute then move it to #3 kinda still pumping the throttle a little and it should take off fine. If this is the 4 stroke, mine did the same thing until it was broke in good. (About 4-5 uses), now I have to say its more reliable than any 2-stroke I've owned and I use it commercially. 1st or 2nd pull everytime and is ready as soon as it fires! Hope this helps!
Apr 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Boating Logo
118 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
