Question about Whirlpool Duet GHW9150P Front Load Washer
F20 error code on whirlpool front load washer duel sport
duby1990
  • 367 Answers
SOURCE: F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Posted on Nov 19, 2008
rylee_smith
  • 8619 Answers
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Posted on Feb 08, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 155 Answers
SOURCE: error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
8. Verify CCU operation by running a Diagnostic Test.
Posted on Apr 11, 2010
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Getting f20 error code, how to check flow meter operation
Check for stuck socks or something just under the door seal at the bottom of the drum. Check filter for blockage and all outlet pipes. Check the pressure switch hose for any holes as it may have rubbed on the drum and created a small hole in it. Make sure flow meter is level and not at any angle.
Dec 22, 2012 | Whirlpool duet Washing Machines
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F20 code
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
http://www.appliancepartspros.com/
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
Whirpool duet sport F 20 code
common F20 error requiring an about $35 water valve replaced. You can get parts and manual at repairclinic.com
Oct 14, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi!
“F20” on display
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
