My Blueway air con is not cooling , fan works but is not cooling
My Blueway air con is not cooling. Motor works and fan works but is not cooling. Any solutions ??
  • pippyandrews Jan 21, 2009
    Does that mean its not worth fixing, if it is how much am I looking at?
  • Anonymous Mar 15, 2009
    Problem Solver:
  • 12 Answers
More than likely the capacitor is bad internally
Posted on Jan 21, 2009
The cooling fan of my 1988 Toyota Corrola 1600 model 4A-L stopped working.What to check for and also need a wiring diagram of the fan cooling circuit.
engine cooling fan motor spinning too slow
faulty thermostatic switch
it may have a relay in the engine bay cluster
interior cooling fan has a relay
air con system fault or out of gas
the switch has worn
Nov 24, 2016 | Toyota Cars & Trucks
Jetta 1.9 TDI 2006 the cooling fan comes on five minutes after starting
sounds about right if in heavy traffic or hot day
the air con one comes on with air con
engine cooling fan on sooner than normal
things to check
check coolant level
replace thermostat
fan relay or resistor
check coolant hoses and clamps for leaks
faulty thermostatic fan motor switch
Nov 03, 2016 | 2006 Volkswagen Jetta
My car 05 honda civic lx special edition.radiator fan not working but the cooling fan & radiator fan are good,relay ok,temp.sensor,fan switch new,thermostat but the radiator fan still not working.
There are 2 fans on your motor , air con fan comes on when the air con is switched on. The engine coolant fan comes on when the motor reaches operational temp, around 85 to 95 degrees . there is a heat censer on the engine block or radiator that controls battery voltage to the fan. with a volt meter check both sides of this censer for battery voltage, with the engine hot. replace if faulty.
Oct 29, 2016 | Honda 2005 Civic LX
WHRE IS THE FAN FUSEE IN A 1.3 TOYOTA TAZZ
you changed the thermo switch and relays and it didnt fix it
did you test the fan motor itself
the fuse box cover should have a fuse layout diagram
engine cooling fan
look for a 30 amp fuse
they usually near the fan relays
is the air con cooling fan working with air con on
and engine running
26238251-04wei2fenntfkeahz4fn3g0j-5-0.jpgwhre-fan-fusee-in-1-3-toyota-tazz#sln-36379873-rmi0ll110lgwm2wbdtthe4rs-3-2_0.jpg
Jul 15, 2016 | Toyota Cars & Trucks
We have a 2002 Chevy Malibu.. And the fans want run to keep the motor cool.. When the motor get too hot the car will shut off.. So, what do I do about it??
First check fuses, there are two fans if fitted with air con. The air con. fan only comes on with the air con. The engine radiator cooling fan comes on at operation tem., it is controlled by a censer switch on the radiator .If there is power to the switch and the switch is OK the fan motor is at fault.
Aug 10, 2014 | Cars & Trucks
Hello there i have a small problem with a 4 month old mitsubishi split system air con. We noticed it was not cooling as good as it has been on inspection out side i found a goanna had got in some how and...
Since the fan was jammed it sounds to me that the fan motor is burnt out. The info for replacement should be on the fan motor itself. Good Luck on your repairs
Dave
Nov 02, 2009 | Heating & Cooling
It makes a noise while moveing likea roar
If the car makes the sound you say,try this.Turn the air/con off and on and see if the sound goes off and on.The car has an electric fan that comes on with the air/con to help cooling of the motor.It may also be the fans for the engine cooling system.If the car starts without the sound and it then kicks in later,its the cooling system working properly.Hope this helps
Oct 30, 2009 | 1997 Jeep Grand Cherokee
Blueway air conditioner not fully cooling
Check the radiator for dirt, and check if the radiator fan is functioning. Do you notice any wetness or ice build up on the outside copper pipes. If so, suggest calling a refrig. tech. to add gas. The gas used is R22 on most aircons.
Feb 02, 2009 | Heating & Cooling
Broken barrel fan
I am not familiar with the Blueway brand but have never seen an air conditioner on which you could not replace the fan.
Is this a split system or a window unit? If a window unit it may not be worth the trouble.
Jan 29, 2009 | Heating & Cooling
Blueway airconditioner/heater/humidifier
I purchased a Blueway Mod BL 168 cooler N12907 0041344 air cooler/humidifier today November 9th, Purchesed from Rezzies Betta Electrical Stocklands Mall 5 Breeze Parade Forster N.S.W
My son was the sales Person, he was very busy so we took the display model which was last one in stock, he was very6 busy and could not find the book for it, They all looked later and still could find the book, I need this before I can use it. Cant get Blueway Company up on the internet. Please help me out here, as its very hot and I cand use it Thank You so much
Heather Kirkby
Jun 14, 2008 | Humidifiers
Heating & Cooling Logo
798 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
