Question about Bbe Fjb 200x Phono Preamp
Bbe Fjb 200x Phono Preamp only one speaker works
How can I connect A BBE482i Sonic max. to this mixer amp and how to hook it up, will it help my sound system I have two Pr15 mains and two PV12 monitors
Go from the main out on the front panel to the left bbe input then from the left bbe output to the power amp 1 input. Then do the same from the monitor out to the right side and back to power amp 2. BBE units can enhance your sound, but too much will tend to sound brittle.
Mar 04, 2016 | Sonic Music
Right monitor has stopped working, left still works
Electrical parts were bad, I returned the speakers for replacement under warranty. FYI... I opened the back and noticed an electrical burn smell.
May 06, 2014 | Alesis M1 Active 320 USB Speakers
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
How to reset password or hard reset crossover ds48
Just spoke with BBE and they said the only way around this is to send them the unit and they will replace it with an unlocked unit. There is no charge, just shipping it to them in southern California.
Jun 27, 2011 | BBE DS 26 Digital Crossover and Speaker...
Have BBE Acousimax pre-amp. Clip light is on and will not turn off. I have not power through the unit but power source seems ok. Fuse problem?
This device, unlike most guitar pedals, requires a 12 volt power supply. Are you sure yours is the original? If the supply is low, the internal electronics will show clipping. Make sure you are using the original power supply and if so, check the voltage it is producing.
May 16, 2011 | Bbe Acoustimax Sonic MaximizerPreamp Pedal
Just bought it today I grounded the tt to the preamp and have a hum coming thru my speakers
First thing is to verify that ALL your interconnected equipment such as TT, preamp, Amplifiers ALL are powered from the same receptacle or power source. A ground loop might exist if they are on separate circuits in the room.
Second is the quality of cables must be good. Some have very poor shielding.
Apr 02, 2011 | Bbe Fjb 200x Phono Preamp
Hi, i have the Lexicon Alpha Personal Recording Studio connected to my mac via USB. im running two powered speakers via phono to phone lead. When i try play music through the speakers it doesnt play...
Make sure you have NO antivirus/antispyware/antiadware or other resource hogging background programs running while processing the audio. These programs hog resources to the point that the buffering within the audio devices is overrun causing gaps.
Nov 22, 2010 | Lexicon Alpha Personal Recording Studio
Setting up a Behringer PMP5000
You can do the effect via the "POWER AMP INSERT" jacks.
Use TRS interconnects to yout effects unit.
If the effects unit does not have TRS type bi-directional in/out ports, you MAY need to make special cables to connect the units. Refer to figure 4.5 on page 9 of your PMP5000 user manual for INSERT connections.
Jul 15, 2010 | Behringer Europower Pmp5000 Powered Mixer...
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
Bbe Fjb 200x Phono Preamp Logo
Top BBE Music Experts
Vito Vacirca Jr.
Are you a BBE Music Expert? Answer questions, earn points and help others
