Question about LG WM2101HW 4.0 cu.ft. Washer
Lg wm2101hw ue error - LG WM2101HW 4.0 cu.ft. Washer
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Posted on Aug 08, 2009
  • 6277 Answers
SOURCE: My LG intellowasher is not
LG's 'UE' stands for 'Unbalance Error'.
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 30, 2011
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
Lg wm2101hw code le
Press "end of cycle" for 3 seconds or till the flashing goes off . Plug off the wall. Code can be an indication of several issues. The most common cause is over sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Click helped if helped.........
Mar 15, 2013 | LG WM2101HW 4.0 cu.ft. Washer
I am getting alert of UE for fully automaticatic washing manchine
According to Lg Ue error code is an unbalanced load error code or uneven load error code you can also click this link from the LG site which describes some ways to alleviate the problem of the UE error code http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800. I have also found that if these ways do not remove the problem you may have to open the unit and check the damper struts that attach to the tub assembly. If one of these struts were not to be attached or have broken, or came away from the tub assembly this would also cause the UE error code as well with the unit. Also if you remove the rear panel you will see the stator which is basicly the motor as well as an rps sensor which helps the stator to rotate. I also have found that in some cases the center bolt that holds the stator in place sometimes unloosens and unscrews as well also causing this UE error code. So you would first try the methods that LG has listed in order to alleviate the UE error code and if there methods did not work then you would first look at the stator center screw to assure that it is tightened and in place. And secondly if the stator screw were in proper place and tight then you would look at the damper struts in the unit lastly. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
Jul 04, 2011 | LG WM-2277HW Front Load Washer
LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
May 20, 2010 | LG Washing Machines
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
May 16, 2010 | LG WM1814CW Front Load Washer
Code error ue lg washing machine
ue is (imbalanced error) cause. the load is to small,washer is tilted, laundry is gathered to one side, non distributed things are put into the washer
Jun 20, 2008 | LG WM-2077C Front Load Washer
LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Dec 01, 2007 | LG Washing Machines
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Sep 23, 2007 | LG WM1814CW Front Load Washer
LG WM2101HW 4.0 cu.ft. Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
